- Oct 12, 2010
- Colorado Springs, CO
- Thread Starter
- #141
They came from Jab-tech.com
Send it back. It's fine but they should NOT mail one out like that.
It's not perfectly new. Was a test rad or something.
Send it back.
Who did you buy it from for future reference?
con did it, I think it looks pretty good
I suck at taking pics.
One note, one the second and third one, you can see the metal a bit on the holes. That's my fault, cleaning some of the water off, i pressed too hard and some of the paint came off.
The first image is all 4 Rads, the other 4 are from left to right. With the first one being the same one I showed pics of earlier.
NOT RESIZED
http://ispano.mine.nu/files/R0.JPG
http://ispano.mine.nu/files/R1.JPG
http://ispano.mine.nu/files/R2.JPG
http://ispano.mine.nu/files/R3.JPG
http://ispano.mine.nu/files/R4.JPG
