G.Skill Ripjaws4 DDR4-2666 MHz Memory Kit Review
Back in September of last year, G.Skill provided a Ripjaws4 DDR4-3000 MHz memory kit to compliment our Haswell-E launch day coverage. This time around, G.Skill sent along a Ripjaws4 DDR4-2666 MHz 16 GB kit for us to have a look at. This particular kit carries a part# F4-2666C15Q-16GRR and is priced substantially less than their DDR4-3000 MHz and above offerings. DDR4 memory is by nature a very expensive proposition, so we’re excited to see if G.Skill can provide a cost efficient DDR4 memory kit that still provides the performance we’ve come to expect from their memory products. Let’s go see how they did, shall we?
Specifications/Features/Product Tour
The specifications below are provided by G.Skill and provide detailed information on the kit at hand. You’ll notice the timings are set identical to the DDR4-3000 MHz kit we spoke of earlier, but the operating voltage is much lower at a mere 1.2 V. Full support for Intel’s XMP 2.0 standard, a lifetime warranty, and a very respectable memory height round out the highlights here.
G.Skill Ripjaws 4 DDR4-2666 4X4 GB Specifications
Part Number
F4-2666C15Q-16GRR
Memory Type
DDR4 Unbuffered Non-ECC
Tested Speed
2666 MHz (PC4-21300)
Tested Latency
15-15-15-35
Capacity
16 GB Total (4X4 GB Modules)
Multi-Channel Kit
Quad Channel
Pin Count288
Operating Voltage
1.20 V
XMP Support
Compatible with Intel XMP 2.0
Compatibility
Intel X99 Chipset/Haswell-E (LGA 2011-3) CPU
Module Height
40 mm/1.58 in.
Warranty
Lifetime
Once the memory is up and running with the XMP Profile set, here is what the UEFI BIOS and CPU-Z show.
UEFI BIOS SPD Table
UEFI BIOS SPD Table
gskill_ripjaws4_2666 (19)
CPU-Z Memory and SPD Tabs
The high level features are listed below and are also courtesy G.Skill.
  • Extreme performance DDR4 memory designed for gaming and PC enthusiasts
  • Optimized compatibility with Intel X99 system
  • Stylish aluminum heat spreader design to keep the memory cool
  • 1.2V ultra low voltage
  • Intel XMP 2.0 Support
For a deeper look into the features the Ripjaws4 DDR4 memory line offers, the G.Skill marketing folks have several key points they’d like you to know about.
Ripjaws 4 – The Ultimate DDR4 Memory for Intel X99 Platforms
G.SKILL Ripjaws 4 series performance DDR4 memory is designed for the ultimate experience on the latest Intel X99 platform! Whether you are processing large amounts of data or intense gaming, experience smooth system performance with the newest next-generation PC memory technology! All Ripjaws 4 memory kits are tested with G.SKILL’s extensive suite of testing software to ensure maximum performance and stability. Make Ripjaws 4 the ideal choice for your DDR4 system!
4th Generation Ripjaws Series memory for the latest DDR4 Systems!
Ripjaws 4 series DDR4 memory are validated for compatibility with most X99 motherboards under a series of rigorous tests in quad channel memory operations. It’s guaranteed to provide the best-in-class performance, compatibility, and stability with the widest range of X99 motherboards.
Faster Transfer Speed
Starting from 2133MHz as standard frequency, DDR4 memory delivers much higher bandwidth than previous DDR memory. You can enjoy a faster computing experience for gaming, video & image editing, rendering, and other professional applications.
gskill_ripjaws4_2666 (5)
G.Skill has a long history of extreme overclocking and world records to prove it. I don’t think their current record was accomplished with the kit we are reviewing today, but it gives you an idea of the Ripjaws4 overclocking prowess.
Extreme Speed in Overclocking
G.SKILL always strive to break past limitations. Ripjaws 4 series is the fastest DDR4 memory in the world, including an exclusive DDR4-3333MHz memory kit. Furthermore, Ripjaws 4 is the first DDR4 memory to break the DDR4 4GHz in overclocking, reaching an incredible speed of 4004MHz. Whether you are an PC performance seeker or a overclocker, Ripjaws 4 is your best choice.
gskill_ripjaws4_2666 (4)
One of the advantages the new DDR4 memory platform offers is its low power consumption. It’s really pretty astounding that memory running at these speeds can do so at such low voltage.
More Power Efficient
Designed with a low voltage of 1.2V at DDR4 standard, this lowers the memory voltage requirement by 20% from DDR3 memory kits! Now your system can perform even faster without becoming an expensive appliance heater.
gskill_ripjaws4_2666 (3)
Optimizing CPU cooler compatibility and still being able to keep the modules cool is something G.Skill thinks they’ve accomplished with their new heatspreader design.
Timeless Classic Stylish Redesign – Looking Great without Oversized Heatspreaders
Confidently knowing your system is a combination of beauty and brawn, Ripjaws 4’s new dashingly sleek heatspreader keeps your system cool and well cooled. Looks isn’t everything, but your rig should look great and perform great at the same time. And don’t worry; Ripjaws 4 has a module height of 40mm – the same height as previous Ripjaws family modules – and will be compatible with most CPU heatsinks!
gskill_ripjaws4_2666 (2)
The memory kit comes packaged in a clear plastic clam shell with a cardboard insert. The insert has a few high-level features and specifications printed on it, and they stuff a nifty little case badge inside too.
Photo Op
Obviously, the kit we were sent has red heatspreaders. As we mentioned before, you can see the heatspreaders are not very tall and should accommodate a wide variety of air coolers. G.Skill’s logo and branding are on both sides of the modules, but one side has a sticker applied with basic specifications printed on it. The heatspreaders feel very well made, and you definitely get a feeling of quality when handling the memory modules. Enjoy the pictures below!
gskill_ripjaws4_2666 (15)
gskill_ripjaws4_2666 (13)gskill_ripjaws4_2666 (14)
gskill_ripjaws4_2666 (18)gskill_ripjaws4_2666 (17)
gskill_ripjaws4_2666 (16)
Testing for Stability at Rated Speed/Timings
Once the memory is installed in our test bed, we begin with a stability check at advertised speed/timings/voltage. To perform the stability check, we use our new Ultra-X R.S.T. Premium USB memory tester. The fine folks at Ultra-X provided us with the tester, and we’re proud to be one of only a few review sites that have one. The Ultra-X R.S.T. Premium is a bootable USB device that’s a relentless, memory pounding beast and will definitely find any instabilities a memory kit may have. Depending on the capacity of the memory kit, it can take several hours or more to complete the five passes we prefer to run. As you can see by the picture below, it took well over six hours to complete the five passes. No errors were recorded, so we’re confident we have a perfectly stable set of memory.
Ultra-X R.S.T. Five Passes
Ultra-X R.S.T. Premium Five Passes
Testing for stability in-OS is performed with a 32M run of HyperPi, which is a pretty stout stability test in it’s own right. If you don’t posses a tester like the Ultra-X R.S.T Premium, it’s the next best thing. After passing the torture test that is the Ultra-X R.S.T. Premium, we didn’t expect a problem when running HyperPi. As you can see, no problems encountered here either.
HyperPi 32M Stable
HyperPi 32M Stable
Benchmarks
Here are the components used in our test bed. All testing was performed with the CPU at its stock setting and the memory set to its XMP Profile.
Test System Components
MotherboardASUS Rampave V Extreme
CPUIntel i7 5960X
MemoryVarious – See Table Below
Video CardEVGA GTX 780 Ti Classified
StorageSamsung 840 Pro SSD 256 GB
CoolingCustom Water
Operating SystemWindows 7 Pro x64
The four memory kits in our comparison group include today’s review sample and the previously reviewed G.Skill Ripjaws4, Corsair Vengeance LPX, and ADATA XPG Z1. The previously reviewed G.Skill and Corsair kits are 16 GB and run at DDR4-3000 and DDR4-2800 speeds respectively. The ADATA kit is 32 GB in capacity and has the slowest MHz speed of all the comparison samples at 2400 MHz. Both G.Skill kits were tested on the ASUS Rampage V Extreme, while the ADATA and Corsair kits were tested on the ASUS X99 Deluxe. Both motherboards used the memory’s XMP Profile with the CPU at it stock settings for all tests. Both of the motherboards also feature the ASUS OC Socket, so results should be consistent between the two motherboards used for testing.
Comparison Kits
BrandSeries Speed ChannelsCapacity Timings Voltage
G.SkillRipjaws4DDR4 3000Quad4×4 GB15-15-15-35-2T1.35 V
CorsairVengeance LPXDDR4-2800Quad4X4 GB16-18-18-36-2T1.2 V
G.SkillRipjaws4DDR4-2666Quad4X4 GB15-15-15-35-2T1.2 V
ADATAXPG Z1DDR4-2400Quad4X8 GB16-16-16-39-2T1.2 V
The graphs below show percentage values with the G.Skill DDR4-2800 kit (today’s review sample) being the basis, and therefore always 100%. In the scored benchmarks, a higher percentage is better while timed benchmarks a lower percentage is better. Below each chart is a table with the raw data used to compile the chart.
Synthetic Testing
The AIDA64 suite of memory tests show the G.Skill Ripjaws4 DDR4-2666 MHz kit landing right where it should. The latency test shows our review sample beating all but the G.Skill DDR4-3000 kit (lower percentage is better). The copy tests show our kit again beating all but the G.Skill DDR4-3000, while the read and write test results show very little difference between all the test samples.
AIDA64 Memory Tests
AIDA64 Memory Tests
AIDA64 Memory Benchmarks – Raw Data
KitReadWriteCopyLatency
G.Skill Ripjaws4 DDR4-300061874469946775264.0
Corsair Vengeance LPX DDR4-280059046476845663269.8
G.Skill Ripjaws4 DDR4-266660378469976278368.9
ADATA XPG Z1 DDR4-2400059793479216109169.8
The SuperPi and wPrime testing show a similar pattern of all the samples being very close, but even more so here. All four of these test results show less than a 2% difference between the samples.
SuperPi and wPrime Tests
SuperPi & wPrime Benchmarks – Raw Data
KitSuperPi 1M
SuperPi 32MwPrime 32M
wPrime 1024M
G.Skill Ripjaws4 DDR4-300010.358535.1283.588103.693
Corsair Vengeance LPX DDR4-280010.281529.3563.527101.728
G.Skill Ripjaws4 DDR4-266610.342538.5283.526103.554
ADATA XPG Z1 DDR4-240010.296543.1153.525103.586
Rendering and Compression Testing
The three Cinebench tests again show minor differences between the sample kits with around 2% being the biggest difference. The 7zip test run shows the same behavior with less than a 2% difference between the test samples.
Blah
Cinebench and 7zip Tests
Cinebench & 7zip Benchmarks – Raw Data
KitCB R10
CB R11.5
CB15
7zip
G.Skill Ripjaws4 DDR4-30004480015.17141243532
Corsair Vengeance LPX DDR4-28004420615.49141243640
G.Skill Ripjaws4 DDR4-26664433315.26140742945
ADATA XPG Z1 DDR4 24004376115.26140742945
Video Conversion Benchmarks
Video conversion performance is tested with x264 and PoV Ray 3.73. Once again, around 2% separated all the comparison samples in these test runs.
Blah
x264 and PoV Ray Tests
x264 & PoV Ray 3.73 Benchmarks – Raw Data
KitPoV Ray 3.73
x264 Pass 1x264 Pass 2
G.Skill Ripjaws4 DDR4-30002847.19205.8883.42
Corsair Vengeance LPX DDR4-28002903.74208.1784.80
G.Skill Ripjaws4 DDR4-26662845.25205.8883.43
ADATA XPG Z1 DDR4-24002849.11204.9883.20
From top to bottom, the test results make one believe memory speed doesn’t play as big a part in total system performance as it might have in previous generation platforms. With that said, the G.Skill Ripjaws4 DDR4-2666 kit becomes quite a value when you consider it performs right on par with the DDR4-3000 and DDR4-2800 kits in our comparison samples. Hardly anything to complain about there.
Overclocking
When I overclock memory, I like to make sure it’s stable and something you can actually use day to day. Sure, you can probably ramp it up higher and complete a quick benchmark, but I prefer settings that can actually be used reliably. By setting the memory speed in the UEFI BIOS to 2750 MHz and then adjusting the BCLK to 127.3, we landed at 2800 MHz for the memory. This only took a slight bump in voltage to 1.3 V and we were able to keep the timings at their default 15-15-15-35. It passed a full 32M run of HyperPi at this setting, so we’re off to a good start!
HyperPi Stable at 2800 MHz 15-15-15-35
Getting the memory to play nice at 3000 MHz required both an increase in voltage to 1.35 V and lowering the timings to 16-16-16-36, which isn’t too much of a sacrifice. HyperPi 32M completed yet again at these settings. Compared to the original run of HyperPi 32M when we were checking for stability at stock speeds, we see over a 45 second improvement in completion time.
HyperPi Stable at 3000 MHz 16-16-16-36
Once past this point, the timings had to be raised to a point where they negated any increase in speed. Not to mention the voltage required was getting well over the 1.4 V ~1.45 V range. I did manage to get to the desktop at 3333 MHz using 17-22-22-36 timings, but it was anything but stable. Still, in the end, this kit runs happily at DDR4-3000 MHz with an acceptable set of timings and voltage. Let’s move on and see what we can do about tightening up the timings.
After dropping the memory back to its default speed of 2666 MHz, we set the timings to 13-14-14-35 and tried HyperPi 32M again. It took right at 1.4 V to get this stable, but we got through the SuperPi 32M run. I tried lowering the timings further and applying even more voltage, but unfortunately it wasn’t having any part of it. Even so, a CL13 isn’t a bad result.
HyperPi Stable 13-14-14-35 Timings
Conclusion
G.Skill has done a very nice job with their entire Ripjaws4 line of memory, and this kit held true to form. For the average overclocker, you can easily get this kit to run at 2800 MHz or 3000 MHz. Taking it past those speeds is doable if you’re willing to throw a lot of voltage at it and have the ability to keep it cool. In the end, it’s a kit that’s has a substantial amount of headroom and is fun to play with. Even if you simply use the kit at its stock XMP profile settings, you’ll enjoy performance right on par with kits costing substantially more.
Aesthetically, the Ripjaws4 DDR4-2666 is a good looking affair, and we really like that G.Skill kept the memory height at a level conducive to using a wide variety of air cooling solutions.
The Ripjaws4 DDR4-2666 kit is currently available at Newegg for $249, which is the least expensive DDR4-2666 kit available there with 15-15-15-35 timings. Given how easy it is to overclock this kit to the 2800/3000 MHz range, the value is certainly pretty impressive.
A good looking kit that is priced right, overclocks very well, and offers enthusiast level performance… Overclockers approved!
Overclockers_clear_approvedClick the stamp for an explanation of what this means.
Dino DeCesari (Lvcoyote)
About Dino DeCesari 230 Articles
Dino DeCesari was a pillar of the Overclockers.com community for over 13 years when he passed away suddenly in 2015. His legacy lives on through his hundreds of computer hardware reviews posted here. Dino spent time in the army as a Telecommunication Center Specialist and received a commendation medal. He had a successful 20+ year career in the automotive parts and technology industry, where he eventually bought and sold his own business. Once retired, he volunteered as tech support for a non-profit and his local school district.
Loading new replies...
W
Woomack
Benching Team Leader
13,193 messages 2,215 likes
It's a great memory kit. I had a chance to test it some time ago -> http://www.overclockers.com/forums/...pjaws4-4x4GB-DDR4-2666-CL15-F4-2666C15Q-16GRR
My kit could run at 3200 CL16 1.35V without issues ( result in link ).
Reply Like
S
Sabishiihito
53 messages 1 likes
You got a better kit, Woomack as the one you tested had Hynix ICs. The kit Lvcoyote reviewed used Samsung (I'm sure you already knew that though, I'm moreso pointing it out for others).
Reply Like
