Innovatek X-Flow
Add Your Comments
Waterblock Test – Joe
SUMMARY: Good choice for CPU cooling, but requires a high power waterpump to hit 1 gpm water flow – optimized for ¼” fittings.
Xflow
The good guys at High Speed PC were nice enough to send a Innovatek X-Flow waterblock to test (Go HERE for Innovatek’s website).
Innovatek’s X-Flow features
  • 8mm/¼” (OD) compression fittings
  • Weight 370g
  • Size 65 x 60 x 16 mm
  • Copper base 9mm thick
  • Extruded aluminum top
What I found interesting is this characterization of the X-Flow:
“The X-Flow achieves maximum performance due to a new and revolutionary flow guidance design within the interior of its compact dimensions. A unique turbulence principle makes optimal utilization of the cooling agent possible without cross-section contraction. Therefore, this water block does not create any back pressure nor stress the water pump.” (my emphasis)
I’m not quite sure I would agree with this statement, as you’ll see that the pressure drop to get 1 gpm through this block is quite high. A high pressure drop is to be expected as the 8mm compression fittings will exact a toll on flow rate – really no surprise here, although the blurb from Innovatek might lead you to think otherwise.
In addition, if you look inside (which I do not recommend – it’s a real pain to get the “O” ring set right), you’ll see that the interior design is quite restrictive:
Xflow Inside
The thumb print is free with the block.
The channels sit 180º from each other, so water has quite an involved path to the outlet. Couple this with ¼” fittings and you get a good idea of why the pressure drop is very high.
The base shows slight signs of polishing marks:
Base
They are not apparent to the touch.
THE TEST
The Innovatek X-Flow was tested using the CPU Die Simulator and Waterblock Test Rig.
WATERBLOCK TEST RESULTS
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds; Heat Load: 70 Watts.
Plot
Waterblock
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
Innovatek X-Flow
0.15
2.65
73.4
NOTE: These results are NOT comparable to tests done by others.
Unrounded data: 0.154 C/W with 0.0009 std dev.
Test Results indicate that the X-Flow’s pressure drop (or head loss) across the waterblock is quite high; high flow resistance such as this is not surprising given its ¼” fittings and the restrictive interior design. This means that Innovatek’s X-Flow requires a fairly large waterpump to hit a 1 gpm flowrate, although it is designed for lower flow systems.
However, I ran a test at 0.5 gpm and found the impact to be less than 1ºC, not terrible by any means.
For a comparison of the X-Flow’s performance to other waterblocks tested to date, see Overclockers.com Waterblock Test Results.
CONCLUSIONS
Innovatek’s X-Flow waterblock is a good choice for CPU cooling, although extracting performance will take a very good waterpump. However, if other components unduly restrict waterflow, flow through the system could be considerably less than 1 gpm – this is not a waterblock to use in series with a GPU and/or Northbridge waterblocks.
For users with systems using ¼” tubing and fittings, Innovatek’s X-Flow waterblock is a fine choice.
Thanks again to High Speed PC for sending this our way.
Email Joe
Leave a Reply
