- Jul 12, 2011
- UK, Essex, Braintree
First off, Hi everyone, this is my first forum post ever so PLEASE forgive me if I've posted incorrectly.
Next... my system specs
Motherboard: Asus M4A88TD-V EVO/USB3 880G Socket AM3
Processor: AMD Phenom II X6 1100T Black Edition 3.3 GHz 6MB
Graphics: Asus Graphics ATI HD 6850 Direct CU 1GB DDR5
Ram: 4x4GB (16GB) Corsair 1600MHz Vengeance Memory Kit CL9 1.5V
CPU Cooler: Corsair H70 Hydro Series CPU Cooler
Seagate 1TB 7200RPM HDD
Plus other bits of hardware.
Now my problem...
I sadly have a Win+Power 850Watt PSU, it is just a cheap temp... I plan on getting this one very soon Adata HM series 850W 80 plus Bronze PSU.
When I turned my computer on earlier, from what sounded like the HDD came a weird sound, it sounded like the HDD suddenly grew a jet engine and windows (Win7 64bit) took about 5 mins to load to desktop, normally it would only take about <20 seconds. So thinking the HDD was beginning to fail, I shut the sytem off, opened the case, disconnected the fans and restarted.
All seemed fine, so 1 by 1 I reconnected the fans, everything still fine. So once again I shut down the system. Rebooted one again, got the sound from the HDD again but only very mild and for just a quick second and windows started as normal <20 seconds.
Thinking that my HDD was failing, I resounded myself to copying everything over to my external HDD, during this process windows shut off Aero for about 1min and then it came back, so I thought I would have a quick check in device manager, where I discovered that the drive letters to my multi card reader which connects directly to the mobo via a USB header all had caution signs next to them, making the card reader unrecognised.
After I had finished copying everything, I shut down comletely, waited about 1-2mins and powered back onn, everything was fine and still is while I'm typing this information.
I now believe the fault could be the PSU... this will hopefully be changed in about a week.
If anyone has any other ideas PLEASE post back to me.
Thank you
Now my problem...
Thank you
