Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
Ivy Bridge Temperatures - It's Gettin' Hot in Here
Thread Tools
Old 04-25-12, 09:43 PM   #41
I.M.O.G.
Homeless Leader
I.M.O.G.'s Avatar
10 Year Badge
Quote:
Originally Posted by Eldonko View Post
Im sticking with the power density theory myself.
Why? Color me curious.
__________________
The OC Forums Way
We are a team. We are a community. We are a fellowship made strong by mutual respect and shared dedication to the task of enriching all who come here.
The OC Forums Thank You Thread
Put your computer to work for our OC Forum Teams!
Try out our POST TEMPLATES, they save you time answering common questions!
I spend half my money on CPUs, GPUs, and Liquid Nitrogen. The other half I waste.
I.M.O.G. is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-25-12, 10:01 PM   #42
rge
Senior Member
rge's Avatar
power density plays a role, trigate, and solder vs tim would play a role, only issue is how much for each.
But regarding wattage earlier post between sandy and ivy, you cant go by total watts dissipated to figure difference in core temps when comparing across a die shrink, even though total heat output the same, what matters is power density, ie power per cm2, and only the area/size where power is actually consumed or heat "originates" matters.
150 watts consumed over a large area, the temperature would not be very hot.
150 watts consumed in a .001 micron area would exceed temp of a nuclear reactor.
See intels slide that everyone uses when explaining power density increase with die shrinks. Same wattage originating from smaller area = higher core temps.
__________________
IVY 3770K 4.7ghz, 1.31v, water/EK sup hf
GB Z77 UD5
GTX 680, water/hydrocopper
360 + 280 rad for gpu/cpu
Intel 520 SSD 240gb
Corsair Dom Ram 1866
Corsair HX850
rge is offline   QUOTE Thanks
Old 04-25-12, 10:22 PM   #43
Eldonko
Revolutionary Mule
Eldonko's Avatar
The heat only makes sense, increase the transistor count from 1.16 billion on SB to 1.4 billion on IB and shrink the die from 216mm2 to 160mm2. That and I have confidence that Intel knows what they are doing with TIM..
Quote:
__________________
Motherboard Reviewer at Hardware Canucks
Team OCX Bench Team
Always lurking the motherboard section
Eldonko is offline   QUOTE Thanks
Old 04-25-12, 10:23 PM   #44
vargis14
sabotage i say:) by intel
I believe intel used the paste as a kind of thermal resistor so ivy bridge cpus will not hit 6+ghz on a good air cooler or a decent AIO water cooler.Combine the 25% smaller die and the paste and they take away 6+ghz
So many Sandy bridges can hit 5+ ghz on affordable cooling.
If almost every 22nm IBk model can hit 6ghz + like the sandys hit 5+ghz it would hurt Intels sales of 6 core SB-E platforms and cpus when you could get the same or even better performance with a 6+ghz IVY
I think the new coolermaster 812s heatpipe/vaporchamber heatsink will let that naked IVY hit 6 ghz maybe more since the bus can almost pass 110mhz add ivys improved memory controller and i think 6000mhz on air
All you need to protect the die is maybe the old amd barton style hard rubber bumpers on all 4 corners or even a ATI/AMD GPU trim ring.Those chips are not cracking.One of those ideas,or a better one is all that is needed to keep the coolers/block from tilting and cracking the chip.
You can use a razorblade and a light to make sure the die is flat and does not have any high spots on the corners and edges.If you do find a high corner i am sure you could carefully shave it with a fine razor.I have seen cracked chips still work so i don't think shaving a minute high spot would hurt a thing.
Get that naked IVY chip in a motherboard and post the oc/temp/voltage results please.BTW i salute the person who found that poison under the IHS 6ghz on air baby i can feel it!!!!!!
vargis14 is offline   QUOTE Thanks
Old 04-25-12, 10:26 PM   #45
Eldonko
Revolutionary Mule
Eldonko's Avatar
Lol if someone does 6Ghz on air because they removed the IHS Ill eat my friggin hat.
__________________
Team OCX Bench Team
Old 04-25-12, 10:44 PM   #46
wingman99
wingman99's Avatar
Looking at the chart the power density went up on the core 2 Duo however the power of CM2 went down is this because of critical dimension and what is that?
__________________
i5 2500K @5.0 GHz
Motherboard Gigabyte Z68A-D3-B3
G.SKILL RipjawsX X.M.P. 1600MHz
EVGA SuperClocked GTX 570
SOLD Ivy bridge i5 3570k
wingman99 is online now   QUOTE Thanks
Old 04-25-12, 10:57 PM   #47
I.M.O.G.
Homeless Leader
I.M.O.G.'s Avatar
10 Year Badge
Thanks.
I also have confidence that Intel knows what they are doing with TIM. I also have confidence that every solution they choose is a balance between what is technically ideal and what is realistically appropriate. They could give us 6GHz on air processors by the end of the year - they have the resources skills, and ability to execute. I don't doubt at all that it could be possible if they dumped enough money into achieving that goal - but maybe they won't do that because making it a reality is too expensive, difficult, or otherwise bad for business.
If using an inferior TIM is sufficient and cheaper/quicker/easier/etc... Despite knowing a different solution would keep things cooler, I could see how they could make a decision to use an inferior cooling solution that was good enough due to balancing priorities.
The 6GHz thing is only intended to draw out a point. What they could do, what is best, and what they actually do can very realistically be different things. And if they are different, it isn't because they are dumb.
__________________
The OC Forums Way
Old 04-25-12, 11:03 PM   #48
vargis14
What kind of sauce would you like,honey mustard,sweet and sour or just plain old ketchup replace popcorn with hat please.
I do have high hopes, unfortunately i am not wealthy.But if i was you better believe i would be on it like a fly on doo doo.
I think that paste slows heat dissipation a great deal.CPU die to paste of unknown origin and properties to IHS to paste to heatsink.3 layers of stuff before it touches the heatsink.
I just really have a gut feeling intel made a cpu a little faster then they planned on and that secret sauce will remove SB stockpiles quickly,also aiding in SB-E platform sales.
SB-e has a place for super memory intesive stuff workstation quad sli etc.
But with IVYs potential raw cpu power PCIe3.0 I mean who will need 4 video cards when the dual gpu 690s and AMDs 7990 come out.BTW i prefer the new NV cards
I.M.O.G. i know intel is not dumb they are a powerhouse with no competition.So they use tactics to sell older cpus.If that means crippling a super fast cpu just enough to make it slightly faster then its older brother at identical clock speeds but wont break 5ghz without extreme cooling is good for business.They clear inventory etc.
Good luck to the first naked IVY cpu!!!!
Old 04-25-12, 11:07 PM   #49
wingman99
wingman99's Avatar
LINK: http://www.anandtech.com/show/4830/i...ture-exposed/1
QUOTE: Intel hasn't announced die size but transistor count has increased to approximately 1.4 billion (layout). This is up from 1.16 billion in Sandy Bridge, a 20.7% increase. With perfect scaling a 22nm Sandy Bridge die would be 47.3% the size of a 32nm die. Even with the increase in transistor count, it's a good bet that Ivy Bridge will be noticeably smaller than Sandy Bridge.
A good percent of the transistors go to the GPU and the CPU portion of the chip did not go through much change from SB it is a TIC, however they added greatly to the GPU transistor count in IB. intel wont give out the split in the transistors CPU and GPU.
__________________
i5 2500K @5.0 GHz
Old 04-25-12, 11:11 PM   #50
Eldonko
Revolutionary Mule
Eldonko's Avatar
Thanks.
Not saying you are wrong, that could very well be the case m8 (or part of it at least), Im just saying that in my opinion the chip architecture would have a lot more of an effect on temperatures than the TIM used. Moore's Law, die size, transistor count, tri-gate, and so on.
I guess this will be proven or disproven as soon as someone removes their IHS and overclocks the chip. I have my $ on a few C less and a few more Mhz same as any other IHS-less chip. Ocers are a curious bunch so we will see this sooner rather than later. It is not gunna be me though lol
__________________
Team OCX Bench Team
Thanks!
I.M.O.G. (04-25-12)
Old 04-25-12, 11:19 PM   #51
dejo
Senior Moment Senior Member
dejo's Avatar
10 Year Badge
I still see no reason for Intel to choose TIM over solder, other than dollars. I also think that most that are willing to pay for the top offering of a specific family- would also be willing to spend a few dollars more to be the best that product "could" be. Bring on 2600k price, but also bring back the solder, and let us see what "should" have been
__________________
if it screams, crank it. if it cries, kill it
Asrock z77 ex6
2600k @4.8ghz
Samsung 2x4gb rams
OCZ Vertex4 256gb ssd
EVGA GTX480
Sparkle 1250 gold PSU
Arc Midi case
dejo is offline   QUOTE Thanks
Old 04-26-12, 01:43 AM   #52
Krazy931
just confused on the whole people saying intels trying to sell the rest of their sandy bridge when that is not the case at all theres a very precise way things are done when new things are coming out and normally the manufacturer holds very little of their own product it would be people like newegg tigerdirect etc.... that would have the stockpiles of extra chips not intel so im sorry you guys can throw that thought into the trash
Krazy931 is offline   QUOTE Thanks
Old 04-26-12, 03:38 AM   #53
txus.palacios
Premium Member #18
txus.palacios's Avatar
Can't understand this movement from Intel. OK. You have no competition. But normal OCers (not LN2 benchers) will not buy your "k" chips.
I will stick with the 2500k or grab a i7 SNB if I find it cheap, if the temperatures get as high as that just because you decided to save a few bucks using TIM instead of solder.
__________________
Maximus V Gene | i5-2500k 4.8GHz (ekHF) | 16GiB | GTX470 SLi @ 800MHz (ekFC) | m4 128GB | T50-RP | Arch Linux + Windows 8 Pro | gaming
P67 Extreme4 B3 | i3-2120T 35W 2.6GHz | 32GiB | ZFS - zRAID1 2TB | VMware vSphere (ESXi) 5.1 | server
Samsung RC520 | i5-2410M 2.3GHz | 4GiB | HD3000 + GT520m | 320GB | Arch Linux | laptop
[ more info about my systems... ]
The only sound I want to hear out of my computer (unless I'm gaming or watching a movie) is the hum of my 6000 rpm fan pushing air through my heatsink. - Seebs
If I turn up dead, somebody make sure they put "should have just benched in the cold" on my tombstone, along with my most recent superpi32m score. - I.M.O.G.
I didn't go water-cooling for an air-cooling Vcore!! - bluezero5
I'll rm -rf /yourface/* - thideras
txus.palacios is offline Benching Profile Folding Profile   QUOTE Thanks
Old 04-26-12, 05:20 AM   #54
rge
Senior Member
rge's Avatar
If it were cheaper to use solder, the cheaper E7200 etc would also have solder like e8400 instead of non-solder/paste die attach, but they dont. So definitely agree with non-solder/paste being cheaper, and intel saving money when die attach on a particular cpu doesnt require solder when used as intended by intel.
Also possible, if intel thought trigate was going to lower voltage, then only later in design realized wasnt the case, perhaps that played a role in die attach choice. Or the fact that at stock setting, non-solder attach works fine with Ivy.
As IMOG pointed out, intel clearly has the ability to design for overclockers, but the future isnt overclocking, it is mobile, less power hungry platforms, and intel isnt designing chips for us few that push way more volts through to overclock, but for the masses.
No one is saying intel doesnt know what they are doing, we are simply acknowledging intels needs and overclockers needs may not always be the same.
__________________
GB Z77 UD5
Intel 520 SSD 240gb
Corsair HX850
Old 04-26-12, 05:22 AM   #55
Zarck
Zarck's Avatar
Arrow
Nothing beats the molecular bonding,
http://www.linguee.fr/francais-angla...E9culaire.html
Zarck is offline   QUOTE Thanks
Old 04-26-12, 05:58 AM   #56
lance-M
lance-M's Avatar
Talking Thanks for the effort.
very good info..seems to match up with other sites around the planet on this issue..heat and chips. but this is the 1st forum to actually find a reason for it.
thanks again for the info..
lance-M is offline   QUOTE Thanks
Old 04-26-12, 06:24 AM   #57
evangelionstar
Question
Question is: is this an issue limited only to the engineering and early release samples OR does it also affect the retail versions of the 3770k that will be released in 3days?
Has anyone read or perhaps suggested it to those lucky ones around the net that have actually gotten their hands on full retail kits?
These chips have been available for a while now in China and a couple of days in Norway, Hollands, Germany etc
evangelionstar is offline   QUOTE Thanks
Old 04-26-12, 06:30 AM   #58
EarthDog
Senior PITA Member
Overclockers.com Editor
EarthDog's Avatar
I dont think anyone is sure as I believe, but not sure, that review samples were all ES. We have a couple days to find out though.
Not sure if a retail one has been delidded.
__________________
"We have more information and more ways of accessing it than ever, yet seem increasingly less inclined to do so."- Michael Wilbon
EarthDog is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-26-12, 07:00 AM   #59
wagex
Premium Member #13
wagex's Avatar
welp only one way to tell, who has the classified chip? tell them to pop off the lid and attach a heatsink right on the die and see what happens lol
__________________
rig-NZXT source 210 elite --serv-- generic rack mount---------------htpc-apex htpc case
2500k 4.5ghz 1.3v------------------ 2x e5345 xeon quad--------------------e6600 @ 3.0ghz
p67-ud4 ------------------------------ s5000pslsata --------------------------- gigabyte g41
8gb gskill 2x4 1600 --------2x2gb samsung ddr2 667 fbdimms-----------2x2b ddr3 1600
6950 dirt 3 edition ----------------- onboard -----------------------------------HD 5450
corsair hx850-------------------------ocz 700w----------------------------------275w came with case
custom loop --------------------------771 stock heatsinks---------------------xigmatek durin
win 7x64------------------------------server 2008 r2 enterprise--------------win 7 64 bit
steam user name : Wagex (you happy bro?) HEAT
"You can't get magical Harry Potter temps with big overclocks, PHYSICS has a lot to do with it." -conumdrum
wagex is offline Benching Profile SETI Profile Heatware Profile   QUOTE Thanks
Old 04-26-12, 07:45 AM   #60
hokiealumnus
Water Cooled Moderator
Overclockers.com Lead Editor
hokiealumnus's Avatar
Just for reference, here is what a soldered die looks like de-lidded.
Image courtesy BlindFreddie @ XS.
__________________
Enjoy benchmarks? Join the benching team! | New to water cooling? Read the Beginner's Guide to Water Cooling Your PC.
xsuperbgx - "As a wise man once said: "Less talky. More clocky."" | cyberfish - "When overclocked, it's undefined behavior."
I.M.O.G. - "Vaseline on Ivy Bridge is a bad idea. But not so bad of an idea that it can't be fixed with a torpedo heater, a dishwasher, an oven, and a few hours. "
\m/ OverClockers mATX L33T Club \m/ - Join Now! - My mITX Build
hokiealumnus is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Tags
ivy bridge
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
