- Feb 25, 2014
- Myrtle Beach SC
Hello, first I want to say hi and that I'm new on this site but not building PC's. I've done 6 for myself and a few for friends and family. I've also done water cooling before but this will be my first Sub loop.
So I've got a Monsoon Series 2 DDC Premium Dual Bay Reservoir with a Swiftech MCP655-PWM-pump. On my reservoir it has the option for a sub loop.
It has 2 inlet ports and 2 outlet ports. So I wont to know if my pump will be ok and not burn out. What I want to do is use the top outlet for #1 loop and that will be for the EK ram water block to the EK cpu water block to the EK water block for the VRM / MOSFETs then to my 420 EK rad.
My bottom ports will be loop #2 and it go to the EK water block for the Z87 intel express chipset then to the EK 780 water block to the Black Ice 280 rad then back to the res.
Will this be ok on my pump. If by chance you have done a sub loop or know of someone that done it . Please get me in touch with them and see how it went for them. Thanks for reading.
