Notices
Overclockers Forums > Overclockers.com Teams > Competitive Benchmarking Team
Competitive Benchmarking Team The Wild Side... Our competitive benchmarking team calls this section home. We are ranked #1 in the US on hwbot.org! Discussions focused on hwbot.org benchmarks.
Forum Jump
From ambient to SUB-ZERO
Thread Tools
Old 02-14-11, 04:34 PM   #101
Wega!
Senior Member
Wega!'s Avatar
10 Year Badge
I have to ask you guys about this conformal again. I've gotten in contact with a group of danish overclockers, and they are helping me get the stuff that i need to go cold. Things are not as easy to get in Denmark
But they keep saying that the acrylic based conformal is ok to use. They all use it, and none of them have seen any cracks or sigh of pressure on components... Some of them have been using it for years, and say that they have never had problems with it. Would it be totally stupid of me to give it a try? The silicon based conformal is just so hard to get, because the places that sells it, only wants to deal with business 2 business, and i dont have a business
So what do you say, is the acrylic really stupid, or is it "just" not the best solution?
__________________
You say Lady Gaga, I say Dash Berlin
You say Hannah Montana, I say Orjan Nilsen
You say Owl City, I say Above & Beyond
You say Justin Bieber, I say Armin Van Buuren
You say Taylor Swift, I say Dj Tiësto
In Trance we trust!
Benching mayhem: Asus Rampage Extreme, Gigabyte Ep45 UD3P, QX9650, Q9550, E6300, 4x Cedar Mill's, Corsair Dominators 2000Mhz 8-9-8-24, Crucial Ballistix DDR2, Asus GTX480, XFX GTX260, Inno 8800GTX, Zotac 8800GT, Piotres CPU pot, EK Supreme HF, MCW60 Mo-Ra 3 Pro, Ek DC 4.0 and a Corsair TX750
Daily driver: Asus P5Q Pro, Q8400, OCZ PC8000, GTX460, Enzotech Sapphire, EK GTX460 full block, XSPC res/pump and a HWLabs GTX480.
Wega! is offline   QUOTE Thanks
Old 02-14-11, 06:01 PM   #102
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
I'd say its quite possibly fine... Some people have their opinions, but most people follow suit of what others are doing.
Unless you hear from someone who has used it and believe they killed things as a result... Most people are probably relaying what is typically advised.
Gomeler doesn't use conformal. Just a bit of grease and toilet paper is all he used when benching all day at the XS party.
I don't use conformal... Microcenter didn't have it, and I didn't look real hard for it anywhere else. I use dielectric grease which I get in 3oz tubes at an autoparts store. I put that in the ram slots and in the CPU socket to make sure no air or condensation gets in there.
Otherwise, I just use some paper towels, frost king, and armaflex. Once you go cold, you will get an idea of how good your insulation is. Watch for frost growth in places you haven't insulated. If you notice some, you probably want to stop before too long and remove power to let things dry up... Give it some time to make sure things are good and dry before you power back up then improve your insulation for next time.
I had a RAM slot frost almost entirely over (3rd slot away from CPU socket). I kept running the session until I was done, then made sure I used grease on all the RAM slots after that.
Keep in mind I've only been going cold for a couple weeks now, but this is what has worked for me. I'll be sure to post in full detail when I kill something. But I know with my current insulation method that frost doesn't grow south from the CPU socket area. When I go cold on the GPU, maybe I'll look at using conformal there... But I'll probably insulate well around the GPU, watch for frost growth, then make adjustments if necessary. Generally however if you are insulating well and you have a fan blowing the smoke away from the board you shouldn't have many problems and the conformal wouldn't have any work to do anyways.
__________________
The OC Forums Way
We are a team. We are a community. We are a fellowship made strong by mutual respect and shared dedication to the task of enriching all who come here.
The OC Forums Thank You Thread
Put your computer to work for our OC Forum Teams!
Try out our POST TEMPLATES, they save you time answering common questions!
I spend half my money on CPUs, GPUs, and Liquid Nitrogen. The other half I waste.
I.M.O.G. is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 02-14-11, 06:08 PM   #103
CgS Drone
CgS Drone's Avatar
Quote:
Did you have a fan blowing on the slots Matt?
__________________
C2D E8500/E6300/E6400, Gigabyte EP45-UD3P--------955BE, TA890FXE, Cooler Master GX 750
Noctua D-14, Corsair 750TX---------------------------HAF 932, Cooler Master 212+,
Ballistix 6400 4-4-4-12 D9 2x1------------------------Geil Black Dragon (2x2GB)
EVGA 8800GTS 512, Raptor 75gb.---------------------9800 GT 512mb, Seagate 500gb
>>>>>>>HeatWare<<<<<<<
CgS Drone is offline   QUOTE Thanks
Old 02-14-11, 06:15 PM   #104
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
Yea. It was blowing over the ram sticks and up to blow the LN2 smoke away from the board. The 2nd and 4th slots were in use, so there probably wasn't a lot of of airflow over the frosted over 3rd slot...
Somewhere there is a balance between fans blowing on the board. Keeping it warm might prevent frost growth but if you get frost and it melts, that's probably more dangerous than frost.
My Ram hangs out around 11-16C typically when running LN2, according to a probe stuck in the heatspreaders.
__________________
The OC Forums Way
Old 02-15-11, 06:53 AM   #105
Wega!
Senior Member
Wega!'s Avatar
10 Year Badge
Thanks IMOG, I think I'll just try with the acrylic then. Then I'll be the one that can report back if it's really bad.
I think I'll go totally crazy and over-isolate, because it's the first time I try it Also some of these guys have access to Ln2, so if I'm lucky I might try that as well. So I'm just going to insulate so that it's good enough for Ln2 also, then I should be on the safe side if I only use DICE
__________________
In Trance we trust!
Old 02-15-11, 07:02 AM   #106
CgS Drone
CgS Drone's Avatar
This and what Miah is doing has me curious if going cold on the RAM is going to give practical differences in benching. My main concern right now would be when I go to LN2 for the first time and worrying about the frost conducting on the RAM. I would have to give it a shot and see but if it looked like it was going to be an issue I was thinking of removing the heat spreaders and taping over the gold pins and using conformal on the RAM then place the heat spreaders back on and just use die electric grease in the slots to try to prevent any frost from being able to get into there and causing an issue.
__________________
>>>>>>>HeatWare<<<<<<<
Old 02-15-11, 07:17 AM   #107
m0r7if3r
Water Cooling Sticky Reading Enforcement Official
m0r7if3r's Avatar
Quote:
I've seen data that it does but I can't find it now...sufficient to say, it helps, though it varies by the stick and the ram will coldbug (I seem to remember optimal temperature for the testing I saw being somewhere around -60C
__________________
If years were seasons, this December would be the December of our December.
-Abed #sixseasonsandamovie
Heat
m0r7if3r is offline Author Profile Heatware Profile   QUOTE Thanks
Old 02-15-11, 03:25 PM Thread Starter   #108
Brolloks
Benching Senior on Siesta
Premium Member #8
Brolloks's Avatar
Exactly, that is why I keep fans away from the pot as airflow around the pot causes frost/ice to melt and the water will run down to wherever, rather let the frost build up , that way it stays on the pot and only melts after you done benching
Brolloks is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 02-15-11, 09:49 PM   #109
xsuperbgx
Benching Team Leader
xsuperbgx's Avatar
I have a tip from my last dry ice session, after benching a few hours and I still needed to do more benching. My acetone was not working very good because I had knocked in so much frost from around the top that it was starting to freeze. I let the dry ice mostly melt then I stuffed some paper towels down into the pot to soak up the acetone then refilled with fresh acetone.
__________________
Come join in on the benching fun! Competitions, contests, prizes. + Learn tips and tricks to get a better score.
Benching:3570K.................................................. .........................................
Asus Rampage V Gene.................................................. ......................................Join us in the "OVERCLOCKTAGON"!!!
Gaming: Intel 2500K...............................Htpc: Silverstone GD05B
HD7970
.................................................Pentium G840
Z68X-UD3H-B3.......................................H67M-D2-B3
Vertex 3..................................................Hd5450, Lenovo N5902
heat..................................................BF3/origin= Circling_Urubu
xsuperbgx is online now Benching Profile Folding Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 02-15-11, 09:58 PM Thread Starter   #110
Brolloks
Premium Member #8
Brolloks's Avatar
Quote:
Yep, use fresh acetone every time
Old 04-15-11, 04:00 AM   #111
mikealaska
mikealaska's Avatar
Quote:
Originally Posted by Voidn View Post
Great write up! Welcome to dice land, Now crank those volts!
20-25lbs would last me 2 days on single and dual cores. I burned through almost 40lbs dice'ing a 920 last weekend .
I bought 2 boxes of eraser from this place. They offer bulk discounts.
link is broken , what am i looking for ?
Faber-Castel @ the hobby shop,,http://www.erasersworld.com/eng/faber.htm
__________________
Asus-M4A89GTD pro, OS win7-64
Phenom llx4,955be Deneb 3.2GHz
2x2GB Crucial ddr3
XFX Radeon HD5770A-ZNFC 1Gb
XFX Radeon 650W psu
zalman cnps9900 max
zalman z9 plus case
seagate barracuda 7200 1TB, asus dvd
samsung SyncMaster 2494HM
OC.Tools:prime95, cpu-z ,coretemp, 3dmark06
mikealaska is offline   QUOTE Thanks
Old 04-15-11, 09:15 AM   #112
Bobnova
Air Superiority Senior Member
Bobnova's Avatar
That's the stuff!
__________________
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -- Einstein (maybe)
How to check your PSU with a multimeter.
17bXw5t51rEBXGavJFMJsC8g7HQgThUGc7
Heatware.
Bobnova is offline Author Profile Benching Profile Folding Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-15-11, 09:21 AM   #113
Seebs
Fronting as a Mod Member
Seebs's Avatar
There you go....
http://www.dickblick.com/products/de...ubber-erasers/
__________________
Daily Driver: GA-890FXA-UD5 - Ph II X6 1090T - 16GB DDR3 1333MHz - HD 5670 - Venomous X Black + 260 CFM San Ace - VX450W - CM 690 II Advanced
Join the "Benching Team" - We have secret sauce! - OptyTrooper: GPUs are for burning not playing games anyway
Kona on League of Legends: This game sits about as well with me as a gallon of prune juice does, and the results are just as nasty.
I done got Pinked...
Be sure to pre-tin everything (even soldered stuff!) with leaded solder. None of the RoHS junk. You want good old fashioned toxic heavy metals. ~ Bobnova
Seebs is online now Benching Profile Heatware Profile   QUOTE Thanks
Old 04-15-11, 10:54 AM   #114
mikealaska
mikealaska's Avatar
ok ! got it , slowing getting my list of materials and tools , this is gonna be fun!!
whats interesting is Dolk is benching our board .
__________________
2x2GB Crucial ddr3
XFX Radeon 650W psu
zalman cnps9900 max
zalman z9 plus case
Old 04-15-11, 10:21 PM   #115
DR650SE
DR650SE's Avatar
I just piced up some of that stuff from Micheals. Now I just need to get some hardware and get started
Eraser, Check
Dice pot, check (en-route)
Hardware...I'll get back to you on that
__________________
Black Alienware M17X R2 | 940-XM | XFire ATI 5870 | Intel 160GB X-25M RAID 0 | N 6300 | 8GB 1333 MHz | RGB LED | Blu-ray Burner | Win 7 Ult | Vantage: 19291 | 3DMark06: 23720
Black Alienware M11X R1 | SU7300 | 1GB 335M | 256GB SSD | 8GB DDR3 | Win 7 | Vantage: 3308 | 3DMark06: 7129
Black Inspiron 1720 | T9500 2.6GHz | 8600M GT | 256GB SSD | 640GB 5K4 | 4GB DDR2 | Win 7 Pro | 1920 x 1200 | Vantage: 1457 | 3DMark06: 4366
DR650SE is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
