- Jun 7, 2002
- On the surface
To date I've only been able to post and open win xp by using the BIOS option "Loads Optimized Defaults" The problem I have with these settings are that from most indications I'm only running at 1200mhz and not 1600mhz. (This is strange because the BIOS says CPU Operating Speed 1600+(133) but I guess its really running at 100mhz)
Hardware
abit kx7-333R
Athlon XP 1900+
Turtle Beach
abit GF3 Ti200
Windows XP pro
one stick 512MB pc2700 Samsung Ram in dimm 1
using two identical seagate 60g drives Raid 0
300w compusa power supply
Soft Menu III Settings (all other setting were set by the Load Optimized Defaults" option
Cpu speed User Define
FBS 133
Ratio 3:2:1
Multi 12
Enh bench enabled
Speed hold disabled
CPU FCD Ultra
All voltages unchanged
The settings above posted but would not open win xp.
Thanks mush in advance
Hardware
abit kx7-333R
Athlon XP 1900+
Turtle Beach
abit GF3 Ti200
Windows XP pro
FBS 133
Ratio 3:2:1
Multi 12
Enh bench enabled
Speed hold disabled
CPU FCD Ultra
