Notices
Overclockers Forums > Hardware > Motherboards > Intel Motherboards
Intel Motherboards
Forum Jump
Hardware monitor Program for ASUS P4S333
Thread Tools
Old 03-09-02, 02:56 AM Thread Starter   #1
_maximilian_
Lightbulb Hardware monitor Program for ASUS P4S333
i have a bit of a problem. i cant find one hardware program that supports the ASUS P4S333 (sis 645 chipset)
mbm5 doest work, well, just about nothing i tryed worked
do you guys know where i can get a hardware monitor program for my board. cuz its kidna hard to overclock when you dont know the temps
_maximilian_ is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 03-09-02, 09:16 AM   #2
Revx
Revx's Avatar
Well there is also the option of getting a much more accurate thermal sensor such as just picking up a cheap compu nurse, as for software i really don't have a clue. But if you see smoke, it's too hot
Revx is offline   QUOTE Thanks
Old 03-10-02, 06:44 PM   #3
racecar12
racecar12's Avatar
Re: Hardware monitor Program for ASUS P4S333
Have you tried the hardware monitor that comes with the motherboard disk also? My motherboard disk is bad so I couldn't get that progy off of it and asus site still sucks. They had it half decent but they have changed the page, once again, and nothing is working yet.
Browse the motherboard cd and look for a file named utilities, and if you could help a fellow oc'er out by coping that file and emailing it to me. I would be much apprecited. I can't monitor temps in windows either. racecar12@excite.com
racecar12 is offline   QUOTE Thanks
Old 03-10-02, 08:24 PM   #4
montano
I would imagine AsusProbe would work with ALL Asus mobo's?? MBM5 works just fine with my SIS 645 Board..........Just takes some adjusting.
montano is offline   QUOTE Thanks
Old 03-11-02, 04:16 AM Thread Starter   #5
_maximilian_
i did try AsusProbe, but the CPU temp always 40". wich isnt right.
i dont think the sis645 sensor is suported by AsusProbe.
montano, how many sensors can you use with Mbm5. i only have one, wich gives a constant temp of 51.
Old 03-11-02, 09:33 AM   #6
montano
I got all the sensors to work. It does take some time to get 'em right. I have 3 temp sensors and 7 voltage sensors, plus 2 fan speed sensors working on MBM5 with my 645 board.
Old 03-11-02, 10:07 AM Thread Starter   #7
_maximilian_
thats just it, i only have one sensor. i think its a mather of time till mbm5 does suport the mainboard, or maybe i should do a bios update.
do u by any chance know where i can get the 1004c bios for my P4S-333?
Old 03-11-02, 10:32 AM   #8
montano
If the BIOS is not listed on thier website, it might be listed under thier BETA download website. Also, do you have the latest version of AsusProbe?
Old 03-11-02, 11:16 AM   #9
racecar12
racecar12's Avatar
Mbm5 does the same with my p4s333. There is only one sensor listed for both the temps and the voltages. So conifuring mbm5 is impossible. I think the problem might be because of the combo of the two chipsets> quote from asus site
"SiS MuTIOL technology, the new bus architecture, connects SiS 645 and SiS 961 together, and delivers 533MB/s bandwidth between North Bridge and South Bridge and even up to 1.2GB/s for South Bridge internal bus frequency."
I really would like to monitor the temps. But I know it is not overheating. I do have suspision that it might be clock throttling when my ambient temps are higher during the daytime. Seti times just fall like a rock from like 2.75-3.5hrs at night to 4-6hrs to crunch a wu during the warmest part of the day. I have the cure with a water cooled setup, but I have to do some engieneering work to do before I mount the waterblock. Soon though
Old 03-11-02, 11:27 AM   #10
montano
The thing is my MoBo has the same chipsets as the P4S333, and MBM5 works great for me??
Old 03-11-02, 11:45 AM Thread Starter   #11
_maximilian_
i think that its a mather or time.couse the sensors are there, and the bios show's the temps.
maybe someone could e-mail ASUS?
Intel Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
