Hokiealumnus Live Benching Tonight
Add Your Comments
Overclockers writer and Benching Team member hokiealumnus (HWBot profile, author profile) , will be benching sub-zero live tonight!
Tune in to stage 1 at 8:45 p.m. EST (plus or minus 15 minutes) for some overclocking with dry ice (DICE). Here’s the low-down:
  • Mobo: ASUS Crosshair IV Extreme
  • CPU: AMD Phenom II x6 1090T Black Edition
  • RAM: 2 x 2GB G.Skill Flare DDR3-2000, 7-9-7-24
  • GPU: AMD HD6870
  • Cooling: Dry ice on the CPU, air on the GPU
  • Focus: Learning DICE, max CPUz, 2-D and some random 3D benches to see how this GPU scores with a cold CPU behind it.
  • Click here to watch on Stage 1
  • Date & Time: November 3, 2010, 8:45 p.m. EST (plus or minus 15 minutes)
    • Benching will wind down between 11:00 p.m. and 12:00 a.m.
Hope you can stop by and root him on!
splat
Leave a Reply
Discussion
  1. MattNo5ss
    I'm gonna guess it was to see the bottom of the pot.
    Considering the length of the pot and the speed of light, it still probably took ~3s for the bottom to illuminate...
    :rofl:
    Lets you see how the dice slurry is going. It's worth doing if you're going hardcore.
    (Note: If you aren't powdering the dice, you aren't going hardcore, so forget it)
    Yea, they were renamed to that prior to uploading. In fact, I was sure to save with the .cvf extension to avoid that being an issue. Guess next time I won't rename the file when saving. Grr.
    Yeah, you have to have the ".cvf" at the end of the name, I figured that out when I started... It took me forever to realize what was wrong...
    Hope you had fun, sorry I couldn't make it.
    great stuff jeremy :thup:
    i am glad to hear you had a successful bench session! remember though, phenoms love cold... so until you get into some ln2 i don't think you will see anything higher than 5.5ghz.
    Dolk will have access to ln2 at the party even if his dewer isnt in by then. So enjoy for the next 2 weeks.
    but very nice results once again. especially being your first time cold. I dont think anyone could have expected more. and you didnt even drop the cores for the supi runs, that may leave alittle more for you to work with even witout ln2.
    Ok, submitted everything to the bot and didn't get much, though this isn't really high-boint equipment anyway. Hardware boints - 9.1. Global boints - 2.4. Total - 11.5.
    On the plus side, as it has been a while since I had anything worth submitting, that put me back over the 100 boint mark. :)
    Nah, didn't try max FSB. Should have though, since the next trip cold will be on the 1075T and I'll need it.
    Oops.
    The CPUz validation I didn't get was right at that screenshot, 5518 IIRC. I also validated lower, at a more stable 5496...and that one was corrupted too. I call shenanigans. :bang head
    It was definitely a blast and will not be my last time sub-zero! Thanks to everyone that made it by, your advice helped a lot. Sorry there was no entertaining music or anything, but sleeping kid > good music. :)
    EDIT - Oh, right...I almost forgot to mention that until Dolk gets his dewar, I have him beat on SuperPi and both WPrimes. :D
