Icy Box 2.5″ HD Enclosure
Attractive unit for portable data transfers – light and small – Joe
SUMMARY: Attractive unit for portable data transfers – light and small.
Pic
The good guys at Tagan were nice enough to send a sample of their 2.5″ HD external storage unit – the drive is protected by an attractive stainless steel case with a very nice graphic.
Key Features:
  • Stainless Steel body
  • LEDs for Drive Activity (red) and Power light (green)
  • Size 137 x 80 x 12 mm, weight 135 grams
  • Includes USB data and power cables, Manual, Vinyl carry case, screwdriver, polishing cloth and Driver Disk if needed
Pic
The back of the unit features an On/Off switch, power port and USB prot – the unit ships with a USB cable that can be used to power the drive from a USB port – I found that I did not need to use this as the power from my laptop’s USB port was sufficient to power the enclosure.
Pic
The top case slips off easily – it’s held in place by four small screws. Pop the drive in and you’re done – very simple!
Pic
The heart of the unit – a small PCB held in place by two screws:
Pic
Performance Test
I tested the enclosure’s transfer rate with an IBM Travelstar 4200 rpm 40 GB IDE HD – results will vary by type of HD used.
Pic
Performance is typical for USB ports – fast enough for routine data transfer.
CONCLUSIONS
IcyBox’s 2.5 HD Enclosure is an attractive unit for portable data transfers – light and small enough to throw into a briefcase or pocket.
Thanks again to Tagan for sending this our way to try out.
  1. Icy Box 3.5″ HD Enclosure
  2. Kingwin Portable 5.25″ Aluminum Hard Drive Enclosure
  3. IcyDock 2.5″ HD Enclosure
  4. Kingwin F-35 3.5″ SATA HD Enclosure
  5. Vantec NexStar SX 2.5″ HD Enclosure
Tags:
