Heatsink Testing Methodology
Add Your Comments
SUMMARY: After trying a number of different methods, looks like the tried-and-true AMD/Intel method coupled with back of the CPU readings gives the best picture.
I’ve spent the last two weeks immersing myself in heatsink testing methods. Andy Lemont at Millenium has been instrumental in this effort, along with John Carcich, Jim Fager, Stephen Hoar and Tillman Steinbrecher*. As a group of interested hardware testers, efforts are continuing at developing standardized testing methods so that you, the buyer, will have the best, objective testing to aid in purchasing decisions. We’ll report on progress periodically.
Omega HH23
The methodology I am using employs the following equipment:
  • Omega HH23 Digital Thermometer
  • Type T Thermocouple Wire
Thermocouple
Heatsinks are fitted with a thermocouple as follows:
  • The heatsink is positioned over the CPU and the center of the CPU core is marked on the heatsink base;
  • A 1/16″ hole is drilled through the heatsink base;
  • A thermocouple wire is epoxied into the hole with its tip exposed;
  • The heatsink base is lapped flat with 600 grit paper.
Heatsink Probe
Common pin shown on the left.
Once this is done, the thermocouple is positioned to read the CPU’s top case temperature; the only material between it and the CPU is the thermal grease used. The thermocouple is plugged into the Omega HH23 and the testing begins.
TEST PROCEDURE
There are two approaches one can take:
  1. Build a precision CPU heat simulator and run heatsinks on it;
  2. Use a “reference” board for live CPU testing.
I have adopted the second approach as I believe a motherboard test is closer to what users will experience when they install heatsinks. The CPU simulator also gives valuable information and results from such a test should be used in conjunction with “live” testing. I have found, for example, that back CPU temps can vary a great deal between two heatsinks even though they show similar CPU case temps.
As we test heatsinks, I will report the following:
  1. Heatsink Temps
  2. Back of CPU Temps
  3. Motherboard CPU Temps
  4. Ambient Temps
  5. Heatsink C/W
Back of CPU Temps are measured by a thermocouple epoxied on the back of the CPU used in the test. Motherboard Temps are those read out from the motherboard’s CPU thermistor, usually found in the CPU socket.
Heatsink C/W is measured by the following formula:
C/W = (Heatsink Temp – Ambient Temp) / CPU Watts
This measure gives the user an objective means to compare heatsinks against each other.
It’s really pretty simple – measure CPU temp (in Centigrade), subtract out ambient temp and divide by the CPU’s power output: C/W.
Once you know a heatsink’s C/W, you can then estimate the CPU’s temp rise under various loads; if you know watts and ambient temp (here temp at the fan intake), you plug them into the formula and it tells you how well this particular heatsink should cool the CPU. Simple.
The lower the C/W, the better the heatsink disposes of CPU heat. However, note that C/W will change if, for example, a higher cfm fan is used. Also note that at some point, any heatsink can become “saturated” with heat such that it will “hit the wall”. Heatsinks can only get rid of so much heat, and if you exceed its limits, it will get very hot – as will the CPU.
Therefor, as you review these test results, bear in mind that loading any heatsink above the tested range may yield very different results.
*Many, many, thanks to Andy Lemont at Millenium, Stephen Hoar at Burning Issues, Jim at Benchtest.com, Tillman Steinbrecher at Heatsink Guide and John Carcich for unstinting efforts and time on this issue.
For more details on heatsink testing see Heatsink Testing, Determining Heat Sink Efficiency Using Thermal Diode Temperatures, and AMD and Future Heatsinks.
Email Joe
Summary: Simulated CPU die testing may be the “purest” measure of heatsink performance.
Cu Block
I continually look to improve the heatsink testing we do. As another test, you will see results using a simulated CPU die (T-Bird size), pictured above.
The simulated die is made of copper and was made by a machine shop to simulate mounting a heatsink on a socket. The three tabs on each side correspond to the location of a socket’s lugs – this allows the same amount of pressure as when mounted on a motherboard.
In front of the block are the heaters used to simulate CPU temps. These are Minco #HK5578. I used four of these to better spread the load to the block. Arctic Silver epoxy was used to glue the heaters to the block’s base.
Cu Block Final
The block weighs about 1200 grams/2 ¼ pounds; there are thermocouples in the simulated die and base to check temps.
The heaters are powered by a Laboratory Power Supply capable of producing up to 180 watts – more than enough to stress a heatsink. In preliminary testing, I ran heatsinks up to about 130 watts.
In running this tester, all four heaters are wired together so that they are powered equally through the power supply. The block is encased in foam insulation to mitigate heat loss to the air.
Testing reveals that heatsinks will show higher C/Ws than those found using actual CPUs and motherboards. This is due to two factors:
  • All the heat from the power supply is concentrated in the block; there is very little heat loss from secondary heatpaths, in contrast to actual conditions, secondary heatpaths, such as through the CPU base, are significant cooling factors;
  • CPU heating by using a program such as Prime 95 may not fully power the CPU, whereas the simulator is fully powering the block.
The table below compares the two approaches:
Simulated Die vs Actual Motherboard Testing
Heatsink
Motherboard
Die
Ratio
Antec
0.39
0.58
1.49
Dynatron
0.19
0.28
1.47
Fortis A102
0.19
0.29
1.45
Tornado
0.30
0.40
1.33
Volcano
0.25
0.33
1.32
Simulated die testing is clearly higher. The variation in results between the two (the Ratio in the chart) is due to the factors mentioned above plus the interactions between the heatsink and motherboard, which vary from each heatsink. The relative rankings are similar, however.
Readers can use the simulated die results as the “worst case” performance for any heatsink; the real world tests are indicative of results users may expect under similar circumstances in “real world” use.
Email Joe
P4 Die
The block measures 120mm/4″ x 120mm/4″ x 130mm/ 1½” weighs almost 9½ pounds; thermocouples are located in the simulated die to measure temps.
I continually look to improve the heatsink testing we do. As another test, you will see results using a simulated P4 CPU die, pictured above. The simulated die is copper and was made by Andy Lemont over at Millennium Thermal to simulate a P4 CPU.
P4 Die Base
Epoxied to the base of the block are the heaters used to simulate CPU temps, Minco #HK5576. I used three of these to better spread the load on the heaters. I made thermal epoxy by mixing Cooling Flow thermal grease with five minute epoxy to glue the heaters to the block’s base.
The heaters are powered by a Laboratory Power Supply capable of producing up to 180 watts – more than enough to stress a heatsink. All three heaters are wired together so that they are powered equally through the power supply. The block is encased in foam insulation to mitigate heat loss to the air.
Foam
Encased in foam – more insulation to be added on top.
Temps are measured using an Omega Digital Thermometer with factory made thermocouples, one embedded in the die and one to measure air temps. It takes about an hour for the Die to reach stability, and then testing proceeds.
I’m testing the Die Simulator, but so far no surprises. It is “easier” to cool a larger die than the smaller one – no surprise, as the large die spreads heat over a much larger area compared to the fingernail size PIII and AMD CPUs.
Many thanks to Andy Lemont for milling this for me; I also was fortunate to have the Die’s top polished to a flat finish by KAF industries located in Stamford, CT. Fred Hartlett was nice enough to show me around while polishing the Die flat. If you have the chance to see a top-rate machine shop that does optically flat polishing, jump at it.
I saw a polishing machine that is air cushioned – the work is so precise that it must be damped from long wave vibrations (something like 4 cycles/sec) that can come from sources as much as five miles away.
Email Joe
Leave a Reply
