Notices
Overclockers Forums > Hardware > Video Cards > General GPU
General GPU
Forum Jump
possibly dead gpu?
Thread Tools
Old 02-14-12, 11:32 AM   #21
Frakk
Quote:
Originally Posted by slynutcase View Post
well small update, have been given an hd 6870 to try instead of the gtx 460 which is working fine in an old pc now, but im still getting the same problem but less frequently, yet scince then i have noticed my 12v is sitting really low at 10.8v could this be a hint that a new psu is in order?
It COULD be, read the post above you, can you borrow a PSU to test?
__________________
“The best argument against democracy is a five minute conversation with the average voter.” -Winston Churchill
Frakk is offline   QUOTE Thanks
Old 02-14-12, 11:42 AM Thread Starter   #22
slynutcase
slynutcase's Avatar
i did try it and had no problems but could only use it for couple of hours so no real gameing time to test it, only other psu available at home is a 220w hp one from a few years back, ill get hold of a new psu (thinking of going for corsair tx850m unless anyone has other sugestions) ill try that if no luck then i think me and a few friends will take a day out and test each individual part over at theres.
thanks for the help guys hope ill find the solution soon.
slynutcase is offline   QUOTE Thanks
Old 02-14-12, 11:55 AM   #23
Frakk
You tried with another PSU for a couple of hours and it was fine? if that differs from using your PSU then i would say it is the PSU.
A TX850M is expensive and overkill, with a (real PSU) IE not a $29.99 PSU,- you don't need more then 650W, as a matter of fact that's plenty for your system.
The Crosair TX is a good PSU, and this one @ $40 less than the 850 is more then enough, (750w might be better if you plan on using 2 high end GPU's, there are no real scenarios to warrant 850W)
But if 850W is what you want go for it, i have a 750W XFX PSU and don't need that much power, its just nice to know its there
__________________
Old 02-14-12, 12:06 PM Thread Starter   #24
slynutcase
slynutcase's Avatar
not meaning to go off topic with this post, but would it not be wise to get the 850 corsair to privide headroom for the future as its not a considerable ammount more cost wise?
Old 02-14-12, 12:20 PM   #25
Frakk
That's not off topic , your right yes, its another reason i went for 750W and not 650W, because they have a 5 year warranty, in that thime i might be using more power hungry components at a later date, my PSU will happily power 2 6990's and an FX-8150 on a Croshair formula V MOBO, and so will the TX 750 / 850, which also have a 5 year warranty.
__________________
Old 02-14-12, 12:24 PM Thread Starter   #26
slynutcase
slynutcase's Avatar
good good, well i guess it will come down to how many bills come out of my bank next week, will post back when i have a new psu jus to let ya know how it goes and which one i get, thanks for the info
Old 02-14-12, 12:27 PM   #27
Frakk
__________________
Old 02-25-12, 10:13 AM Thread Starter   #28
slynutcase
slynutcase's Avatar
tohught id update this post as i said i would, turns out its not my psu failing, it was my motherboard lol.. after my last post i added an extra case fan and dunno why but my mobo went haywire then shut off completly and would not power anything except the extra fan i added (and that was spinning really slowly) no cpu fan, no post, nothing, i returned that mobo for a replacement the same, and all is fine now.. thanks for the time and help from you guys.
thought id post to let you know what happend in the end. (the old corsair psu lives to fight another day )
__________________
CPU: I5 3570k de-lidded - 4.5 @1.27v max temp 79c
CPU COOLER: arctic cooling freezer 13 pro
MOBO: Asrock z77 extreme 4
RAM: 8gb corsair vengeance LP @ 1600mhz
GPU: sapphire 7950 boost clock version, stock for now
SSD: samsung 840 250gb
HDD's: seagate barracuda 250gb + 1tb
PSU: corsair tx850m
Old 02-25-12, 10:26 AM   #29
Frakk
Thats great thanks for reporting back.
__________________
Old 03-04-12, 03:14 AM   #30
cyberfish
By the way, baking a card to 350C will most definitely FUBAR it.
Lead-free solder, used in virtually all consumer electronics products nowadays, melt at around 250C. That means, you'll be disconnecting the GPU from the PCB (at that temperature, if you flip the board, the GPU will just fall off), as well as everything else.
When it cools, you'll get a lot of shorts between GPU pins. Soldering a fine-pitched BGA device like a GPU requires precise temperature control (reflow profile) and optical alignment. You can't just heat it up to 350C and cool it down and expect it to work.
__________________
Heatware
Disclaimer: I am a NVIDIA employee, but everything I post here are my personal opinion, and do not represent the views of NVIDIA.
System:
CPU - Intel i5 2500K @ 4.7GHz, cooled by Hyper 212+
Mobo - MSI Z68A-G43 (G3)
RAM - 2*4GB, DDR3-1600
Video cards - 2x GTX 560 Ti SLI
Storage - 128GB Crucial C300 SSD
PSU - 600W Corsair builder series
cyberfish is offline Heatware Profile   QUOTE Thanks
Old 03-08-12, 09:30 AM Thread Starter   #31
slynutcase
slynutcase's Avatar
interestiong point of view, i have never tried baking a gpu and dont plan on, yet many people have posted saying that it has worked for them so i guess its just a gamble that some people are willing to take.
__________________
PSU: corsair tx850m
Old 03-08-12, 10:06 AM   #32
cyberfish
Thermal cycling a GPU can indeed fix (or at least change) things, but definitely not to the solder melting temperature.
I have done it exactly twice with a peltier temperature controller, and from my experience, if you have a flaky GPU, heating it up to 120C, wait a few minutes, then cool it back down, sometimes they will start working again. In both cases, though, the GPU failed again within 24 hours.
__________________
Heatware
System:
Old 03-08-12, 10:13 AM Thread Starter   #33
slynutcase
slynutcase's Avatar
i see so the possiblitys of it working long term are slim, but to the lucky few who have saved themselves abit of cash for few more month's may back the idea, but as iv said before i havent tried it and dont plan on, iv replaced the one that i thought was dead anyway (which turns out it wasnt dead and is running in one of my lesser rigs now lol)
but to have the information is always nice thanks for your time
__________________
PSU: corsair tx850m
General GPU
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
