G.Skill Pi DDR3-2400 4GB Memory Kit Review
My first experience with G.Skill RAM was as a moderator of the (dearly departed) abit forums. They. Just. Work. We’d recommend them all the time because once you set the BIOS properly, you were done.
Back then there weren’t a lot of high performance G.Skill options. This was before the Trident or Ripjaws series and even the Pi series was brand new. Their choices were basically red, blue, lighter blue & black. Since that time, G.Skill has come a long way and has established themselves as one of the premiere manufacturers of low- to high-end RAM.
In an Overclockers.com exclusive, the kit we’re looking at today is one of their highest, the Pi series DDR3-2400 4Gb kit, model # F3-19200CL9D-4GBPIS.
Packaging, Specifications & First Impressions
Since this kit comes with a fan, it arrives in a larger cardboard box instead of the usual thin, shiny G.Skill box. It’s understated, especially for what’s inside, but a box is a box and is far from any great concern. What it does is protect the memory and its accompanying fan well.
Box Top
Box Top
Box Side With Info
Box Side With Info
Opened Up
Opened Up
As you can see in the photos, this kit is designed for a niche market – namely those with a P55 board and either an i7 860 or i7 870 CPU. The upcoming i7 880 can most likely be added to that list as well.
The reason for this limitation is the memory multipliers. For example, using an i5 750, the memory multiplier will top out at at 10x as opposed to the i7′s 12x. In order to run the rated DDR3-2400 with an i5 750, you’d have to hit a crazy high BCLK of 240. Good luck with that on anything less than liquid nitrogen.
The kit’s specs from G.Skill’s web site are:
  • Main Board: Intel
  • System: Desktop
  • System: Type DDR3
  • M/B Chipset: Intel P55
  • CAS Latency: 9-11-9-28-2N
  • Capacity: 4GB (2GBx2)
  • Speed: DDR3-2400 (PC3 19200)
  • Test Voltage: 1.65 Volts
  • PCB
  • Registered/Unbuffered: Unbuffered
  • Error Checking: Non-ECC
  • Type: 240-pin DIMM
  • Warranty: Lifetime
Qualified Motherboards List
  • ASUS Maximus III Formula(Since BIOS 1204)
  • ASUS P7P55D Deluxe(Since BIOS 1207)
  • EVGA EVGA P55 FTW 200(Since BIOS A51)
  • Gigabyte P55A-UD6(Since BIOS F6)
  • Gigabyte P55A-UD5(Since BIOS F5)
  • MSI P55 GD65(Since BIOS 1.6B3)
*G.Skill guarantees 2 Dimms dual channel operation with attached fan would reach announced specification.
The first thing that jumps out is the Qualified Motherboards List. This puts these even further into a niche market than the CPU limitation. They might work on some boards that aren’t listed but it’s not guaranteed. For instance, the board used in this review is an EVGA P55 FTW (not the 200 model) running BIOS A59.
Timings aren’t as tight as sticks at slower speeds, but sometimes you must sacrifice a little in timings to gain a little in MHz, as anyone that’s ever overclocked memory well knows.  Let’s see how they look!
Pulling the memory out, we are met with a rather nice looking fan and some stunning yet ominous looking black and dark blue memory. The heat spreaders are tall, but not insanely so (Kingston HyperX beats these in height by just under 1/4″). They are adorned with G.Skill’s symbol of choice for their top of the line memory – Pi (π).
Memory and Fan
Memory and Fan
With Specs Showitng
With Specs Showitng
They certainly look nice installed too. The fan is extremely quiet and is inaudible next to the noise of all the other fans in this system turned down to their normal levels.
Installed
Installed
Installed .... In the Dark
Testing and Performance at Rated Speed
This is the first in what we hope will be a series of memory reviews. This particular kit is rated at DDR3-2400 with timings of 9-11-9-28, so we’re definitely starting off with a bang!
Before performance testing, let’s look at stability. Ultra-X has generously supplied their RAM stress tester, the R.S.T. Pro 3 PCI Express. There are only a couple review sites that have one of these and we are proud to be one of them. It’s not your standard Memtest++ bootable CD. This is a standalone, bootable piece of hardware that plugs into a PCIe x1 slot and, man, does it ever beat on some RAM. By the time it was done, these sticks were hot, even with the case side panel off and the supplied fan blowing air on them.
Several manufacturers use this to test their memory before it goes out the door to reduce RMAs. If it passes this test, it is stable and then some. Manufacturers generally run the full memory test for three passes. We’re overclockers though and tend to abuse sticks a little more than other people, so for our purposes, doubling the manufacturer’s requirement sounds good.
These sticks were set to their rated speed using the 12x multiplier at 200BCLK with timings 9-11-9-28. vDIMM was 1.65V as specified and VTT was set at 1.4V. They made it through all six passes with zero errors. Well done G.Skill!
Now let’s see how they perform, shall we? To establish a baseline, the sticks already in this system, a 4GB set of G.Skill Trident DDR3-2000 with timings 9-9-9-24, were run through a battery of benches. Every benchmark was run three times and the best score is reflected in the results below.
Obvious anomalies, if they existed, were tossed and the bench was run again. The only tests that happened on were the everest read/write/copy tests, when the result glitched to about 10,000MB/s over every other run. This only happened once, but should be mentioned in the interest of full disclosure.
All tests were run with the CPU at 4.0GHz (200BCLK x 20) and RAM set to its rated speed and timings. The rest of the system in question consists of:
  • CPU: Intel i7 860
  • Motherboard: EVGA P55 FTW
  • GPU: HIS HD4890 Turbo
  • PSU: Corsair TX650
  • OS for stock testing: Windows 7 Professional x64.
  • OS for overclocking: Vista Enterprise x86.
3D Performance
To start, we’ll have a look at how memory affects 3D performance by running every 3DMark from 01 to Vantage.
3DMark Graph
3DMark Graph
I assumed the effect would be relatively small and it turns out that assumption was correct. So small, in fact, that the percentage change ranges from -1.78% to +0.07%. Basically a rounding error at best. The largest discrepancies came in 3DMark06 (-1.35%) and 3DMark Vantage (-1.78%), in which the higher frequency but loosened timings actually lost out a little bit.
Rendering & Compression Performance
For some “real world” testing I used Cinebench R10 64-bit to test graphics rendering & WinRAR for compression performance.
Cinebench
Memory Score Percent Change
G.Skill Trident DDR3-2000 23419 n/a
G.Skill Pi DDR3-2400 23354 -0.28%
This one was a bit more of a surprise until thinking about it. The image rendered isn’t that large in size, so this one’s less of a memory test than a CPU test.
WinRAR
Memory KB/s Percent Change
G.Skill Trident DDR3-2000 4345 n/a
G.Skill Pi DDR3-2400 4504 3.66%
There we go, finally a substantive difference and one that goes in favor of MHz over timings too. 3.66% doesn’t sound like much, but if you were compressing something that’s 10GB, you’d save 1 minute, 42 seconds (but it would still take over 38 minutes at 4,504KB/s).
Synthetic Number Crunching Performance
Here we’ll have a look at how each kit performed when running benchmarkers’ favorites SuperPi 1M, SuperPi 32M, WPrime32M & WPrime 1024M.
SuperPi 1M
Memory Time (Seconds) Percent Change
G.Skill Trident DDR3-2000 10.477 n/a
G.Skill Pi DDR3-2400 10.422 -0.52%
SuperPi 32M
Memory Time (min:sec) Percent Change
G.Skill Trident DDR3-2000 9:21.109 n/a
G.Skill Pi DDR3-2400 9:15.844 -0.94%
Not a bad reduction really, considering it was the same CPU speed. If the timings were, say, 9-9-9, the difference would have been a bit more noticeable, especially in SuperPi 32M. That said, a six second difference in 32M scores is easily the difference between first & third. Not a bad gain at all for just swapping RAM out!
WPrime 32M
Memory Time (seconds) Percent Change
G.Skill Trident DDR3-2000 6.378 n/a
G.Skill Pi DDR3-2400 6.390 0.19%
WPrime 1024M
G.Skill Trident DDR3-2000 193.383 n/a
G.Skill Pi DDR3-2400 193.398 0.01%
WPrime was a little bit of a surprise. There was hardly any difference at all, with the greatest coming in 32M. Looks like WPrime prefers tighter timings to raw MHz, but even then you’re talking just over a hundredth of a second.
Everest Bandwidth & Latency Results
Everest’s full memory suite was run, consisting of read, write, copy & latency tests.
Everest Read
Memory Speed (MB/s) Percent Change
G.Skill Trident DDR3-2000 19414 n/a
G.Skill Pi DDR3-2400 20869 7.49%
Everest Write
G.Skill Trident DDR3-2000 15787 n/a
G.Skill Pi DDR3-2400 15827 0.25%
Everest Copy
G.Skill Trident DDR3-2000 22662 n/a
G.Skill Pi DDR3-2400 23285 2.75%
Everest Latency
Memory Latency (ns) Percent Change
G.Skill Trident DDR3-2000 37.7 n/a
G.Skill Pi DDR3-2400 35.5 -5.84%
In the everest suite you can see a very significant increase in write speed with a healthy increase in copy speed and strong reduction in latency. Write wasn’t quite as strong as the rest of the results, but no ground was lost anywhere.
The results above were obtained from running the individual tests three times & taking the best, but some people like the Everest quick bench, so here they are side by side.
Trident Cache & Mem Bench
Pi Cache & Mem Bench
Overclocking
This kit was an absolute blast to overclock. No insane voltages were used (max 1.45V VTT & 1.72V vDIMM) and unfortunately there wasn’t enough time to tweak every single timing / MHz out of them. This is the result of only a few nights’ overclocking. You can spend countless hours testing different timing / speed combinations. These are just rough results I was able to get in the meager hours I had to play with them before writing this review.
I focused mainly on the old favorites SuperPi & WPrime for overclocking since they were quick & showed the most promise. First we’ll see how tight the timings can be cranked down when reduced to DDR3-2000 speeds and running 1.68V with CPU speed maintained at 4.0GHz.
Tightened Timings
Tightened Timings
Wow. DDR3-2000 at 6-9-8-24 with barely above default vDIMM! That’s crazy talk. It’s not just bootable either…this was stable through SuperPi 32M, Wprime both 32M and 1024M and even a MaxxMem thrown in there. (Maxxmem will be used in all memory reviews from now on, it just didn’t make the default results above for this kit.) Note I did have to manually set the strap to 1600MHz to begin cranking the timings down. They don’t seem to like tighter straps when you’re tightening timings.
Now let’s see just how far we can push the MHz! Stability was not a concern here. The goal was to see how high they could run SuperPi 1M and validate. Timings were default 9-11-9-28, vDIMM was set at 1.72V and VTT was 1.4V for this run. It wouldn’t quite boot at this speed, but we could use EVGA’s eLEET and crank the BCLK up once booted.
Max Frequency
Max Frequency
Amazing is the only way to describe it, simply amazing. DDR3-2626 without loosening up timings or running crazy voltages! Here’s the CPUz validation.
Pi Valid DDR3-2626
Pi Valid DDR3-2626
This is stronger than I ever expected. A full 113MHz overclock, without high voltages and with relatively tight timings. Simply incredible.
So what does this mean for overclockers really? What if you can’t reach that kind of bclk with your system? It means you have memory that will go as far as you need it go to. No longer do you have to be held back by memory that just won’t reach where you need it to. No longer do you have to reduce your memory multiplier in BIOS unless you’re running crazy BCLK on sub-zero. Here’s what it meant to this setup:
Sub-9 SuperPi Run
Sub-9 SuperPi Run
It meant this CPU could be pushed as far as it would go (with a self-imposed limit of 1.5Vcore set in BIOS) and not have to worry about memory interfering. (The time would be even better if I was in XP, but that’s a long story.) It’s truly a great feeling to have that monkey off your back when reaching for the bleeding edge of stability!
Conclusions
Let’s face it. No one is going to run to Newegg and spend $229.99 on a 4GB set of memory to set it and forget it. These are tailor made for overclocking…and overclock they do! It also would seem G.Skill is the first to get a set of DDR3-2400 for sale at the Egg. Considering the number of memory manufacturers that sell there, that’s a pretty good feat in and of itself. Here’s the bottom line:
Pros
  • One of the highest-rated kits on the market in terms of sheer MHz.
  • Respectable timings.
  • Rock solid stable performance at rated speed and then some.
  • Timings can be cranked down pretty hard at DDR3-2000.
  • MHz overclocking at rated timings and barely over rated vDIMM of over DDR3-2600!
Cons
  • The only con I can think of for this kit is its rated timings. Getting a kit rated any lower may just be an overclocker’s pipe dream though…so don’t consider this as much of a con.
If you are running on a P55 platform and want to get some memory that will never hold you back, this kit is for you. Run, don’t walk, on over to Newegg and buy yourself a pair. You will most definitely not be disappointed. I’m happy to say that this kit is very emphatically Overclockers Approved!
- Jeremy Vaughan (hokiealumnus)
  1. Patriot Sector 5 DDR3-2400 4GB Memory Kit Review
  2. Kingston HyperX DDR3-2000 4GB Memory Kit Review
  3. Preview – G.Skill Ripjaws Z DDR3-2133 Memory Kit
  4. G.Skill Ripjaws Z DDR3-2133 Quad Channel Memory Review
  5. G.Skill RipjawsX DDR3-2133 8GB RAM Review
Tags: , , , , , , ,
1 Comments:
MattNo5ss's Avatar
Great review!
I have the DDR3-2000 (6-9-6-24) set, and the heat spreaders are definitely a con for air cooling:
The G.Skills are so tall I had to mount my Venomous X off-center of the CPU.
Leave a Comment
