Hi guys . I have quoted this post from Tom's Hardware, because no one has helped me there, so I really hope I'll get some better support on this forum
Recently I got the HP ProLiant Microserver which I currently use as a workstation. I'm just wondering if the are any possibilities to slightly overclock this machine (I know it's got a passive CPU cooler, but I still want to do it). I have already flashed it with an unlocked BIOS from BIOS-MODS.com, but even in that new BIOS I can't see any OC options (you can grab the rom file from here). Also, it would be nice to be able to control it's fan speed manually (I can see the current RPM in BIOS but can't change it). Here are the full spec (I added to it an aftermarket GPU AMD Radeon HD 6450 512 MB GDDR5). . Thanks in advance .
EDIT: I have to mention that I've already tried Clockgen and SetFSB: CG even didn't load properly (no options - yes, I ran it with administrative rights) and SetFSB (only version 2.3x which is a shareware) read the FSB, but because it is a shareware, I wasn't able to actually set the FSB speed.
