- Mar 15, 2009
- London, Croydon
Ok my current setup is;
Virgin Media Superhub (192.168.0.1)
v
Powerline adapter 1 (wired only)
v
Powerline adapter 2 (wired only)
v
Switch
v
Wireless Powerline adapter (192.168.1.1) / Xbox 360 / Samsung Smart TV
v
Macbook connected to wireless powerline adapter.
I use the wireless powerline adapter because the wireless signal from my room is awful (distance to router is too far).
When I'm on my Macbook/Xbox at random times, I'll disconnect, I'm guessing this is a DHCP error.
What settings should I use? and on what devices?
I can edit the settings on the router and the same settings on the wireless powerline adapter if that helps.
Here are the network settings from my Wireless Powerline Adapter (192.168.0.123) (In my room)
Here is the device list on my Router (192.168.0.1) (Downstairs)
Lease table:
Lease settings:
Does this explain why I get disconnects every so often? because the powerline adapter (192.168.0.123) is getting a new IP, so I get dropped temporarily?
If so, should I add a reservation for it or what?
v
v
v
Switch
v
v
Lease table:
Lease settings:
