Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
Ivy Bridge Temperatures - It's Gettin' Hot in Here
Thread Tools
Old 04-26-12, 10:40 PM   #101
wingman99
wingman99's Avatar
10 Year Badge
__________________
i5 2500K
Motherboard Gigabyte Z68A-D3-B3
G.SKILL RipjawsX X.M.P. 1600MHz
EVGA SuperClocked GTX 570
wingman99 is offline   QUOTE Thanks
Old 04-26-12, 11:13 PM   #102
Aynjell
I don't think beheading is even an option with the retention mechanism, is it?
__________________
Do not break wind in the same room as a dark brother or sister; to do so is to invoke the wrath of Sithis. - Aynjell, in fond memory of Lucien LeChance
Aynjell is offline Author Profile   QUOTE Thanks
Old 04-27-12, 12:39 AM   #103
dtrunk
dtrunk's Avatar
microscopic stress cracks in the Indium soldier based TIM... mayb this is the issue. Though this article seems a little old to be relevant to a 2012 launch. I could see how striving for "uniform" heat dissipation and heat cycle stress cracks of the STIM could push intel to use simple TIM this go around. I still hope they revise this asap for future batches.
Nice post on the intel link, good reading just for fun.
__________________
CASE: HAF - X BUILD PICS
PSU: Cooler Master 850W Silent
CPU: Intel i5 3570k @ 4.0ghz 1.17v
Custom Water Cooling Loop - XSPC RX360 w/ Swiftech Helix 120s Pull- Alphacool Monsta 140 w/ 2x Bgear Blaster 140 push/pull
- EK Suprm HF CPU Block - XSPC RezTop on MCP350 pump -Tubed in Black n coiled in RED
GPU: EVGA GTX680 HydroCopper @1201 GPU / 6110 Mem
MOBO: ASRock Z77 Extreme4
MEMORY: Corsair Vengeance 2x4GB DDR3 @ 2133 9-11-10 1.5v
HD: OCZ Agility3 SATAIII 120gb : 3TB 7200rpm SATAII 64mb cache
dtrunk is offline Benching Profile Folding Profile   QUOTE Thanks
Old 04-27-12, 03:54 AM   #104
odin_611
Intel pulling a fast one.
Perhaps it's to try and subdue overclocking long enough for intel to milk Ivy Bridge for better performance values in later models. Same processor, release it 8 times, minor tweaks to the first 4 then for 5-8 solder instead of TiM and add a major off the shelf performance boost to the late models. Ahhh good old intel :P
__________________
Entry level OCing setup:
Apevia XTrooper Jr (5 Case fans plus Rad Fan)
Biostar G41D3+ (Rev 6.3)
Intel LGA775 Pentium D820 Smithfield (Stock 2800Mhz, highest clock so far: 3560Mhz... Can go higher)
Gskill 2x4GB F3-8500 DDR3-1066Mhz RAM
Corsair H40 Closed system cooler with Nidec Beta V 130CFM Push Fan
Zotac GeForce GT440
Enermax 350W PSU (I have a 450W as well but I'm waiting until I need it before unboxing)
I know this setup is pretty low-end, but I'm not gonna cry if the whole thing goes pop. =]
odin_611 is offline   QUOTE Thanks
Old 04-27-12, 05:01 AM   #105
rge
Senior Member
rge's Avatar
@wingman99, yes page 10 if going by pdf page counter, though page 9 is printed on that page, since page 9 of the article. Debated whether to say page 9 or 10, wasnt sure which would make more sense.
@dtrunk, they test each cpu, and they worked out voids a long time ago. Just posted this to show the thermal conductivity of intels indium solder die attach, 87 w/mk and melting temp 157C.
__________________
4790K 4.7ghz, 1.28v, Koolance 380I wb
GB Z97 UD5h
GTX Titan, water/hydrocopper
360 + 280 rad for gpu/cpu
Sandisk Extreme Pro 480gb
Corsair Dom 2400 10,12,12
Samsung 27 inch 1440
Corsair HX850
rge is offline   QUOTE Thanks
Old 04-27-12, 08:51 PM   #106
mjw21a
mjw21a's Avatar
Looks to be an artificial barrier then. Does it surprise anybody that Intel would do this when they're ahead of AMD performance wise? If AMD catch up we'll probably see them go back to a soldered IHS and boom, their back in front again. Due to a new and improved IB
__________________
CPU & HSF: AMD FX-8120 & Noctua NH-D14
Mobo: Asus M5A97-EVO
RAM: 16GB (4Gx4) DDR3 2133 G.Skill RipjawZ F3-17000CL11Q-16GBZL
Storage: 1x 120GB OCZ Vertex II SSD, 1x 250GB Samsung 830 SSD, 1x 1.5TB Samsung Silencer Series HDD
GFX: 4GB Gigabyte ATI R9 270X OC Edition + Yamakasi Catleap Q270 SE 27" IPS LED LCD
Audio: Asus Xonar DX, Senheiser CX270 earbuds + UltraDisk 4016 Condenser Lavelier Microphone
Case & Lighting: Silverstone Temjin TJ04-E w/ Side Window + Red CCFL's
PSU: 550W Antec EarthWatts Platinum
My rig piccies & links
"Under democracy one party always devotes its chief energies to trying to prove that the other party is unfit to rule - and both commonly succeed, and are right." H.L. MENCKEN
mjw21a is offline   QUOTE Thanks
Old 04-27-12, 08:55 PM   #107
ghost_recon88
Senior Jedi Master
Premium Member #9
ghost_recon88's Avatar
Interesting, removing the IHS apparently did not help with temps at all.
http://www.overclock.net/t/1249419/p...ed-without-ihs
ghost_recon88 is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 04-27-12, 09:11 PM   #108
mjw21a
mjw21a's Avatar
^^^ Hmmm, very interesting.... Will have to see how the final retail products are on heat. If these chips remain hot then I suspect my next chip will definitely be Piledriver....
__________________
Old 04-27-12, 09:20 PM   #109
dejo
Senior Moment Senior Member
dejo's Avatar
10 Year Badge
Kyle, the test that you linked to is likely to have issues with mounting pressure when giving up the thickness of the IHS and a mount intended for used with a given thickness chip (chip with IHS-in this instance). would guess it had very low mounting force which could change temps for the worse very easily
I would trust a scenario much more with just having a mounting system that went through the mobo to mount the hsf or waterblock. and at least having a chance to get good pressure on the chip
__________________
if it screams, crank it. if it cries, kill it
Asrock z77 ex6
2600k @4.8ghz
Samsung 2x4gb rams
OCZ Vertex4 256gb ssd
EVGA GTX480
Sparkle 1250 gold PSU
Arc Midi case
dejo is offline   QUOTE Thanks
Thanks!
I.M.O.G. (04-28-12)
Old 04-27-12, 09:22 PM   #110
wingman99
wingman99's Avatar
10 Year Badge
That's what i believed also, we will have to see more testing to confirm it.
So it's back to TRI-gate and power density
__________________
i5 2500K
Old 04-27-12, 09:30 PM   #111
xsuperbgx
Benching Team Leader
xsuperbgx's Avatar
I don't think that the cooler used is meant for use on a cpu without heatspreader. I think it needs a little more mass at the base to distribute the heat to all of the heatpipes.
__________________
Come join in on the benchingmarking fun! Competitions, contests, prizes. + Learn tips and tricks to get a better score.
SteamOS || Woomack's memory test list. || Compare your 4Ghz Spi32m score. || Mining efficiency.. || Set up a benching OS. || Get Cold. || You can bench your Raspberry Pi.
Join us in the "OVERCLOCKTAGON"!!!
LTC "LQPgAb7jbtYEzi6W9hnXsS4Xi3RLN7NDgu"
heat
xsuperbgx is offline Benching Profile Folding Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-27-12, 09:39 PM   #112
diaz
diaz's Avatar
Quote:
That too, but I think its fine because it doesn't have bare heatpipes. The cooler is not the problem, at this point it is mounting pressure. The fact that the temps went UP when ISH was removed, means there is at least some pressure problem. This can be easily verified by applying pressure on the cooler while maintaining counterpressure on the backplate.. using a hand /(or screwdriver while watching the temperature difference (in small increments) as pressure if mounting allows for more tightening headroom) is gradually applied. This way a knee temperature could be found depending on pressure mount.
__________________
\m/ OverClockers mATX L33T Club \m/ >>>JOIN NOW<<<
Main Rig
i5 3570k
EVGA GTX 680
Asus Maximus V Gene mATX
Silverstone TJ08E mATX
16G Corsair Vengeance
Corsair H80
Silverstone Strider Plus 850
Crucial M4 256G SSD // Seagate 750G 7200.12 Storage
Recommended PSU's - True/Tested/***/Intel C2D/Q/X Thermal Designs Explained
Heatware
diaz is offline   QUOTE Thanks
Thanks!
I.M.O.G. (04-28-12)
Old 04-27-12, 09:42 PM   #113
ghost_recon88
Senior Jedi Master
Premium Member #9
Good points, who here is gonna be the guinea pig that takes their IHS since I know you guys have good mounting setups
Old 04-27-12, 09:47 PM   #114
MattNo5ss
5up3r m0d3r4t0r
Overclockers.com Editor
MattNo5ss's Avatar
Quote:
What about a Venomous X with its variable pressure knob? Sounds like it may be a good heatsink for testing direct die cooling, once it's lapped to be sure it's flat as possible to match the die.
__________________
i7 3770K | ASUS Maximus V Gene | 4x4GB G.Skill Ripjaws DDR3-1600 9-9-9-24 | EVGA GTX780 SC ACX | 256GB OCZ Vertex 4 | SeaSonic SS-1000XP
My Overclockers.com Articles | HWBot Profile | Heatware (98-0-0)
Projects: Copper-Framed, MDF Station | PVC-Framed, MDF Station | Custom Cascade Cart/Case | Untitled TJ07 Build
MattNo5ss is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Thanks!
I.M.O.G. (04-28-12)
Old 04-27-12, 09:49 PM   #115
mjw21a
mjw21a's Avatar
I think I'll wait and watch at this point
Old 04-27-12, 10:02 PM   #116
diaz
diaz's Avatar
Quote:
That would be quite prefect..
__________________
Main Rig
i5 3570k
EVGA GTX 680
Corsair H80
Heatware
Old 04-27-12, 10:17 PM   #117
Just a nickname
I would like to see some one using no IHS with indigo xtreme. Like this we can remove all the speculation about bad contact with the die as this "TIM" performance doesn't vary with mounting pressure.
__________________
System:
i5-750 @ 4.4GHz (and beyond), 1.368v under LinX & 1.225v VTT
EK supreme cooper, MCP655 with 2x360 swiftech
EVGA P55 classified 200
2x2Gb ECO G.skill 1600 7-8-7-24 @ 2000MHz 7-8-7-24 1.61v / 2100MHz 8-9-8-24 1.5v
XFX 5870 @ 960//1300 stock voltage
CM690 II
Samsung F3 spinpoint
Corsair 750W
Just a nickname is offline   QUOTE Thanks
Old 04-28-12, 12:22 AM   #118
I.M.O.G.
Glorious Leader
I.M.O.G.'s Avatar
10 Year Badge
Was late to getting back to this discussion, but thanks have been distributed to everyone that covered the basic points I would have.
__________________
The OC Forums Way
We are a team. We are a community. We are a fellowship made strong by mutual respect and shared dedication to the task of enriching all who come here.
The OC Forums Thank You Thread
Put your computer to work for our OC Forum Teams!
Try out our POST TEMPLATES, they save you time answering common questions!
I spend half my money on CPUs, GPUs, and Liquid Nitrogen. The other half I waste.
I.M.O.G. is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-28-12, 01:00 PM   #119
nikhsub1
Unoriginal Macho Moderator
nikhsub1's Avatar
10 Year Badge
Yeah that must be due to mount pressure... and if you look at the bare die / paste / HSF picture you can see the cooler wasn't making proper contact - I wonder if the cooler is bowed?
__________________
Loading Signature ...
nikhsub1 is offline   QUOTE Thanks
Old 04-28-12, 03:37 PM   #120
MattNo5ss
5up3r m0d3r4t0r
MattNo5ss's Avatar
I asked because I have one and it's been lapped, and wanted opinions
Plus, you can increase the pressure further by putting something inside where the knob screws down.
__________________
Thanks!
diaz (04-28-12)
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
