Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
Ivy Bridge Temperatures - It's Gettin' Hot in Here
Thread Tools
Old 04-28-12, 10:41 PM   #121
bmwbaxter
Premium Member #5
bmwbaxter's Avatar
Quote:
Originally Posted by MattNo5ss View Post
I asked because I have one and it's been lapped, and wanted opinions
Plus, you can increase the pressure further by putting something inside where the knob screws down.
sounds like someone volunteered to delid and test
__________________
SSD > PCMark 05
freeagent - Torture is watching all these 2600k's kicking my rig in the mosfets
bmwbaxter is offline Author Profile Benching Profile Heatware Profile Rosetta Profile   QUOTE Thanks
Old 04-28-12, 11:09 PM   #122
Ivy
Ivy's Avatar
Ivy Bridge ist from my view not truly impressive regarding gaming performance.
Gulftown (990X) vs. SB-E (3960X) was between 0 and 25% ~ 12.5% average. (Its just in order to compare, not that anyone ever need them for gaming).
SB vs. IB is between 0 and 15% ~ 7.5% average.
So the improvements this time certainly much lower.
I only mean CPU power, the integrated GPU indeed is much stronger but its of no use for high end user unless they use that CPU as a media center PC and plan not to use any dedicated GPU for. Thats indeed the strong spot of IB.
Regarding Overclocking, because Intel is retourning with a technique most recently used on the C2D 4000 series, it can be a pain to OC. I dont know why Intel decided to do so, probably simply wanted to produce cheaper. But im sure Intel will bring out some better IB end of year, so the powerusers can buy a new IB and sell the old one with a lot of money loss. The one truly gaining lot of money is Intel because many fanatics will buy the almost same CPU 2 times in a row, thats how its done it seems. Probably even better to slowly increase turbo clock capabilitys aswell but not this year, so they can buy a third CPU of same architecture.
The valid reason to get IB is to have higher heat capabilitys because of its lesser nm, and thats the stuff every user would expect. But why? Intel dont have to provide that kind of CPU to us right from the start, as long as there is only the slightest improvements, thats all they need. Yes, they say, its hotter than SB using a cool voice ? WHAT? Unbelievable... we have dynamic TDP control and shrinked nm and still hotter? Well... its magics.
__________________
Most important values: Quality>Price/Performance>Noise Level>GFLOPS/cm3>GFLOPS/W
Screen/Audio: Panasonic Plasma @1080P + Onkyo NR609. Computer Series Gen Alpha: Every PC may act as a backup for another one.
Gamer PC: Shuttle SZ77R5 (barebone) modded/I5 3570K @4 Ghz/7870 DCII @1150/1400/Gskill 2x8 GB @1600,1.5V,9,9,9,24, 2T/120 + 240 GB OCZ Vertex 3 MI V. 2.22/750 GB WD 7500BPKT/LiteOn SH-D163B
Workstation: Gigabyte GA-X58A-OC/I7 990X (stock)/6950 FLEX 2GB (stock)/Mushkin 3x4 GB @1600,1.5V, 9,9,9,24, 1T/128 GB Crucial M4 V. 0309/4 TB Hitachi, 2 TB WD RE4/Seasonic X-850/Lian Li PC-C60/NH-C12P SE14/LiteOn IHBS112
HTPC: Asrock Extreme 4-M/I7 3930K (stock)/650Ti AMP! 2GB (stock)/Gskill 4x4 GB @1600,1.5V, 9,9,9,24, 1T/128 GB Samsung 840 PRO/4 TB Hitachi, 2 TB WD Green/Corsair 1200i/Lian Li PC-V354/Phanteks TH-TC14CS/Pioneer BDR-207EBK
Ivy is offline   QUOTE Thanks
Old 04-28-12, 11:14 PM   #123
diaz
diaz's Avatar
I am very anxiously awaiting a thread with lapped vs not-lapped... oh and possible delid?
__________________
\m/ OverClockers mATX L33T Club \m/ >>>JOIN NOW<<<
Main Rig
i5 3570k
EVGA GTX 680
Asus Maximus V Gene mATX
Silverstone TJ08E mATX
16G Corsair Vengeance
Corsair H80
Silverstone Strider Plus 850
Crucial M4 256G SSD // Seagate 750G 7200.12 Storage
Recommended PSU's - True/Tested/***/Intel C2D/Q/X Thermal Designs Explained
Heatware
diaz is offline   QUOTE Thanks
Old 04-29-12, 05:59 AM   #124
TechNickel
Quote:
Originally Posted by nikhsub1 View Post
Yeah that must be due to mount pressure... and if you look at the bare die / paste / HSF picture you can see the cooler wasn't making proper contact - I wonder if the cooler is bowed?
My old U12P is as flat as any heatsink I've ever seen, confirmed with a proper straight edge. If Noctua is anything like Thermalright, they won't have changed their base plate in the last couple of years...
The Noctua coolers are actually super easy to mod for this, just put a shim exactly the thickness of the IHS directly next to the springs on the screws and you have exactly the same mounting pressure as before with the IHS. Much better than using the Venomous X's adjustable mounting pressure since there you can't be sure that you keep the pressure constant between IHS/No IHS (not that too much pressure would make much of a difference, never did in my tests with a TRUE and shims).
TechNickel is offline   QUOTE Thanks
Old 04-29-12, 08:39 AM   #125
mjw21a
mjw21a's Avatar
I'd love to see it tested with a nh-d14
mjw21a is offline   QUOTE Thanks
Old 04-29-12, 09:29 AM   #126
Ivy
Ivy's Avatar
Quote:
Intel also points out Ivy Bridge has a higher TjMAX specification, which governs when the CPU starts throttling in order to protect itself from heat damage. The cut-off for the Core i7-3770K is 105°C, while the 2600K starts throttling at 100°C.
From my experience its very hard to reach TjMax and even by putting a incredible 130W CPU inside a SFF system (the size of a shoebox) and not even the specified TDP does matter, its up to the CPU itself, as a absolutly individual piece. Of course some bad tongues from my local computer shop told me that a 130W TDP CPU will always run into TjMax (the point where the CPU would auto throttle itself) inside a SFF and stuff like that, but its not true**. To be honest, you cant expect people to know the truth who dont even try, everything based on a prejudiced mind. But the main reason a system having very limited cooling can handle such dinosaur CPUs, is because that CPU does transfer its heat to the heat sink in a very powerful manner, thats the main reason it works. That does start at the size of the IHS, going over to the TIM and how it been solved, reaching the DIE, and DIE size can matter too (even material, a DIE made with silver is top notch but doesnt exist). From the DIE it will matter how good the heat is catched up by the sink, and then it will matter how good it will be transfered to the other end... every little detail can add up, and the sum up of those details can create lot of difference. So the 6 core Nehalem was a burner but from my experience it had a good thermal dissipation, maybe SB even better... i was unable to test.
**The heat on the 990X under Intel Burn Test load for 15 min, using Real Temp 3.60 GT monitoring tool, ~25° ambient temp, never created results above 80°, combined with a SFF, size of a shoebox.
Finally, even during hardest conditions (small system, huge CPU): Staying below TjMax is not issue, its to stay stable and that matter is increased by keeping the stuff cool (obviously, my system i tested is NOT made for OC). But how is it done by a CPU very hard to cool down? Stuff like that was easy on huge 6 core CPUs of Nehalem type even. I do worry to put an IB into a SFF system because even a 6 core Nehalem (TjMax of 101°) would not be more of a pain when those results are true. Thing is, its harder to transfer the heat from the cores to the end of the heat sink, thus even when a IB may have lesser TDP, its still same amount of heat hurting the cores.
Besides, Indium is expensive (kinda same such as silver), so Intel will always have to pay more using it, thats certain. Its very soft and will be fluid at above 156° (so the CPU can not be destroyed when its done correctly). Although i dont think its good to fill entire gape with (still better than cheap thermal paste). Indium should be used in order to fill surface irregularities while the main material have to be elemental silver under perfect conditions. And the DIE should be united, in order to remove simply have to heat up the united silver DIE to 156° short time to remove from IHS. Certainly difficult, the indium need to be as thin as possible and totaly even and have to be attached while under vacuum (so no air bubbles). But surely the stuff i see on Intel CPUs from people who dismantled theyr CPUs, is making my eyes hurt (looks like childrens work). At least E types should have a special solution (which is absolutly affordable at a price of 1000$ and up). In general its no quality, despite its insance price of E types. Although many E types may have some better solution, guess thats why my 990X seems to perform better (on heat) than most other Nehalems. Intel could do much better but finally, it will cost them up to 100$ each unit (dependable on material) and why to pass on 100$ each unit if they could make millions charging those 100$ without delivering any real value?! No one gonna stop them, US is free country...
__________________
Old 04-29-12, 10:16 AM   #127
satandole666
satandole666's Avatar
So I still have my trusty Storm Rev.2 from the AMD64 days. I'm wondering how a 3770K would do delidded and WCed for 24/7...
__________________
i7 920
Gigabyte X58 Extreme
6gb OCZ DDR3 2000
7970
Fuzion/MCP655/3x120 rad
satandole666 is offline   QUOTE Thanks
Old 04-29-12, 11:34 AM   #128
Ivy
Ivy's Avatar
The stuff annoying me the most is the fact that companys are never fully transparent with what they do. The dont deliever all the details considering theyr stuff to the consumers. Most consumers may not wish to know, but for those who wish to know it... its legitime for them to be informed.
__________________
Old 04-29-12, 11:58 AM   #129
LZ_Xray
LZ_Xray's Avatar
Quote:
Quote:
Quote:
4th'd! Very kind of you Matt to volunteer to delid your new cpu!
__________________
1) 2500k@4.6/M4GZ/CoolIt ECO 120/8GB Gskill 1600/EVGA GTX570@825/500GB WD Black/HX750/Xigmatek Asgard airflow modded
2) i3-2100/MSI Z68MA-G45/Stock cooler/8GB XMS3 1333/GTX460Hawk@950/160GB WD Blue/Modxstream Pro 700/Xigmatek Asgard
3) 2600k@4.6/M4GZ/H50/8GB Vengeance 1600/GTX460Hawk@950/Intel 320 160GB/Seasonic X650/BitFenix Survivor
4) i7-920 C0/C1 @3.3/EVGA X58 LE/H50/6GB Mushkin 1600/HD6850@950/1TB WD Black/PCP&C Silencer/HAF932
Folding User Stats
LZ_Xray is offline Folding Profile   QUOTE Thanks
Old 04-29-12, 12:27 PM   #130
Janus67
Benching Team Leader
Wannabe Admin Senior
Janus67's Avatar
Currently running prime95 on blend at stock 3770k voltage/speeds (looks like 1.112v under load @ 3.9ghz) with my venomous-x. Currently the maximum temperature is hitting about 57C (57/55/52/52 for all 4)
__________________
Ivy Bridge Benching and Gaming: Asus Maximus V Extreme 0010 BIOS : Intel i7 3770k w/ Phanteks PH-TC14 : 8GB 2x4GB G.Skill TridentX DDR3-2666 : MSI 7970 Lightning Edition
Other Benched Hardware: GA-EX58a-UD3R; Rampage Extreme; Rampage Formula; GA-EP45-UD3R; P5K-Deluxe; MIVE -- 2500k; 2600k; 920; E6300; E6550; E6600; E8400; Q6600 -- 6950; 4870; 8800GTS
Other Components: Crucial M4 128GB SSD : 2x1TB Samsung F3 in Raid0 : Silverstone Strider Gold 1250W : Auria EQ276W 27'' & Dell 2407FPW : KPC Tek9 Fat and Gemini LN2 Pots
Folding User Stats
Janus67 is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 04-29-12, 12:35 PM   #131
Ivy
Ivy's Avatar
How does the Venomous X compare with the best Noctua? No baby coolers that.
Well actually, have to be compared with Silver Arrow, which seems like Silver Arrow slightly beat it. But how is Venomous X in comparison? Most important vs. stock cooler.
As far as i can tell: Not truly to impressive because some other people running 95 W TDP SB CPUs and using Venomous X, had about same results, and i mean, its a CPU with higher specified TDP and older architecture. Because the IB is so close in performance (about 7.5% average, i already told), its kinda a mess of a upgrade. The lowest upgrade i have ever seen (taking out the IGP, its no use for high end user, unless they use it for media center).
Seems like Intels main concern was simply to promote theyr IGP and adding a lot of power considering that matter. Pretty much a foul for high end, but thats a market which isnt to be taken to seriously. The mainstream is the money.
__________________
Old 04-29-12, 01:01 PM   #132
diaz
diaz's Avatar
its not about cooling performance, its about comparison between lapped vs no lapped, possible delid vs lid. venomous has pressure adjust to compensate for lid being gone.
__________________
Main Rig
i5 3570k
EVGA GTX 680
Corsair H80
Heatware
Old 04-29-12, 08:15 PM   #133
Ivy
Ivy's Avatar
Yes the pressure adjust is kinda noticed because i checked the Thermaltake site. But the issue is that a cooler of a certain size is almost incapable of, would touch other parts of the MB. So whats the point of it... when the cooler have to be downsized. Well, anyway, keep it up and may provide interesting infos about those different conditions.
__________________
Old 04-29-12, 10:35 PM   #134
SHODAN
SHODAN's Avatar
Quote:
Originally Posted by hokiealumnus View Post
Just for reference, here is what a soldered die looks like de-lidded.
Attachment 109059
Image courtesy BlindFreddie @ XS.
Jesus built your hot rod?
__________________
Antec Solo | Corsair AX750 | ASRock Z68 Extreme4 | i5-2500K w/ TRUE @ 4590 MHz
2x4GB G.Skill Ripjaws X 1866 9-10-9-28 | MSI R6850 Cyclone @ 940core / 1220mem
OS: WD Caviar Black 640GB | Data: 2 x ST1500DL003 in RAID 0
Q3 2007 - Q2 2011:
Antec Solo | Corsair 520HX | Abit IP35 Pro | E2160 /w TRUE @ 3384MHz
2x2GB G.Skill Pi Black DDR2-800 | XFX 7950GT Ext @ 670core / 860mem
Low noise!
SHODAN is offline   QUOTE Thanks
Old 04-29-12, 10:39 PM   #135
MattNo5ss
b4n4n4 dr4g0n d00m3d m0d3r4t0r
Overclockers.com Editor
MattNo5ss's Avatar
Quote:
It's possible I'll test a delidded CPU. I have ~$210 in my "extra Ivy CPU" fund, so I still need about $110 or so before I can do that.
Quote:
Overall max temps don't matter, it's the temp differences between the different setups: not lapped IHS, lapped IHS, no HIS, TIM change + lapped IHS, etc. So, whether the cooler is the best for the chip or not doesn't matter because we'll be looking at temp differences, not overall max temps.
__________________
i7 3770K | ASUS Maximus V Gene | 4x2GB Dominator GT DDR3-1600 6-6-6-20 | EVGA GTX780 SC ACX | 256GB OCZ Vertex 4 | SeaSonic X750
E8700/E6750/P4 631 | Rampage Extreme & EP45T-Extreme & Commando | DDR2 D9 or any DDR3 | 1 of 20ish GPUs | 50GB OCZ Vertex 2 | SeaSonic SS-1000XP
O/C Author Profile | HWBot Profile | Heatware (91-0-0)
Projects: Copper-Framed, MDF Station | PVC-Framed, MDF Station | Custom Cascade Cart/Case | Untitled TJ07 Build
MattNo5ss is online now Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-30-12, 10:56 AM   #136
Robert17
Robert17's Avatar
__________________
Main rig: MSI Z77 MPower||Intel i7-3770K @4.2GHz||Corsair H60
Antec EA 650w||G.Skill Ripjaws X 2133 x8||Crucial M4 128GB
Seagate 1Tb F1 7200 32Mb||Galaxy Geforce 660ti
NZXT Phantom Black||fans 1x140, 3x120, 3x200||Asus VN247H-P||Win7 Pro 64-bit
Folding User Stats
You can _____ when pink elephants fly
Robert17 is online now Author Profile Folding Profile   QUOTE Thanks
Old 04-30-12, 12:50 PM   #137
Janus67
Janus67's Avatar
Quote:
Originally Posted by Robert17 View Post
Nice find!
although we weren't the ones that pried open the CPU, always happy to see some extra publicity for the site
__________________
Folding User Stats
Old 04-30-12, 03:19 PM   #138
diaz
diaz's Avatar
Quote:
Originally Posted by Janus67 View Post
Nice find!
Saw this a while back...
http://fudzilla.com/home/item/26957-...blem-explained
Quote:
According to a post over at Overclockers.com, the first reason is only partly true as although the power density is indeed greater it can't explain a difference of up to 20°C when overclocked Ivy Bridge and Sandy Bridge are compared. Although, there is also a minor possibility that second reason has something to do with it as Ivy Bridge certainly has a lower overclocking potential, but mostly due to heat, as some reviewers were even scared to push it beyond 4.5GHz.
__________________
Main Rig
i5 3570k
EVGA GTX 680
Corsair H80
Heatware
Old 04-30-12, 07:47 PM   #139
zkAry
Do you have any comments to this test? that place the heat sink directly on the die and find that temperatures are similar. The weakness in their argument is that they equate their die -> paste -> cooler assembly with a die -> solder -> IHS -> paste -> cooler assembly. They don't test Ivy Bridge with a soldered IHS.
zkAry is offline   QUOTE Thanks
Old 04-30-12, 08:49 PM   #140
Janus67
Janus67's Avatar
you can't test Ivy Bridge with a soldered IHS as IB isn't (as far as we know) soldered with any of their chips and Intel uses a special kind of solder that melts at a lower temperature than most other solders (and I'm sure is a special blend)
__________________
Folding User Stats
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
