Heatsink Simulations
Add Your Comments
(Ed.note: You’re going to see some lopsided pictures; those using smaller resolutions may have to scroll. Normally I resize them, but
if I did that in this case, you simply couldn’t read any of the graphs)
I’ve worked out some possibilities for cooling CPU’s.
I’m an master-engineer in metallurgy, so i have access to some good simulation
software for this problem. (FEMLAB, which works under MATLAB)
First, some assumptions:
  • The CPU produces 100W on a 1cm^2 surface and have internaly a infinitely high
    thermal conductivity.
  • The heatpaste is not a notable bottleneck in removing the heat. (A few
    degrees C don’t matter in the calculationes.)
  • The case is not a notable bottleneck in removing hot air.
    Now: we are only left with two bottlenecks: The thermal conductivity of the
    heatsink, and the thermal coefficient between the heatsink, and the air.
    As we know, less airspeed on the fins requires more surface for
    the air to flow over to remove the heat equally efficient. So I’m going to find
    out if the thermal conductivity of the heatsink is big enough to spread the heat
    out to a large enough surface.
    Since the needed surface area (on the fan side) of the heatsink is 1/(relative
    airspeed), I will only simulate the temperature differences in the heatsink itself.
    As a start, and to confirm I’m using the program correctly, I did a very simple
    calculation:
    A copper cube of 1cm^3, 100W flowing in from the top, and out at
    the bottom. The sides are isolated, so this is a very easy calculation to
    confirm by calculating by hand.
    The thermal conductivity of copper is 402W/(cm*K) and should give about 0,25 C difference between the bottom and top.
    The simulation looks like this:
    Calibration
    This looks correct with a 0.249 C temperature difference (mesaures in meters and
    degrees C)
    To make further calculations easier for this computer (I only have 256MB ram,
    and FAMLAB needs HUGE amouts of ram; wish I had a 1GB or so.); I’m going to
    divide the calculation in two parts: the heatspreader-base, and one of the fins
    connected to it.
    Heatsink
    OK, it’s just a sketch which is out of proportion.
    Email Simen in care of Ed
    Imagine the 1cm^3 “cube” of copper to be a part of the heatspreader and placed
    over the CPU-core. Now the cube would conduct heat out from the sides (to the
    surrounding material) Since the sides are bigger then the top, i would expect a
    lower temperature difference between the CPU-core and the top of the base.
    Surface Temperature at the bottom of the base
    Bottom
    Surface Temperature at the top of the base
    Top
    Temperature ISOs in the base
    Top
    Heatlines in the base
    Top
    Pretty? I love all these nice visualisations.
    Note that the temperature differences in the base is only about 0.1C.
    The fins? I assumed there is 20 of them on top
    of the base, each removing 5W. The dimentiones are 1x40x40mm, with 1 mm space
    between them. I also assumed equal heat removal (W/cm^2) all over the two sides. Here
    is one of the fins:
    Temperature of the Copper Fin
    Fin
    The temp-differance is 1.0C (I’m sorry i made it upside down, but the
    heat-physics still apply)
    If we sum it up, the total temperature difference in the heatsink would be 1.1C
    between the hottest point and the coldest. That’s not much at all.
    Even if we used aluminium, the temperatures wouldn’t rise much. Actually it proportional
    with the heat conduction: deltaT* (K Copper/K Aluminium) = 1.1C * (401/237) =
    1.9C.
    From this we learn that the heat conduction in the heatsink is not a big
    bottleneck in heat removal. It’s so small that i can assume the same
    temperatures in the whole heatsink for further calculationes.
    This shows that the major bottleneck in a cooler is the transport of heat from the fins
    to the flowing air.
    It’s not coincidental that an
    upgrade of the fan can lower the temperatures considerably, or by closing
    close the heatsink and letting water flow through it.
    Further Considerations:
    To optimise weight vs. cooling capability, I would
    have made these changes:
  • Made it in Aluminium (~1/3 the weight and ~1/2 the heat conduction)
  • Thinner base. (0.1C is not necessary, 0.5C would do fine)
  • Larger area of the base. 6x6cm or more? (to support more and bigger fins)
    If someone wants to make a totally fanless PC, airflow is a
    must. While natural convection can work, it needs a huge surface area, and
    thus a huge heat sink. Such huge heatsinks (30×30 cm or so) may work, if you
    have ok air circulation around it.
    The temperature drop in the heatsink it self
    will not be a huge problem. A few degrees C DeltaT in the heatsink is ok, but
    you need a huge surface area and good aircirculation. Altso, to make the
    convection as good as possible, the fins shuuld be placed vertically.
    I will do some calculations of a “new model” with new dimentions (6x6cm
    and 30x30cm. If i can figure out the aerodynamics and
    heatconductinon copling in FEMLAB (and get myself some more RAM) i might even
    come up with some actual simulations on a full heatsink and fan-combo, and a
    megaheatsink without a fan.
  • Leave a Reply
