Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
Beginners: How to set your 25/6/700K to 4.5Ghz
Thread Tools
Old 12-07-11, 11:04 AM Thread Starter   #21
Theocnoob
Theocnoob's Avatar
Quote:
Originally Posted by Brolloks View Post
Pretty decent guide, I would add a disclaimer which include..."Overclocking your CPU reduces the life expectancy of your CPU. This is a guide and does not gurantee any overclocking results.
A good aftermarket air or water cooler is required to reach the CPU speed, a stock cooler will not be effective enough."
I do not feel such a disclaimer is needed. Who still runs a 486 or Pentium 60? Keep in mind we're only talking going from 1.328 or so to 1.35.
I did add a disclaimer, though.
Quote:
Originally Posted by EarthDog View Post
As far as this goes, that person was right, dont use specifics, but then you are too generic. Just a statement along the lines of 'set the 4 major memory timings and voltage manually, such as 9-9-9-24 1.5v (must set to your memories specifications).
I just changed it
What I quoted is an incomplete thought...
I'm still not following you on this virtualization thing. Incomplete how? You're confusing me buddy
__________________
I've forgotten more than I've learned.
Theocnoob is offline   QUOTE Thanks
Old 12-07-11, 07:43 PM   #22
dealmaster
Looks like my CPU just needed a little more voltage to be stable. For I upped it to 1.36 and set LLC to level 1 and it appears to be stable after 20 minutes or so of Prime95. CPUZ is still showing throttling down to 4.2GHz sometimes for some reason, I'm not entirely sure why it is doing that. The cores are hitting a max temperature of 75 but most of the time are hovering around 71-72. Any ideas?
Edit: CPUZ is reporting a Vcore of 1.36v during load. Max multiplier is 45, but right now it is alternating between 4.2 and 4.3GHz. Prime95 hasn't errored yet.
__________________
Gaming Computer:
Intel i5-2500k @ 4.5GHz 1.31v | AsRock Z68 Extreme3 Gen3 | 8GB G.Skill Sniper DDR3-1600 | Sapphire 6950 2GB (flashed to 6970) | Megahalems Rev b w/ Scythe Ultra Kaze 2000 Push/Pull | Corsair HX620 | Fractal XL R2 | Samsung 830 256GB SSD | Seagate 1TB | Samsung 2TB
HEATWARE
dealmaster is offline   QUOTE Thanks
Old 12-07-11, 10:52 PM   #23
dealmaster
Just an update, I found this thread on here:
http://www.overclockers.com/forums/s...d.php?t=692224
And in it, manu2b mentions setting turbo boost power limit to manual, and both short and long duration to 300.
I did just that and suddenly the frequency fluctuation went away. Also, the chip was perfectly stable at 4.5GHz. Currently I have it stressing at 4.5GHz and 1.315v and it's been happy for the past 45 minutes. We'll see how low it can go, but it looks like setting the power limit and the short/long duration did the trick. This would probably be something helpful to put in the main post as it looks to be the solution on other AsRock boards.
Edit: Looks like she was stable for 7 hours at 4.5GHz and 1.305v. It had a rounding error after about 7.5 hours, so I went ahead and increased vcore to 1.31v and called it a day.
__________________
Gaming Computer:
HEATWARE
Thanks!
Theocnoob (12-09-11)
Old 12-08-11, 05:47 PM Thread Starter   #24
Theocnoob
Theocnoob's Avatar
Good job. I'll find a way to work this info in. That's a decent bin CPU you have there.
__________________
Old 12-08-11, 09:35 PM   #25
Rcmorr09
Great topic, and helped me get to 4.5 first try. I did over 3 hours prime and passed 5 runs of intel burn test. So thank you very much.
__________________
I7-2600k with 212 Evo, Asus P8Z68-Pro, Ati 5870, 8 gigs Gskill 1866
124g Crucial M4, 1TB Western Digital Black, Corsair 650w psu and cooler master haf 932 case.
Rcmorr09 is offline   QUOTE Thanks
Thanks!
Old 12-09-11, 12:26 AM Thread Starter   #26
Theocnoob
Theocnoob's Avatar
Quote:
Welcome
__________________
Old 12-09-11, 12:37 AM   #27
pwnmachine
pwnmachine's Avatar
Awesome guide, very easy to follow.
I will definitely be referring many first timers here.
__________________
i5 2500k @ 4.8 gHz. 1.3v..................Q9650 @ 4.0 gHz.
Kingston Hyper 1600mHz 4gb..........XMS3 1600mHz 4gb
Asus P8P67 Pro B3...........................790i Ultra FTW
XFX 5970 BE + XFX 5850..................GTX 260 2xSLI
CM Hyper 212/Thermalright HR-03...Scythe Mugen II
CM Cosmos S Modified......................NZXT H2
Custom Maple Gaming Case
pwnmachine is offline   QUOTE Thanks
Old 12-09-11, 11:32 AM   #28
Lord_of_Decay
Lord_of_Decay's Avatar
Or those returning to the Intel platform.
__________________
Intel i5 3570k
MSI Z77A-GD55
8GB Geil PC312800
MSI R6950 Twin Frozr III
Aircooled with Thermalright Venomous X
Lord_of_Decay is offline   QUOTE Thanks
Old 12-09-11, 09:37 PM Thread Starter   #29
Theocnoob
Theocnoob's Avatar
Quote:
I see you have taken the blue pill this time . Please step up to the mirror. Hehe.
I have worked this info into the guide.
Nice thing to say man
__________________
Old 12-09-11, 10:33 PM   #30
Suppressor1137
So...Here are my results.
Cooler is Xigmatek Gaia and ambient temp is 17.5C
Yes, that is 1.280 you see XD
Temps don't ever go higher than that, This is on maximum heat setting, And same results at the end..Will post more settings after it completes its test.
__________________
CPU:------------Intel Core I5 2500k@4.5 Ghz 1.295Vcore
Motherboard:-MSI Z68A-GD65(B3)
Memory:-------2x4gb G.skill Ripjaws X DDR3 1600 CL8's@ 8-8-8-24
Power Supply:Kingwin Lazer Gold series 850w
Video Card:---Zotac Geforce GTX 460 1GB DDR5 Vram@860/1720/1950
Case:-----------NZXT Phantom Full White
HDD:------------Western Digital Caviar 250GB/Western Digital Caviar Black 1tb
Suppressor1137 is offline   QUOTE Thanks
Old 12-09-11, 11:11 PM Thread Starter   #31
Theocnoob
Theocnoob's Avatar
^Golden chip I think.
You spiked to 1.29 btw Hwmon doesn't lie.
But gold. For sure.
If you still have your box I'm sure everyone wants to know your batch no
You sure you got a firm mount and good tim on that cooler dude? You hit 61. At that voltage?
Seems strange.
__________________
Old 12-10-11, 07:10 AM   #32
Rod911
<picture was here>
Personally speaking, low voltage doesn't always equate to a high multi with some decent voltage through it (my own safety level for testing this is 1.54v). My one is happy to go as low as 1.23v @ 4.5Ghz, but can only get up to 5.3Ghz. Tested this by both trying the multiplier and BCLCK'ing it up to that speed.
ASRock's UEFI/BIOS settings are a cross between Asus' and Gigabyte's. When I was helping a friend overclock his sytem with an ASRock board, the multis were flying all over the place (mostly down). A quick trip to Google sourced the solution.
__________________
||i5 2500K@4.8Ghz[1.325v]|ASUS P8Z68-V Pro Gen3|8GB G.Skill Ripjaws X F3-12800CL8D@1600Mhz[8-8-8-18-1T]|GB GTX670 OC [1241/1606]|240BGB SanDisk Extreme SSD|500GB Samsung|500GB*2 WD (RAID0)|700W Seasonic M12|Dell U2711|Samsung 226BW||
||Cuplex Kryos HF|XSPC RX240|Panaflo FBA12G12H*2|Eheim 1048||||Logitech G510|Logitech MX620||
Rod911 is offline   QUOTE Thanks
Old 12-10-11, 08:12 AM   #33
IJAHman
IJAHman's Avatar
Great post!
__________________
1155 Rig - Asrock Z68 Extreme3 Gen3
i7 2600k @ 4.5Ghz 1.296v - Noctua NH-D14
Gigabyte GTX 560 OC -G.Skill 8gb 1600mhz
Thermaltake TR2 600w - OCZ Vertex 4 128GB SSD
1TB WD Green Caviar - NZXT Source 210 Elite
775 Rig - GA-EP43-US3L - Q8400 @ 3.2Ghz
Themalright HR-02 Macho - Palit GT 430
4Gb DDR2 800mhz Kingston - Thermaltake Xaser III
IJAHman is offline   QUOTE Thanks
Old 12-10-11, 08:43 AM   #34
aaawew
Premium Member #14
EarthDog, do you know if Asus' recommendation extends to AsRock as well? I am having issues getting my 2500k stable at 4.5GHz (it even throttles itself down to 4.2-4.4GHz during OCCT stressing for some reason), it errored out of OCCT after about 20 minutes with LLC set to level 1. I had insane vdroop with it at level 5.
it throttles because of maby LLC of 5 is way undervolting and LLC of 1 is an overvolt on ASRock boards, try LLC of 2 also i havethe throttleing problem and it is easly solved with the C states being disabled i believe
edit: sorry i didnt see someone already answered your question :P
__________________
Desktop: i5 2500k @ 4.2GHz/4.7GHz w/ Cooler Master Hyper 212+ in pull (yea pull it's cooler o.O) //
ASRock P67 Extreme 4 (B3) // Evga GTX 570 SuperClocked // 8GB G.Skill Ripjaws X 1600mhz //
Crucial M4 128GB SSD // 1TB Samsung Spinpoint F3 7200 RPM // Antec 900 two V3 // Corsair HX850W Modular //
aaawew is offline   QUOTE Thanks
Old 12-10-11, 10:36 AM   #35
RollingThunder
Moderating "The Dark Side"
Premium Member #12
RollingThunder's Avatar
When you experienced guys are satisfied that theocnoob's initial post is (mostly) complete we can make this a sticky. It's incredibly helpful to the new and casual OC'ers and it makes an excellent reference to repeat inquiries.
__________________
Intel E8500 @ 3608 MHz...............Intel E7500 @ 3333 MHz Home Server
DFI DK P45 T2RS Plus.................Same
WD Velociraptor 150 & WD Raptor 74...Raptor 74 - WD160
ATI 5750.............................ATI 6200FX
Dell Ultra Sharp 2209WA..............Dell Ultra Sharp 2007 1600x1200
2 x 2 GB GSkill PC8500 @ DDR2 960....2 x 1 GB GSkill PC8500
Corsair HX520........................Corsair HX520
Coolermaster NV 690..................Lian-Li PC-K7
Vista 64.............................XP Pro
There are two kinds of people, those who do the work, and those who take the credit.
Try to be in the first group; there is less competition there.
RollingThunder is offline   QUOTE Thanks
Old 12-10-11, 09:05 PM   #36
dealmaster
As an experience overclocker, but a newbie to the i25/6/700ks, I feel his guide is quite comprehensive. I'm used to the old "increase FSB" way of overclocking, but this guide was very helpful.
__________________
Gaming Computer:
HEATWARE
Old 12-11-11, 10:46 AM Thread Starter   #37
Theocnoob
Theocnoob's Avatar
Quote:
If you (plz?) explained what your solution and issue were a bit more it may help other members with ASrock boards. Cheers.
Quote:
Thanks RT Its almost there just need to work in the 'quirks' of a few brands people have used and I have not ie ASrock. Got one in but there seem to perhaps be others. If you have any input as well I would take it even if you don't run SB
TY!
Yes Dealmaster had a 'max power duration' setting which was off on his board. This is a quirk. ASRock boards, some come with this pre-set. I have not seen it happen on ASUS or Gigabyte.
__________________
Old 12-11-11, 11:27 AM   #38
Suppressor1137
But gold. For sure.
Seems strange.
Good tim=Second best A+ grade TIM According to tests. Gelid Solutions GC-Extreme. As for firm mount...No idea, My first ever install of non stock heatsink...didn't want to tighten too much, for fear of cracking the board. I'm sure i could get another 6 pounds of pressure on it, but it is "good enough" for me.
Voltages are set to 1.305, but only ever pulls 1.28-1.29 according to HWmon, cpu-Z, speedfan, And speccy. I don't complain.
Ran well for the remainder of the tests, max temp was 63c. No Hardware failure detected after 12 hours. So, Its plenty good enough for me XD.
Room temp has since dropped to 14.9c, so I can't run another.
As for the box, I do not. sorry :/
__________________
Old 12-11-11, 12:35 PM   #39
Bobnova
Air Superiority Senior Member
Benching Team Leader
Bobnova's Avatar
Picking some nits: IE means "that is", you want to be using EG, which means "for example".
There's some other grammar stuff as well, but that'll get ironed out by the editors before it hits the frontpage.
Content wise I'm good with it.
Definitely leave the disclaimer in.
__________________
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -- Einstein (maybe)
How to check your PSU with a multimeter.
17bXw5t51rEBXGavJFMJsC8g7HQgThUGc7
Heatware.
Bobnova is offline Author Profile Benching Profile Folding Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 12-11-11, 03:45 PM   #40
exhorder
exhorder's Avatar
For my 2600 the best results for me were to hit my OC Tuner, Go back into bios and change it to 100x45, set my offset to -.010 and Change VRM Frequency to 350. With these settings I vary from .868-1.032 idle to 1.280-1.296v under prime95. Ran this for 3 weeks now. Not as much as a bsod or freeze.
Edit - Batch#3115B989
Edit again. Ill post screenies after I try to get 1.26v ... dropped offset to -.020 and shes running nice.
__________________
Primary
i7 2600-k | Asus P8Z68-PRO/Gen3 | MSI 580 Lightning Xtreme in SLI | HAF 932 Advanced Blue Edition | 8g G-Skill Ripjaws X | Crucial M4 120g SSD | SAMSUNG Spinpoint F3 1TB | SeaSonic Platinum 1000w | Phanteks PH-TC14PE CPU Heatsink
Secondary
q9650 | Evga 750i FTW | BFG 275 GTX | NZXT Case | 4g Gskill | Seagate Barracuda es.2 500g Raid+0 | PC Power & Cooling 750w | Zalman CNPS9700
exhorder is offline   QUOTE Thanks
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
