Future Folding Farm Hardware Info Thread (LGA2011)
Budget, SandyB-E may well be a monster but i pretty much made up my mind when i found out
The pricing of Core i7-3930K has been confirmed at US$560
back around late July.........Hence, the following post.
Come launch time i think we'll be seeing more to the line up.........At least i'm hoping so :popcorn:
If not, i'll likely only get one for the sake of seeing what she's got.......But the farm will have to get a re-think. :-/
I still plan on getting one (1) but sadly there won't be a fleet of them. :(
If only big big adv was staying 12 cores. I'm only two frames into this P6903 but I'm getting a tpf of 37:43 with light comp usage and a PPD of 114459.
Latest Virtualbox running with all 12 cores
Ubuntu 11.04 guest
3930k 4.925GHz
Win 7 Host
Ubuntu 11.04 guest
3930k 4.925GHz
Win 7 Host
if this runs on native linux, i bet the tpf around 32-33"
W00t
Come on bigadv.... Want to see what it'll do!
Just curious... isn't 1.44v on the very high side of what is recommended "safe"? Just seems like a lot. I know folks run their 2600k cpus higher than 1.35v and have seen no ill effects as of yet and I just figured the voltage requirements would be in a similar range for SB-E.
Intel docs state 1.4v max. I'm running 1.53v right now, but on high end water. I have seen people state to not go past 1.6v unless you are going sub zero. Right now no one really knows what is safe, so in order to be "safe" you should stick to the Intel spec. Intel has been known to raise their specs on safe voltage before though.
Seems a few people are running between 1.35 and 1.5+ here and on other sites. If I am not mistaken CJ145 is running 1.53v core. I wonder how :mad: his CPU is? :)
At 1.525v 63c on hottest core with 72f room temp. WC setup in sig except switched to apogee HD. 1366 bracket on my R4E, will be switching to the 2011 system when swiftech finally releases it.
These are just testing clocks, not what I will be running 24/7. It will do 4.6GHz at a safer 1.35v all day long so that is what I will set it to. I just wanted to see what it would do at maximum clocks on Bigadv before they go away... :cry: at least for < 16 cores.
So far it has run folding for over 24 hours and not had one failure at current settings (4857.7MHz and 1.44V). 4.9GHz would fail OCCT and P95 for some reason even at 1.5v and I don't want to push it further than that on Corsair water cooling. I would push it if I had custom W/C though just to see if it could do 5GHz, even though I was still far away from "i7-3930K enabled thermal throttling at 86°C". It folds consistently at the current speeds and voltages at 68-72°C. The higher temps in my logs above were from running small data sets in OCCT.
Lets have some discussion on it though, what does everyone think would be a good safe voltage/temperature limit for 24/7 folding and not burning out the cpu in 30 days?
So I got a non big bigadv unit this time on my machine. Ubuntu 10.10 VM on my 3930k at 4.9GHz with 2133MHz cl9 memory.
Code:
Project ID: 6901
 Core: GRO-A5
 Credit: 7164
 Frames: 100
 Name: SB-E Hex VM
 Path: \\vmvmvmvm\FAH\
 Number of Frames Observed: 82
 Min. Time / Frame : 00:14:44 - 87,121.5 PPD
 Avg. Time / Frame : 00:14:53 - 85,807.8 PPD
 Cur. Time / Frame : 00:15:02 - 84,235.6 PPD
 R3F. Time / Frame : 00:14:55 - 84,953.3 PPD
 All  Time / Frame : 00:14:53 - 85,160.5 PPD
 Eff. Time / Frame : 00:15:09 - 83,529.0 PPD
Light use on the computer throws frame times all over the place. VM is paused for gaming etc.
So I got another big bigadv unit this time.
Virtualbox with win 7 host,
Ubuntu 10.10 guest
3930k 4.9GHz
2133MHz cl9 memory
Computer completely idle for these frames.
P6903
TPF: 32:47 over 9 frames
PPD: 140806
Ubuntu 10.10 guest
3930k 4.9GHz
2133MHz cl9 memory
P6903
PPD: 140806
Congrats! Very nice!
I'm also very jealous. I never was able to get virtualbox to work work for my i7 970 in win 7.
Specs and Pricing of Xeon E5-2600 series
I wonder how these will perform with SR3 boards and comapred to G34 set-ups :confused: :bang head
The E5-2630 price seems to be a sweet spot, for me anyways. All the rest a way, way out of my price range.
Model Cores Threads Frequency L3 cache TDP Price
Xeon E5-2603 4 4 1.8 GHz 10 MB 80 Watt $202
Xeon E5-2609 4 4 2.4 GHz 10 MB 80 Watt $294
Xeon E5-2620 6 12 2 GHz 15 MB 95 Watt $406
Xeon E5-2630 6 12 2.3 GHz 15 MB 95 Watt $612
Xeon E5-2630L 6 12 2 GHz 15 MB 60 Watt $662
Xeon E5-2637 2 4 3 GHz 5 MB 80 Watt $884
Xeon E5-2640 6 12 2.5 GHz 15 MB 95 Watt $884
Xeon E5-2643 4 8 3.3 GHz 10 MB 130 Watt $884
Xeon E5-2650 8 16 2 GHz 20 MB 95 Watt $1106
Xeon E5-2650L 8 16 1.8 GHz 20 MB 70 Watt $1106
Xeon E5-2660 8 16 2.2 GHz 20 MB 95 Watt $1329
Xeon E5-2665 8 16 2.4 GHz 20 MB 115 Watt $1440
Xeon E5-2667 6 12 2.9 GHz 15 MB 130 Watt $1552
Xeon E5-2670 8 16 2.6 GHz 20 MB 115 Watt $1552
Xeon E5-2680 8 16 2.7 GHz 20 MB 130 Watt $1723
Xeon E5-2687W 8 16 3.1 GHz 20 MB 150 Watt $1885
Xeon E5-2690 8 16 2.9 GHz 20 MB 135 Watt $2057
Cheapest 8 core Xeon is $1100. Damn you AMD, make better processors already...
Edit: I tried the core wrapper in the vm from kraken and TPF has dropped to 32:22
Biostar TPower X79
For anyone looking for another option in the LGA2011 motherboard line up.....
Biostar TPower X79
Said to be shipping late Dec/early Jan, with retail availability ~Jan 15th.
GIGABYTE Firmware (BIOS) Update on Certain X79 Series Motherboard Models
City of Industry, California, December 27, 2011-- It has come to our attention that certain X79 Series Motherboards (see models below) may malfunction due to excess heat when performing Extreme Overclocking beyond the board’s limit. To address this issue and to ensure our product is being used as intended, we urge existing X79 users to either visit GIGABYTE’s official website to download and update their X79 series BIOS, or contact GIGABYTE’s regional service center.
The GIGABYTE X79 Series Motherboards in question are ONLY limited to the following models: G1.Assassin 2 , GA-X79-UD7, GA-X79-UD5 and GA-X79-UD3. The X79 series motherboards not named above are outside the scope of this statement and not applicable.
GIGABYTE is committed to the following:
GIGABYTE will make its best efforts to ensure that all partners, distributors and retailers have the latest firmware (BIOS) installed on existing X79 Series Motherboard models.
GIGABYTE’s commitment to service excellence will not be compromised. The GIGABYTE X79 Series Motherboards offer an unprecedented 5 year warranty, the longest offered in the industry. We encourage users to register for this FREE 5 year warranty here:
http://e-service.gigabyte.com/Productregistration/webevent/ExtendWarranty_US.aspx
If any existing user is still unsatisfied after the recommended firmware (BIOS) update of their X79 Series Motherboard, GIGABYTE will offer an unconditional replacement of their X79 Series Motherboard (same model). No Questions Asked.
The latest X79 Series Motherboard BIOS update may be found below.
G1.Assassin 2 – Please update to BIOS F7 or later
Download : http://www.gigabyte.us/products/product-page.aspx?pid=4046#bios
GA-X79-UD7 – Please update to BIOS F7 or later
Download : http://www.gigabyte.us/products/product-page.aspx?pid=4047#bios
GA-X79-UD5 – Please update to BIOS F7 or later
Download : http://www.gigabyte.us/products/product-page.aspx?pid=4049#bios
GA-X79-UD3 – Please update to BIOS F7 or later
Download : http://www.gigabyte.us/products/product-page.aspx?pid=4050#bios
This demonstrates GIGABYTE’S commitment to service excellence to all our customers in USA and Canada. For additional inquiries, please contact us at the following link :
http://www.gigabyte.us/support-downloads/customer-service.aspx
GIGABYTE
