Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
Intel i7 3770K - Ivy Bridge - CPU Review
Thread Tools
Old 04-24-12, 08:26 PM   #141
hokiealumnus
Water Cooled Moderator
Overclockers.com Lead Editor
hokiealumnus's Avatar
77W was confirmed directly from Intel.
hokiealumnus is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-24-12, 08:30 PM   #142
Bobnova
Air Superiority Senior Member
Benching Team Leader
Bobnova's Avatar
Good to know, thanks.
I was hoping it was.
__________________
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -- Einstein (maybe)
How to check your PSU with a multimeter.
17bXw5t51rEBXGavJFMJsC8g7HQgThUGc7
Heatware.
Bobnova is offline Author Profile Benching Profile Folding Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-24-12, 09:29 PM   #143
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
You are right about the power density, I did the math on it as well after posting that - because I assumed it was higher... But really it isn't higher by much. (not enough to explain the temp problems in my opinion, but lack of solder between the IHS would explain it well)
__________________
The OC Forums Way
We are a team. We are a community. We are a fellowship made strong by mutual respect and shared dedication to the task of enriching all who come here.
The OC Forums Thank You Thread
Put your computer to work for our OC Forum Teams!
Try out our POST TEMPLATES, they save you time answering common questions!
I spend half my money on CPUs, GPUs, and Liquid Nitrogen. The other half I waste.
I.M.O.G. is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-24-12, 09:41 PM   #144
Bobnova
Bobnova's Avatar
The non-solder TIM is my bet as well. .43 to .48 is a jump, but it isn't that big.
It also seems like the 3d transistors may leak a lot at higher voltage levels. That was something I noticed with BD as well, at stock volts it ran pretty cool, raise the volts a bit and that changed rapidly. More rapidly than with previous chips I've worked with.
We may be entering an era of heat output not following voltage in the classic way.
If it wasn't a $300 puck I'd rip the IHS off mine when they get here, but as it is I can't really afford to throw $300 out the window. Clearly I can to an extent as I intend to bench the hell out of them, but high voltage and LN2 seems safer than a razor blade.
__________________
Heatware.
Old 04-24-12, 10:02 PM   #145
Audioaficionado
Super Moderator
Audioaficionado's Avatar
10 Year Badge
Well if you kill it fairly soon after you get it, you could just do an autopsy and send out the special sauce for analysis
__________________
.....................................My HeatwareMyFAH Stats
.......................Folding is a marathon, not a sprint © audioaficionado
Asus Commando, 8GB GSkill 5-5-5-15-2t PC6400, Q6600 @3.0GHz >SMP2+GPU3 FAH 24/7
Gigabyte DS3, 3GB GSkill 5-5-5-15-2t PC6400, E6400 @3.0GHz
Asus P5Q PRO Turbo, 4GB GSkill 5-5-5-15-2t PC6400, E6600 @3.0GHz
Iwill DH800, 2GB OCZ4002048PFDC-K 2.5-3-3-8-1t, Dual 2.4 M0 Xeons 1.5v/880/3300
Help improve overclockers.com! Get involved!
You have over 101 posts and Can't see the classifieds???Click This Link
Anyone we catch cookie stuffing at this site will be banned on the spot!!
Audioaficionado is offline Folding Profile Heatware Profile   QUOTE Thanks
Old 04-24-12, 10:04 PM   #146
Bobnova
Bobnova's Avatar
I'll drive up to medford and borrow yours
Need to go up there and hit the kart track again someday anyway
__________________
Heatware.
Old 04-24-12, 10:08 PM   #147
wingman99
wingman99's Avatar
Did SB have solder between the IHS? I now see that there is higher power density by a little, however intel says IB runs cooler stock and we know at stock it uses less watts than SB.
Matt i hope intel will talk with you about the overcloking with excessive heat being generated needing excessive cooling.
EDIT my sandy bridge runs so cool and fast compared to 45nm core2 quad and IB seem like a big step backwards for air cooling.
__________________
i5 2500K @5.0 GHz
Motherboard Gigabyte Z68A-D3-B3
G.SKILL RipjawsX X.M.P. 1600MHz
EVGA SuperClocked GTX 570
SOLD Ivy bridge i5 3570k
wingman99 is offline   QUOTE Thanks
Old 04-24-12, 10:37 PM   #148
muddocktor
Retired
muddocktor's Avatar
10 Year Badge
I can think of a couple of reasons why Intel might have gone back to the traditional TIM between the IHS and slug (if they did so).
1. No competition from AMD, meaning that they didn't need any higher ambient overclocking than they already have with SB for enthusiasts that don't go cold. Let's face it, nothing AMD is producing can hang with a 2600k, much less IB.
2. More profits. Smaller cores, more good dies per wafer and money savings by using a cheaper IHS>Core bonding process, offset just a little by slightly more expensive wafers=insane profits for Intel.
muddocktor is offline Author Profile Benching Profile Folding Profile SETI Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-24-12, 10:59 PM   #149
Bobnova
Bobnova's Avatar
TIM is far cheaper than the specialized solder they were using. Even high end TIM.
I bet it saves a decent amount per chip in time and heating too.
They split the 775 stuff, e7xxx and lower were TIM, e8xxx and higher were soldered.
P4s were all soldered, they were too hot not to be.
__________________
Heatware.
Old 04-25-12, 12:03 AM   #150
JigPu
Inactive Pokémon Moderator
JigPu's Avatar
10 Year Badge
Great article The power figures are impressive, but I'm still happy with my Sandy Bridge system. Undervolting the chip, I can run 24/7 at full load with my fans inaudible and still have reasonable temperatures.
Quote:
Originally Posted by Bobnova View Post
Regardless of the scale used you cannot accurately use any method to estimate your eventual temps without knowing the ambient.
If you know your ambient, hokies ambient, and your SB core temps you can estimate your eventual IB core temps using his percentile just fine. Alternatively you can simply look at the degrees over ambient (in C) and estimate that way. Both ways will work fine, neither will be exactly accurate unless you have the same cooler and fan of course.
This.
If you want to indicate a the difference in terms of percent, do it on deltaT, not T itself. In addition to being a more meaningful statement, it has the nice property of being applicable to *any* unit: if your deltaT doubles in Celsius then it also doubles in Fahrenheit.
JigPu
__________________
.... ASRock Z68 Extreme3 Gen3
.... Intel Core i5 2500 ........................ 4 thread ...... 3300 MHz ......... -0.125 V
2x ASUS GTX 560 Ti ............................... 1 GiB ....... 830 MHz ...... 2004 MHz
.... G.SKILL Sniper Low Voltage ............. 8 GiB ..... 1600 MHz ............ 1.25 V
.... OCZ Vertex 3 ................................. 120 GB ............. nilfs2 ..... Arch Linux
.... Kingwin LZP-550 .............................. 550 W ........ 94% Eff. ....... 80+ Plat
.... Nocuta NH-D14 ................................ 20 dB ..... 0.35 C°/W ................ 7 V
"In order to combat power supply concerns, Nvidia has declared that G80 will be the first graphics card in the world to run entirely off of the souls of dead babies. This will make running the G80 much cheaper for the average end user."
"GeForce 8 Series." Wikipedia, The Free Encyclopedia. 7 Aug 2006, 20:59 UTC. Wikimedia Foundation, Inc. 8 Aug 2006.
JigPu is offline   QUOTE Thanks
Old 04-25-12, 06:48 AM   #151
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
Secret Sauce Revealed: Looks like non-solder TIM to me (Thanks to pt1t):
Now, let's refer back to the recent past (thanks to Muddocktor), the E6XXX series of Conroe chips were much easier to cool compared to the E4XXX series. The original Conroes used the bonded TIM, and the E4XXX series used the traditional TIM.
__________________
The OC Forums Way
Thanks!
EarthDog (04-25-12), hokiealumnus (04-25-12), Janus67 (04-25-12), rge (04-25-12)
Old 04-25-12, 07:09 AM   #152
rge
Senior Member
rge's Avatar
Well that settles that question, thanks for posting that.
Also the E7200 (which had paste) had higher core temps and also had more issues with higher temp differences between cores than soldered counter parts.
Makes direct die cooling attractive again, well except the issues with increased risk of mobo/cpu shorting from having to alter/remove cpu socket and suboptimal contact between cpu and mobo. Good for testing, more risky for 24/7 use.
I wonder if could get ahold of any solder attach or newer die attaches, some 2x higher thermal conductance than indium solder, indium graphene 160 w/mk vs solder 80 w/mk. But my guess is none would sell 1-2 units.
Either that or new direct die waterblock sold with new socket attach
__________________
IVY 3770K 4.7ghz, 1.31v, water/EK sup hf
GB Z77 UD5
GTX 680, water/hydrocopper
360 + 280 rad for gpu/cpu
Intel 520 SSD 240gb
Corsair Dom Ram 1866
Corsair HX850
rge is offline   QUOTE Thanks
Old 04-25-12, 07:37 AM   #153
hokiealumnus
Quote:
JigPu
Thank you for that; and you're absolutely correct. Ambient was very close to the same between the two within two degrees Celsius. I'm kicking myself for not measuring when I took it, but that room stays very close to 23°C, ticking a degree or two one way or the other (except in the middle of summer, when it can heat up more). Kicking myself for forgetting to actually measure the temperature. I guarantee ambient temps were within two degrees of each other though.
__________________
Enjoy benchmarks? Join the benching team! | New to water cooling? Read the Beginner's Guide to Water Cooling Your PC.
xsuperbgx - "As a wise man once said: "Less talky. More clocky."" | cyberfish - "When overclocked, it's undefined behavior."
I.M.O.G. - "Vaseline on Ivy Bridge is a bad idea. But not so bad of an idea that it can't be fixed with a torpedo heater, a dishwasher, an oven, and a few hours. "
\m/ OverClockers mATX L33T Club \m/ - Join Now! - My mITX Build
Old 04-25-12, 10:21 AM   #154
Audioaficionado
Super Moderator
10 Year Badge
Looks like you would want to mount the board so this delidded processor lays flat and the heat sink will be sitting on top rather than hanging off of it.
__________________
Old 04-25-12, 10:33 AM   #155
Bobnova
Bobnova's Avatar
Pretty bad contact there too, looks like there was a gap all the way around that was filled with TIM.
__________________
Heatware.
Old 04-25-12, 10:40 AM   #156
Frakk
Bobnova... yeah.
That TIM looks pretty think between the DIE cap and the Heat Spreaders contact plate.
Is there any sort of contact between the two or is it a gap filled with TIM?
I would not like to see anywhere near that much TIM between the Heat Spreader and the CPU cooler contact plate when i occasionally pull it off to reapply.
I would wonder WTF i was thinking the last time i applied.
__________________
“The best argument against democracy is a five minute conversation with the average voter.” -Winston Churchill
Frakk is offline   QUOTE Thanks
Old 04-25-12, 10:44 AM   #157
Bobnova
Bobnova's Avatar
The reality of modern TIM is that you cannot put too much and have it cause temp issues. Modern TIM thins under heat and squishes out the side. You can put too much on and have an entertaining cleanup time. You can put too little on and have temp issues. Too much? No.
If there is a gap with TIM in it, it means that the two surfaces mechanically cannot come closer together, the TIM will not stop them from getting closer if other factors allow it.
__________________
Heatware.
Old 04-25-12, 10:47 AM   #158
Janus67
Wannabe Admin Senior
Janus67's Avatar
So basically ideally we wouldn't see any TIM on the die/heatspreader area then if it was making perfect/near-perfect contact?
__________________
Ivy Bridge Benching and Gaming: Asus Maximus V Extreme 0010 BIOS : Intel i7 3770k w/ Phanteks PH-TC14 : 8GB 2x4GB G.Skill TridentX DDR3-2666 : MSI 7970 Lightning Edition
Other Benched Hardware: GA-EX58a-UD3R; Rampage Extreme; Rampage Formula; GA-EP45-UD3R; P5K-Deluxe; MIVE -- 2500k; 2600k; 920; E6300; E6550; E6600; E8400; Q6600 -- 6950; 4870; 8800GTS
Other Components: Crucial M4 128GB SSD : 2x1TB Samsung F3 in Raid0 : Silverstone Strider Gold 1250W : Auria EQ276W 27'' & Dell 2407FPW : KPC Tek9 Fat and Gemini LN2 Pots
Folding User Stats
Janus67 is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-25-12, 10:48 AM   #159
bmwbaxter
Premium Member #5
bmwbaxter's Avatar
I hope this is only going to be an issue with review samples and ES chips. Hopefully retail will fair much better.
The contact between core and IHS is horrible! No wonder temps are so bad.
bmwbaxter is offline Author Profile Benching Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-25-12, 10:53 AM   #160
Bobnova
Bobnova's Avatar
We'd see a very thin fairly translucent layer, rather than the thick opaque one shown.
__________________
Heatware.
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
