- Jun 17, 2002
- Chicago, IL
I have a TRUE HSF on my Core i7 920 with a EX58-UD3R. I turned off Turbo and all the Power Savings and my Vcore is 1.3 with RAM Voltage at 1.64. I turned turning up BCLCK to 165 with a 21x multiplier and I'm hitting 84-85c Celsius on prime.
Yesterday I got the 600T Corsair case and my cables are very neatly managed so it's not a case problem with airflow being blocked. I cleaned out all the dust as I transferred my gear from my Antec 900 to the new Corsair 600T. I have the 120mm blowing air out the back and on the top and the 200mm blowing air in.
As I transferred the gear, I also re-applied AS5 and re-seated my HSF.
Any ideas on what I can try? Seems to be really hot for running such a low overclock. If I put my settings back down to normal with the voltage staying the same, I drop more than 10 degrees Celsius. Running idle I am at about 40c without an overclock.
