Notices
Overclockers Forums > Hardware > Cooling > Water Cooling
Water Cooling Discussion devoted to blocks, pumps, radiators, reservoirs, tubing, and everything else to get you running smooth on a water loop
Forum Jump
Beginner's Guide to Water Cooling Your PC *** READ THIS FIRST ***
Thread Tools
Old 04-15-11, 07:42 AM   #21
hokiealumnus
Water Cooled Moderator
Overclockers.com Lead Editor
hokiealumnus's Avatar
Quote:
Originally Posted by Conumdrum View Post
I was really hoping this link Hokie just wrote would stay at the TOP of the current posts, in BIG BIG red BLING letters, and not buried in the sticky link. We know how little peeps start there. They spend 20 min typing the first question that are so easily answered by spending 20 minutes reading. Saves ALL of us time and effort..
So, can it become the first post forever in the posts? And not lost somewhere?
I sticked it, put some capital letter text with asterisks and made it the only yellow-text thread (frontpage), but you know how stickies are. I fear it will receive less exposure than a random thread. Unfortunately you can't format subject lines with color/bold. Hope this helps a little at least.
Quote:
Originally Posted by Ace. View Post
Good Work Buddy
Thank you very much!
__________________
Enjoy benchmarks? Join the benching team! | New to water cooling? Read the Beginner's Guide to Water Cooling Your PC.
xsuperbgx - "As a wise man once said: "Less talky. More clocky."" | cyberfish - "When overclocked, it's undefined behavior."
I.M.O.G. - "Vaseline on Ivy Bridge is a bad idea. But not so bad of an idea that it can't be fixed with a torpedo heater, a dishwasher, an oven, and a few hours. "
\m/ OverClockers mATX L33T Club \m/ - Join Now! - My mITX Build
hokiealumnus is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-18-11, 12:42 PM   #22
robertcutshall
robertcutshall's Avatar
[IMG][IMG][/IMG][/IMG]
robertcutshall is offline   QUOTE Thanks
Old 04-18-11, 12:55 PM   #23
hokiealumnus
Is that a flow meter between your CPU & NB blocks?
__________________
Old 04-18-11, 01:00 PM   #24
robertcutshall
yes i thought that was the best place for it..lol
still waiting on do cooling on video cards and mem..
Old 04-18-11, 01:27 PM   #25
hokiealumnus
Honestly, next time you do a tear down, take the thing out. It's not going to do you a bit of good. If you have enough flow, your temps will be fine. If you don't, they'll be too high. If your pump stops, you'll know when your CPU throttles. All they do for you is restrict flow IMHO.
Also, don't bother with memory unless you just want it for looks. Modern memory doesn't get hot enough to justify the restriction you'd put in your loop. At least IMHO.
__________________
Old 04-18-11, 01:29 PM   #26
robertcutshall
ok thanks for the info
Old 04-18-11, 02:01 PM   #27
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Dude Jeremy...you've totally outdone yourself with this one
Everytime I read something I wanted to criticize, I'd continue on, and you'd address my concern in the next paragraph. Very well written, and exceptionally thorough.
The only criticisms fall on your editors; the titles/headings/sub-headings could be improved a little IMO.
Great work
MIAHALLEN is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-18-11, 02:08 PM   #28
hokiealumnus
Thank you very much! I'm as much to blame for those items as any. We're somewhat limited with our heading options and some look too similar to others. Now, if you were referring to their wording, I'm happy to entertain changes. Let me know what you had in mind.
__________________
Old 04-18-11, 04:04 PM   #29
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Ah, a couple more things.
Mention running multiple pumps in series.
When talking about tubing, I would mention the difference between 1/16" walls and 1/8" walls, the advantages/disadvantages of each size....and you might also mention that (contrary to popular belief) the most kink resistant size is 3/8" ID 5/8" OD
Old 04-18-11, 04:05 PM   #30
m0r7if3r
Water Cooling Sticky Reading Enforcement Official
m0r7if3r's Avatar
Quote:
Originally Posted by MIAHALLEN View Post
Ah, one more thing. When talking about tubing, I would mention the difference between 1/16" walls and 1/8" walls, the advantages/disadvantages of each size....and you might also mention that (contrary to popular belief) the most kink resistant size is 3/8" ID 5/8" OD
I've heard the best is 1/2"x5/8" with antikink coils
__________________
If years were seasons, this December would be the December of our December.
-Abed #sixseasonsandamovie
Heat
m0r7if3r is offline Author Profile Heatware Profile   QUOTE Thanks
Old 04-18-11, 04:11 PM   #31
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
I'm talking about bare tube (no coils)....bringing coils into the discussion might change things a bit
....or are you just being a PITA?
Old 04-18-11, 04:40 PM   #32
m0r7if3r
m0r7if3r's Avatar
I'm appalled, I would never...
But no, I'm actually genuinely interested in what tubing combination gives you the best turn radius...haven't seen much on it since the testing over at XS, which didn't include any kink coil testing
__________________
Heat
Old 04-18-11, 05:10 PM   #33
hokiealumnus
Thanks for the input miah! Will work on getting that in as time allows.
Old 04-18-11, 05:44 PM   #34
MattNo5ss
5up3r m0d3r4t0r
Overclockers.com Editor
MattNo5ss's Avatar
The thicker the walls, the less likely to kink.
3/8" ID 5/8" OD has 2/8" 1/8" thick walls. 1/2" (4/8") ID 5/8" OD has 1/8" 1/16" thick walls.
__________________
i7 3770K | ASUS Maximus V Gene | 4x4GB G.Skill Ripjaws DDR3-1600 9-9-9-24 | EVGA GTX780 SC ACX | 256GB OCZ Vertex 4 | SeaSonic SS-1000XP
My Overclockers.com Articles | HWBot Profile | Heatware (98-0-0)
Projects: Copper-Framed, MDF Station | PVC-Framed, MDF Station | Custom Cascade Cart/Case | Untitled TJ07 Build
MattNo5ss is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-18-11, 05:51 PM   #35
QuietIce
Disabled
Quote:
3/8" ID 5/8" OD has 2/8" (1/4") thick walls. 1/2" (4/8") ID 5/8" OD has 1/8" thick walls.
Actually, it's only half those numbers, 1/8" and 1/16" thick, because there are two walls per diameter.
Adding coils to the outside changes that, though, so 1/16" thick tubing with coils, like 1/2-5/8", won't kink as easily as tubing with 1/8" walls but no coils.
QuietIce is offline Author Profile   QUOTE Thanks
Old 04-18-11, 05:53 PM   #36
MattNo5ss
5up3r m0d3r4t0r
MattNo5ss's Avatar
Quote:
Oops, edited
But, yeah, 3/8"x5/8" has twice wall thickness.
__________________
Old 04-18-11, 07:56 PM   #37
m0r7if3r
m0r7if3r's Avatar
I think the reasoning is that the tubing itself will only bend so much, thinner tubing will bend more, so if you force it to not kink, you can get a tighter turn...
__________________
Heat
Old 04-18-11, 08:07 PM   #38
robertcutshall
i use the 3/8 tubing on my system...
__________________
Folding User Stats
Old 04-23-11, 10:27 AM   #39
Spotswood
Spotswood's Avatar
Thanks for the mention.
__________________
Rich
Custom Case Builder
Spotswood is offline   QUOTE Thanks
Old 04-23-11, 10:40 AM   #40
hokiealumnus
You deserve it; your cases are fantastic!
__________________
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
