Global Win CAK II 38 and CAK II 16
Add Your Comments
One very good, one to skip. — Joe
SUMMARY: Global Win CAK II 16 – don’t like the fan; CAK II 38 – very good performance, annoyingly loud Delta 38 fan.
GW CAK
60 x 60 x 60; Weight: 440 gm; Fan: 38 cfm @ 7000 rpm or temp controlled.
Global Win was nice enough to send samples of their all copper, skived heatsinks, models CAK II 16 and CAK II 38. They use exactly the same heatsink but with different fans. I’ll cover this shortly, but first, let’s take a look at the heatsink itself:
Fins
Skiving is a technique whereby the fins are literally shaved off the base – there are no solder joints, it’s all one solid piece. This is a new technique developed in Japan and we’re seeing a lot of new heatsinks using this technology.
The base
Base
is fairly smooth – no discernable machining marks.
This is exactly the same as the CAK II 38 except it uses a temperature controlled fan:
Fan
The little blue bulb hanging off the side is the thermistor. As air heats up, the fan speeds up. For overclockers, this presents a problem: If your case airflow is good and close to ambient temp, the air entering the fan is going to keep this fan from speeding up to what might be required.
For example, if you’re running Quake intensively, you want the fan to speed up as the CPU heats up. But if air entering the fan does not heat up, the CPU will but the fan won’t speed up. There should be some feedback as the heatsink heats up, but I don’t think you will see a 1:1 correlation.
The Hair Dryer Test
To find out the temp curve, I ran the fan on an Iwill XP333 fan header while aiming a hair dryer at the fan’s intake. I taped a thermocouple next to the thermistor and read temps with the Omega Digital Thermometer while recording rpms as reported by MBM. I found the following:
Temp C
RPM
16
Did not register
29
4000
31
4500
35
5100
65
6666
My concern then is that this design is inherently flawed. I certainly could not get the fan to speed up much when I had the CAK II 16 on the Die Simulator, and I was not about to mount it on a CPU in that state. If you’re handy, you could clip the thermistor off the fan and maybe mount it at the heatsink’s base – this could work better.
Bottom Line: I can’t see anyone using the CAK II 16 for serious CPU cooling, and I would be hard pressed to use it on even a “normal” system. I don’t think temp controlled fans such as this are suitable for CPU cooling.
The CAK II 38 is a different animal – it sports a Delta 38 (or clone) fan with its attendant noise level. I measured its noise at 68 dBA with a Radio Shack sound meter 8″ from the fan’s intake (nb: This is not the same as manufacturer’s sound ratings, which are usually taken 3 feet away).
THE TEST
The CAK II 38 was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. Tests then were conducted on a variety of motherboards as examples of what users might see on their systems.
TEST RESULTS – CPU Simulator
Platform
Die Temp
Ambient Temp
Delta
C/W
Simulator, 77.1 Watts
46.1 C
19.2 C
26.9
0.35
TEST RESULTS – Motherboards
CPU/Motherboard
CPU Die Temp
Ambient Temp
Delta
C/W
CPU Back Temp
Palomino 1200/Iwill KK266+ (56 watts)
31.8 C
20.0 C
11.8
0.22
33.4 C
XP @ 1467, Shuttle AK31 (65 watts)
35.4 C
18.2 C
17.2
0.26
31¹
¹MBM socket diode temp.
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU core temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the CAK38 in the upper ranks of heatsinks (Heatsink Ranking) – a very good showing.
CONCLUSIONS
Very good performance but, as with many others, at the expense of your hearing and peace of mind.
Email Joe
Leave a Reply
