Notices
Overclockers Forums > Hardware > General Hardware
General Hardware Discuss your new build and gather upgrade suggestions. And if your question doesn't fit anywhere else...it goes here.
Forum Jump
Motherboard assist required
Thread Tools
Old 03-18-12, 10:10 PM Thread Starter   #21
kian525
if i buy all of the parts from the u.s., will it be cheaper, more expensive or about the same?
kian525 is offline   QUOTE Thanks
Old 03-18-12, 10:27 PM   #22
Knufire
Senior Member
Knufire's Avatar
Shipping will make it more expensive. You get pretty good prices in Australia.
__________________
i7-920 3.8 Ghz | Venomous-X w/ Panaflo HS | Sapphire Vapor-X 4890
EVGA X58 SLI LE | 8GB Corsair Vengeance DDR3-1600 | 500GB Samsung OEM | Rosewill 850w | Thermaltake Armor Series | OCZ Vertex 2 60GB
Secondary Rig:
CM Elite 430 | A8-3870K stock | Radeon HD 6670 | 500GB WD Caviar Blue | 4GB G.SKILL DDR3-1333 | ASUS A55
Knufire is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 03-18-12, 11:45 PM   #23
Mjolnir
Mjolnir's Avatar
Buy it from PCCG. Or MSY if you've got one close to you.. That you can drive to. Importing is only worth it for small items. E.G i got a mod on the forums to buy a Crucial M4 128GB for me when it was 130 bucks on newegg; arrived the other day; works like a charm. 150 bucks total with shipping. So was well worth it. Saved a good 50+ dollars. But larger items definitely not worth it.
There's a site called 'Linke'. Look that up. Things like an SSD you could buy from there a little cheaper. They're a fairly major company in Hong Kong. So don't worry about fraud, etc. They're not some crappy little story lol. By major I mean.. It's like PCCG for Hong Kong. Where it's one of the most used e-tailers. But ships worldwide =)
__________________
\m/ OverClockers mATX L33T Club \m/
Motherboard - Asus Maximus Gene V Z77
CPU - i5 2500K @ 4.5ghz 1.3v /w Corsair H60 SE + GT AP-13 /w Scythe Kaze Master Fan Controller (GT AP-13/AP 181)
RAM - 8GB G Skill Ripjaws 1600mhz.
GPU - Asus GTX 670 DCUII
Storage - Samsung 840 Pro 256GB + 2TB Seagate Cuda.
Case - Silverstone TJ08-E
PSU - Corsair HX650
OS - Windows 7 Ult 64
Peripherals - Leopold FC700R Graphite Brown MX + G500 Mouse
Screen(s) - Dell U2711
Audio - Audioengine 5+ + Audioengine D1 + Wharfdale SW150 /w Shure SRH 840 Headphones
Mjolnir is offline   QUOTE Thanks
Thanks!
kian525 (03-19-12)
Old 03-19-12, 05:25 PM Thread Starter   #24
kian525
my laptop is a bit uncooperative atm, so i cant upload a photo of the pccg cart so far. but ill write it here instead.
ASRock Z68 Extreme3 Gen3 Motherboard
Due 21/03/12 $129.00
Microsoft Windows 7 Home Premium 64bit with SP1 OEM
In stock $95.00
Seagate Barracuda 500GB ST500DM002
$75.00
Zotac GeForce GTX 560 Ti 1GB
$229.00
Antec Neo Eco 520C 520W Power Supply
$69.00
Standard ATX Power Cable
$1.50
Intel Core i5 2500K
$215.00
G.Skill Ares F3-1600C9D-8GAO 8GB (2x4GB)
$55.00
Antec Three Hundred Case
$59.00
i really wanted to add a 560 Ti but it pushes the price (incl shipping) too close to $1000. are there any equally powerful graphics cards that are cheaper on pccg? i don't prefer any brand so go wild
Old 03-19-12, 06:09 PM   #25
Mjolnir
Mjolnir's Avatar
The HD 6870 is still a solid Card. . I'd opt for the Antec Three Hundred Two if you can squeeze that it with a HD 6870. the orginal 300 is good. But its aging now and lacks a few features.
Thanks!
kian525 (03-19-12)
Old 03-19-12, 08:45 PM Thread Starter   #26
kian525
Quote:
mmkay, so ill go for the three hundred two case and a sapphire 6870 in each. but what about OEM windows 7? should i get this or not. as you may have noticed, the in tight budget i cant afford proper win 7, so should i get OEM or buy the full version and downgrade the pc further?
Old 03-19-12, 08:48 PM   #27
Mjolnir
Mjolnir's Avatar
OEM is perfectly fine. Forget the full version :P.
__________________
PSU - Corsair HX650
Thanks!
kian525 (03-19-12)
Old 03-19-12, 08:53 PM Thread Starter   #28
kian525
In stock $95.00
$75.00
Sapphire Radeon HD6870 1GB [11179-09-41G]
$175.00
$69.00
$1.50
Intel Core i5 2500K
$215.00
$55.00
Antec Three Hundred two Case
$69.00
+ $58 shipping
cost = $951 AUD
any other places I can shave off a couple dollars?
Old 03-19-12, 09:04 PM   #29
Knufire
Senior Member
Knufire's Avatar
PSU comes with a power cable. xD
__________________
Secondary Rig:
Old 03-19-12, 09:11 PM   #30
Mjolnir
Mjolnir's Avatar
It doesn't Knufire. The Antec Neo Eco series does NOT come with a power cable =).
And yes; there is.
http://www.pccasegear.com/index.php?...ducts_id=18977
Buy 2 of these. For your RAM. That's 14 bucks saved. =).
Heatspreaders are just there for looks. They really aren't required lol.
PS: The Antec Three Hundred two is 79 not 69.. XD. If you wanted; you could look at this. For the 69. Or the Bitfenix Shinobi. For 65. The Sharkoon T9 value cases are decent too; 69 as well.
__________________
PSU - Corsair HX650
Old 03-19-12, 09:24 PM   #31
Knufire
Senior Member
Knufire's Avatar
Never seen that with a PSU before. O.o
__________________
Secondary Rig:
Old 03-19-12, 10:28 PM   #32
Mjolnir
Mjolnir's Avatar
Quote:
Reduce re-use recycle man!! . The idea is that you're replacing an older PSU that already has a power cable.. Part of the "Eco" Naming scheme.. Full of it if you ask me rofl.
__________________
PSU - Corsair HX650
Old 03-19-12, 10:39 PM   #33
Knufire
Senior Member
Knufire's Avatar
Or an excuse to save them the cost of including a cable...
__________________
Secondary Rig:
Old 03-20-12, 12:42 AM Thread Starter   #34
kian525
And yes; there is.
the reason i went for the aeres was that they have a 1600mhz clock speed these two sticks dont though. is there a noticeable difference or is it just a way to hike the price a bit?
Old 03-20-12, 01:42 AM   #35
Mjolnir
Mjolnir's Avatar
Unless you're benching and after specific benchmarks; I can't say there's any real noticeable difference. :P.
__________________
PSU - Corsair HX650
Thanks!
kian525 (03-20-12)
Old 03-20-12, 01:49 AM Thread Starter   #36
kian525
okay ill go for the two sticks of 1333mhz then thanks
Old 03-20-12, 04:57 PM Thread Starter   #37
kian525
updated and slightly cheaper build:
G.Skill F3-10600CL9S-4GBNT 4GB (1x4GB) DDR3
In stock $21.00 $42.00
Antec Three Hundred Two Case
Ships in 24hrs $79.00 $79.00
In stock $129.00 $129.00
In stock $69.00 $69.00
In stock $1.50 $1.50
In stock $75.00 $75.00
Intel Core i5 2500K
In stock $215.00 $215.00
In stock $95.00 $95.00
In stock $175.00 $175.00
Sub-Total: $880.50
Standard Shipping (averages 2-5 days) $59
Total cost = $939.5
okay that is quite impressive, but i cant help feeling if i dont add a 560 ti ill be missing out on better fps. hmmm. ok what could (or should) i downgrade to offset the cost of the 560 ti ($59 extra) i probably will still settle for the 6870 though.
EDIT: just checked out msy and i must say im impressed. but of RAM, which will be compatible with my build http://www.msy.com.au/default.jsp?category=30&page=1
EDIT 2: ok then im not buying msy. just read all of the reviews and i am pretty disgusted tbh.
Old 03-27-12, 08:54 PM Thread Starter   #38
kian525
sorry for attack of the bump thread but the extreme3 gen3 isnt stocked anymore at pccg, any alternatives near the same price?
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
