Hydor Seltz L30
Medium flow waterpump – Joe
SUMMARY: Cost effective waterpump for medium flow systems.
Pump
Power consumption: 23 watts (US version); Fittings: 1/2″OD (13mm); Dimensions without fittings: 4.5″ (114mm) x 3″ (76mm) x 3.5″ (89mm) height.
The good guys at Cooltechnica were nice enough to send over a waterpump from a manufacturer I had not known called Hydor. They are an Italian company which produce a full line of aquarium, fountain and pond pumps. The model Cooltechnica sells is the Hydor Seltz L30.
Hydor L30 is suitable for either inline or submersible use – personally, I prefer inline – it results in a more compact installation. The performance curve starts at 336 gph @ 0′ head:
  1. Pump-Off
  2. Mitron Waterblock, Radiator and Reservoir
  3. Waterblock Testing
  4. Aqua Joe Watercooling Kit – Preliminary Test
  5. Fuel Pump Water Pump
Tags:
