First I owe Gigabyte an explanation for taking so long to get this review written up. The truth is, Gigabyte products always take me the longest time to review because they’re so much fun to use. I often forget I’m supposed to be writing a review, and get completely sidetracked. I’d like to thank Angela at Gigabyte for being so patient with me taking my time to publish results any time she sends a product to me for testing.
GOOC 2009 (Gigabyte Open Overclocking Championship) was the first time I overclocked on the X58 platform, and I haven’t done so since then. P55 got in the way, and although I’ve been having a blast with it over the past several months, something has been missing. I realized just what that was when Gigabyte sent me their X85A-UD7 for testing.
First impressions
Specs and Features
- CPU: Core i7, LGA1366
- QPI: 4.8GT/s, 6.4GT/s
- Northbridge: Intel X58
- Southbridge: Intel ICH10R
- Memory: 6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory
- Memory frequency: DDR3 2200/1333/1066/800 MHz memory modules
- Audio: Realtek ALC889 codec
- LAN: 2 x RTL8111D chip (10/100/1000 Mbit)
- 2x PCI Express slots running at 16x
- 2x PCI Express slots running at 8x
- 2x PCI Express 1x slots
- 1x PCI slot
- Multi-Graphics technology: Support for 2-Way/3-Way ATI CrossFireX™/NVIDIA SLI technology
- Up to 10 USB 2.0 ports: 6 on back panel, 4 internal
- 2 USB 3.0/2.0 ports on back panel via NEC chip
- 6x SATA 3GB/s connectors supporting RAID 0, 1, 5, 10, via ICH10R
- 2x SATA 6GB/s connectors supporting RAID 0, 1, via Marvell 9128 chip
- 2x SATA 3GB/s connectors supporting RAID 0, 1, and JBOD, and 1x IDE connector, via Gigabyte SATA2 chip
- 2x eSATA 3GB/s connectors on back panel, via JMicron JMB362 chip
- 1x floppy drive connector via iTE IT8720 chip
Here we see packaging typical of high-end Gigabyte products. Product features cover the oversize box, and the front flap opens to reveal the motherboard inside. The board resides in a clear plastic shell, while the huge assortment of accessories have their own separate box, hidden behind it.
Opening the box, we see the X58A-UD7 nestled comfortably in a clear plastic shell (like most top-end Gigabyte boards) with the SilentPipe chipset cooler add-on.
And a closer look at the SilentPipe assembly. The X58A-UD7 heatpipe assembly has options for air or water cooling. For users taking the air cooling route, this is easily mounted with a little thermal paste and four screws.
Included Accessories
- User manual, installation guide, Smart 6 manual, driver disc
- I/O shield
- 4x SATA cables
- 1x PATA cable
- Tri-SLI bridge
- Flexible SLI cable
- eSATA bracket and cables
And finally, the motherboard pictures. Typical Gigabyte color scheme and all the component cooling hardware you’d expect on a board like this.
Located next to the memory slots, we find a nice, big onboard power button, along with a smaller reset button.
The first thing you notice on the lower right corner of the board is the huge heatsink covering the ICH10R. Located in this area are ten total SATA ports, the battery, a PATA connector, front panel connectors, two USB headers, and an onboard debug LED. If you don’t own a debug LED (or POST code reader), and your motherboard doesn’t have one built in, you need to order one. They’re absolutely essential for troubleshooting, and I always have one on hand when overclocking.
In the expansion slot area, we have two PCI-E slots at 16x, and two at 8x. There are also two PCI-E 1x slots, and a single PCI slot.
Now on to the CPU socket area. The X58A-UD7 features 24-phase power, as you can see by the crowded socket area. Insulating around all of it for liquid nitrogen cooling was a bit more time consuming than some other boards, but well worth it.
And a closer look at Gigabyte’s SilentPipe cooling solution. These pictures are only for the top half, because there are several pictures showing the ICH10R portion above.
Now to see what’s under all that cooling hardware…
And the rest of the motherboard pictures, including the back and I/O panel.
You may be worried about the un-sinked mosfets on the back of the board, but none of the Gigabyte boards with 24-phase power that I’ve owned have had any problems because of this.
The BIOS
Most of the BIOS settings you’d expect on just about any motherboard, with the exception of the MB Intelligent Tweaker (M.I.T.) section. And the M.I.T. section is by far the most important. Where other motherboard companies put the overclocking goodies section in the top right (or worse even), Gigabyte put theirs first. This means before even setting the system time, you need to begin overclocking.
And now the important stuff…The M.I.T. section.
Ideally, the thing to do here would be to list all the slick overclocking features under the M.I.T. menu. But it’d be much easier to list the options that are missing, since it’s got pretty much everything you could want or need.
Testing
I did a little air testing with a Core i7 920 D0, and a good bit of air testing with a 920 C0. I did a bit of liquid nitrogen testing with the D0 as well, but in cooling with both air and LN2, the CPU was the limiting factor.
Testing setup
- Core i7 920
- Gigabyte X58A-UD7
- 3x1gb Kingston HyperX DDR3 2000MHz
- Radeon HD 4890
- OCZ 1000w PSU
- Open air bench station
- Air cooling: COGAGE TRUE Spirit
- LN2 cooling: Dragon F1 EE
Air testing the 920
I’ve never overclocked on anything so easy before. The 920 D0 was doing 4.5GHz perfectly stable within only a few minutes of powering it on for the first time. The only settings I had to change in BIOS were CPU voltage, CPU VTT, and DDR3 voltage. All other settings were at ‘auto’ or ‘normal.’ I received this board shortly before Forum Wars, which gave me a great opportunity to do some competition-based testing. It topped out around 4.7GHz on air, but was a disappointment when frozen.
LN2 testing
The 920 D0 I had was a great CPU on air. When put under the cold stuff, it was a completely different story. I was stopped just short of 5GHz, but stability was not an issue for any benchmarks I threw at it. Even with the CPU’s poor LN2 results, I was able to pull off some personal bests in a few benchmarks:
Final Thoughts and Conclusion
I’m not near finished testing this board, and I probably won’t be for quite some time. There are so many possibilities with a powerhouse such as this, and I get a huge grin on my face every time I have the opportunity to use it.
Still on my list for tesing:
- Gulftown + HD 5870
- USB 3.0 + SATA 3 testing
- GTX 480 when available
If you’re new to overclocking, you probably won’t find an easier motherboard to get your feet wet with. If you’re an extreme bencher, and need every single MHz you can get, this board will give you that. If you’re a casual user, who just wants a solid motherboard with USB 3 and SATA 3 at an affordable price, Gigabyte has less expensive options in their X58A line as well.
I’d like to thank Angela at Gigabyte for letting me test this incredible motherboard.
Related posts:
- Another Look at the Gigabyte X58A-UD7 Rev. 1.0
- Review and Overclocking results of the Gigabyte GA-P55-UD3R Motherboard
- X58A-UD3R: High-End Overclocking on Gigabyte’s Entry X58 Platform
- Gigabyte P55A-UD7 on liquid nitrogen
- GIGABYTE Announces GO OC 2010 (GIGABYTE Open Overclocking Championship) Worldwide Final
Tags: Core i7, gigabyte, x58, X58A-UD7
03-26-10 12:28 PM
Look forward to seeing what you will do with a nice 5870...
03-27-10 02:21 AM
03-27-10 02:42 AM
03-27-10 05:53 PM
04-05-10 02:00 AM
04-05-10 02:22 PM
No, the only hiss was coming from the HD 4890
04-05-10 05:28 PM
04-07-10 06:32 PM
04-07-10 06:35 PM
04-07-10 06:48 PM
04-07-10 06:50 PM
04-07-10 09:35 PM
04-08-10 03:10 AM
Voltages are (need to reboot to check), but I'm wondering if the UD7 can run my same processor at a lower voltage?
04-08-10 03:19 AM
My 920 was pushing the same temps at 4.5GHz on air as yours is at 4.1. The newer batch 920 D0s are good on air at mid-4GHz range with nice low volts, but after a certain point they scale terribly, but that's fine if you're on air or water cooling. My 920 was pushing 82 C at 4.6v. Of course this all depends on your cooling. I'd trade you if I still had the chip, because I bet with the high temps yours would be great under LN2
04-08-10 07:30 AM
One thing I do wish they would start giving a bit more attention to (or maybe going a new direction) is overall appearance of the board itself. The blue and white color combo is getting a little drab and could use some updating.
04-12-10 06:20 AM
04-12-10 10:21 AM
04-12-10 05:21 PM
04-21-10 09:35 PM
07-01-10 03:38 AM
I find your post 100% true when it comes to UD5 but I managed to made my rig stable @ 4.01ghz using this settings below. Hardware specification is in my sig.
Hope this helps...
Advanced CPU Features:
CPU Clock Ratio ................................19
Intel(R) Turbo Boost Tech .................Disabled
CPU Cores Enabled ..........................All
CPU Multi Threading ..........................Enabled
CPU Enhanced Halt (C1E) ................. Disabled
C3/C6/C7 State Support ................... Disabled
CPU Thermal Monitor .......................Disabled
CPU EIST Function ............................ Disabled
Virtualization Technology .................Enabled
Bi-Directional PROCHOT ....................Enabled
Uncore & QPI Features:
QPI Link Speed ................................x36 (7.59 ghz)
Uncore Frequency ..........................x16 (3376 mhz)
Isonchronous Frequency ............... Enabled
Standard Clock Control:
Base Clock (BCLK) Control .................. [Enable] Enabled
BCLK Frequency (MHz) .........................211
PCI Express Frequency (MHz) ............. 101
Advanced Clock Control:
CPU Clock Drive ..............................700
PCI Express Clock Drive ................ 700
CPU Clock Skew ............................ 0
IOH Clock Skew ............................. 0
Advanced DRAM Features:
Performance Enhance .......................... Standard
Extreme Memory Profile (X.M.P) ........... Disabled
System Memory Multiplier (SPD) ........... 8x
DRAM Timing Selectable (SPD) ............. Quick
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ..................9
tRCD ......................................9
tRP ........................................9
tRAS ......................................24
CR..........................................1
Advanced Voltage Control:
Load Line Calibration .................... Level 1
CPU Vcore 1.08750 ........................ Normal
Dynamic Vcore Adjust (DVID)............[0.000] +0.200
QPI/VTT Voltage 1.200v ................ 1.240v
CPU PLL 1.800v ..............................[1.80] 1.84
PCIE 1.500v ................................... Normal
QPI PLL 1.100v .............................. Normal
IOH Core 1.100v ............................ Normal
ICH I/O 1.500v ............................... Normal
ICH Core 1.1v ................................ Normal
DRAM
DRAM Voltage 1.500v ................ 1.60v
DRAM Termination 0.750v........... 0.80
Ch-A Data VRef. 0.750v ............... 0.80
Ch-B Data VRef. 0.750v ............... 0.80
Ch-C Data VRef. 0.750v ................ 0.80
Ch-A Address VRef. 0.750v ........... 0.80
Ch-B Address VRef. 0.750v ........... 0.80
Ch-C Address VRef. 0.750v ........... 0.80
08-16-10 11:39 PM
