Notices
Overclockers Forums > Overclockers.com Teams > Competitive Benchmarking Team
Competitive Benchmarking Team The Wild Side... Our competitive benchmarking team calls this section home. We are ranked #1 in the US on hwbot.org! Discussions focused on hwbot.org benchmarks.
Forum Jump
From ambient to SUB-ZERO
Thread Tools
Old 04-12-10, 11:37 AM   #21
Sam__
Sam__'s Avatar
shame you didnt have a thermometer .
but some very good results there
__________________
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
"I think there is a world market for maybe five computers."
- Thomas Watson, chairman of IBM, 1943
Sam__ is offline   QUOTE Thanks
Old 04-12-10, 12:23 PM   #22
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Quote:
Originally Posted by Brolloks View Post
Oh , and as I had no idea on temps, the bios got stuck at this, irrespective of the voltage or load, same with Coretem, could not get realtemp to work as I use a stripped down version of XP and missing some components
The only temp sensor that I've seen scale far sub-zero was on a 7600GT
That's why most extreme cooling benchers use a digital thermometer Although for dice, if you just keep it as cold as possible...a thermometer is somewhat pointless IMO
Quote:
Originally Posted by sno.lcn View Post
Crushing that much DI up is a huge pain, trust me.
Very true...skip that cr@p and go straight to LN2
__________________
THE POST COUNTER IS NOT AN INTELLIGENCE METER!
Intel i3, i5 and i7 Overclocking Guides
Heat "Water & Wood" computer desk build log My HWBOT Profile
MAX11Lv3 - "It kind of reminds me of going to the circus and seeing a mini drive around and then 83 clowns jump out of it!" - ollien33
i7 3820 @ 5GHz || 32GB G.SKILL @ DDR3-2000 || GTX580 tri-SLI || Corsair AX1200 || Custom water cooling
MIAHALLEN is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 12:28 PM   #23
Voidn
Voidn's Avatar
Great write up! Welcome to dice land, Now crank those volts!
20-25lbs would last me 2 days on single and dual cores. I burned through almost 40lbs dice'ing a 920 last weekend .
I bought 2 boxes of eraser from this place. They offer bulk discounts.
__________________
.........................__ .....__..___.___.____.._..._......
.Celeron.356.@6324MHz....\ \\.../ /// _ \_ _| ._ \| \\| |\....
.Core.2.E8500.@5796MHz....\ \\./ //| | | | || | | | .\| ||....
.Core.i7.980x.@5650MHZ.....\ \/ //.| |_| | || |_| | |\. ||....
.Core.i7.2600k.@5557MHZ.....\ .//...\___/___|____/| ||\ ||....
.Core.i7.920.HT.@5153MHz.....\//..................|_|| \||....
Folding For Team 32
Benching for OCF / overclockers.com
Voidn is offline   QUOTE Thanks
Old 04-12-10, 12:28 PM   #24
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
Gautam had mentioned previously in one of Bobnova's threads that he found a temp sensor to be useful with Dry Ice, to help keep temps more stable. I'd think it would help give you an idea or gauge if you are adding more material when you need to.
__________________
The OC Forums Way
We are a team. We are a community. We are a fellowship made strong by mutual respect and shared dedication to the task of enriching all who come here.
The OC Forums Thank You Thread
Put your computer to work for our OC Forum Teams!
Try out our POST TEMPLATES, they save you time answering common questions!
I spend half my money on CPUs, GPUs, and Liquid Nitrogen. The other half I waste.
I.M.O.G. is online now Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 12:33 PM   #25
ghost_recon88
Senior Jedi Master
Premium Member #9
ghost_recon88's Avatar
Yep that's the same stuff I used when I had a pot. Everyone I talked to seemed to recommend that brand.
__________________
The will to live will always outweigh the ability to die
ghost_recon88 is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 12:58 PM Thread Starter   #26
Brolloks
Benching Senior on Siesta
Premium Member #8
Brolloks's Avatar
Nice work so far. Need to see you pushing at least 5.6 when you get back home and shoot for more
If you're benching a quad hard, and maybe a GPU, it's easy to burn through 30+lbs in one session. Crushing that much DI up is a huge pain, trust me.
Thanks Jeremy , I was somewhat disappointed to be honest, was hoping to get to 5.5-5.8 last night. I think this board is holding me back, at 530 FSB I got stuck until I drop the RAM speed and then I could get all the way to 560 FSB when I got stuck again, went to bed soon afterwards
Quote:
Originally Posted by Bobnova View Post
6.4lbs lasted me four or five hours last friday, that's on a conroe dual core.
9lbs lasted about seven hours on a different conroe.
You can't really store dry ice though, at best you lose 10% per day, and that takes really good insulation.
Yes, depends how fine you smash the stuff, you get lower temps on powder apparently but it reacts quicker as well. I still had a full block this morning, I kept the bag with leftover powder and one block in the cooler bag. the bag does get very cold underneath and ice tends to pack on, so I put it on a piece of card board
Yep, I ordered an digi thremal unit that goes to -326 C, you can guess I'm not going to hang around smashing dice for much longer or what
You on the money Miah, my impatience will drive me to LN2 in no time
Thanks, and I will for sure get some more of that rubber stuff, no more air benching for me Going to prep all my boards for icy benching
Brolloks is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 01:08 PM   #27
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Another tip with the eraser...some is tougher than other...If you get some that seems very difficult to kneed, stick it in the microwave (tennis ball sized amount) for about 60-90 minutes on low (or defrost)....then it should be easier to work with
__________________
Old 04-12-10, 01:10 PM   #28
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Yep, I ordered an digi thremal unit that goes to -326 C, you can guess I'm not going to hand around smashing dice for much longer or what .....
.....You on the money Miah, my impatience will drive me to LN2 in no time .....
.....Thanks, and I will for sure get some more of that rubber stuff, no more air benching for me Going to prep all my boards for icy benching
Very exciting...you're made for this stuff Ed
__________________
Old 04-12-10, 01:29 PM   #29
Khemikal
Khemikal's Avatar
10 Year Badge
Did you honestly mean minutes?
__________________
E3110 @ 3.6GHz(daily use), Asus P5Q Pro, 2x AMD (Sapphire) 6870s, 4gigs G.Skill DDR2 1066, 2x 21.5" 1080p Dells
Heatware
Join the OCF Benching Team
Khemikal is offline Folding Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 01:33 PM   #30
Sam__
Sam__'s Avatar
Quote:
i bloomin hope not!
__________________
Old 04-12-10, 01:36 PM   #31
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
LOL ...no I ment seconds
__________________
Old 04-12-10, 01:46 PM   #32
mgoode
mgoode's Avatar
Nice write-up Ed!! You will be looking for an LN2 dewar in no time
__________________
Benching: 980X
"Behold, I am Funkadelic. I am not of your world. But fear me not, I will do you no harm. Loan me your funky mind and I shall play with it. For nothing is good unless you play with it. And all that is good, is nasty!"
("What Is Soul," Funkadelic, 1969)
mgoode is offline   QUOTE Thanks
Old 04-12-10, 01:55 PM Thread Starter   #33
Brolloks
Premium Member #8
Brolloks's Avatar
Thanks Mike, making the conscious decision to make the switch was the hardest for me...however resistance is futile as they say
Old 04-12-10, 02:10 PM   #34
Dolk
I once overclocked an Intel
in a nightmare and
it was HORRIBLE Senior
OCF's Plaything
Dolk's Avatar
I want more Pics!
__________________
(╯°v°)╯︵ ┻━┻
currently has .2738428927348 internets
create your own rules to find the answer
be proud of the pink stars
Earthdog: New codename for SB for extreme overclockers... BLEH.
Dolk is offline Author Profile Benching Profile   QUOTE Thanks
Old 04-12-10, 03:23 PM Thread Starter   #35
Brolloks
Premium Member #8
Brolloks's Avatar
Lol, of what Dolk?
Old 04-12-10, 03:34 PM   #36
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Ed...you need to swoop up that dewer Todd has had on sale for months....it's too good a deal to pass up
I tried to convince him to sell it to me, but he was to lazy to package it up for me (JK Todd )
http://www.overclockers.com/forums/s...d.php?t=620886
__________________
Old 04-12-10, 03:35 PM   #37
Deanzo
Benchmarking Senior Member
Deanzo's Avatar
Nice work Ed,
Now you've seen how easy and somewhat safe it is.
Stop with the slow stuff, and get that 980X on the go.
__________________
My Heatware
icebob: Do we have to flip the screen upside down to see you Dean!!!!
Deanzo is offline   QUOTE Thanks
Old 04-12-10, 03:38 PM   #38
sno.lcn
Senior Member
sno.lcn's Avatar
No one can buy that dewar until next month when I move back to Atlanta. Then it's mine
sno.lcn is offline Author Profile Benching Profile Folding Profile SETI Profile   QUOTE Thanks
Old 04-12-10, 03:46 PM   #39
Neuromancer
Neuromancer's Avatar
I bought mine from the same place.
good deal
Nice going brollocks I just took the plunge into DIce myself a couple weeks ago If my gpu pot arrived I am doing my vmods when I get home tomorrow and going LN2 for hte first time this weekend!
It really is addictive...
Neuromancer is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 04-12-10, 03:49 PM   #40
Dolk
in a nightmare and
OCF's Plaything
Dolk's Avatar
Lol, of what Dolk?
There should be more Scores posted
__________________
(╯°v°)╯︵ ┻━┻
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
