Hello. I'm having some troubles with my CPU. I've recently put together my first gaming computer and it's come to my attention that my CPU (AMD A10-5800K) is going way over the normal temperatures. It idles at 50C and when I turned on BF3 on max settings it went even to 105C! My computer specifications are the following:
CPU- AMD A10-5800K (stock cooler)
RAM- 8GB G.SKILL Ares series 2133MHz DDR3
Motherboard- ASRock FM2A55M-DGS
GPU- AMD 7950XFX 3GB GDDR5
HDD- 500GB WD
Tower- CM haf xm
This computer is nearly a month old now and I thought maybe I'd wait a bit for the thermal paste to settle in but that didn't happen. I've tried various CPU temp measuring programs and CoreTemp showed me the temps go as low as 0C which is really questionable, I then tested it in Speccy and it showed me basically the same that CPUID HW Monitor showed me (105C at max load and rising and 50C at idle). But the program ASrock Xtreme Tuner shows me that the CPU temp is 35C. I also tried putting my hand close to the CPU and I noticed a temperature change when idle and under full load, there is a temp increase but It doesn't feel as it is 105C . I'd appreciate if anyone can shed some light on this issue of mine.
HDD- 500GB WD
Tower- CM haf xm
