Intel i7 5775C Broadwell CPU Review
Keeping with their Tick-Tock model, Intel’s latest “Tick” CPU comes in the form of the i7 5775C. As is the case with “Tick” releases, we have a new manufacturing process that advances the Haswell 22nm manufacturing process to Broadwell’s 14nm. The Broadwell desktop CPUs will work on any Z97 chipset motherboard, provided the appropriate BIOS update has been made available. This release also marks the first time Intel has included the Iris Pro graphic solution on an unlocked desktop processor or even in an LGA package for that matter. So, let’s dive in and see what this latest Intel processor is all about.
Specifications and Features
Intel’s target market for the i7-5775C processor is the content creator and gamer who enjoys media creation, vivid 3D gameplay, and overclocking performance options. As you can see by the specifications below (provided by Intel), the base and turbo frequencies are quite a bit lower than the i7 4790K, but the Iris Pro 6200 graphics should be a huge improvement over previous Intel desktop processors. The 65 watt TDP and Iris Pro 6200 graphics definitely make the i7 5775C an attractive option for small and thin form factor desktops such as a HTPC.
Intel i7 5775C Specifications
# of Cores4
# of Threads8
Clock Speed3.3 GHz
Max Turbo Frequency3.7 GHz
Instruction Set64-bit
Instruction Set ExtensionsSSE 4.1/4.2, AVX 2.0
Lithography14 nm
TDP65 W
Thermal Solution SpecPCA 2013D
Memory Specifications
Max Memory Size32 GB
Memory TypesDDR3L-1333/1600
# of Memory Channels2
Max Memory Bandwidth25.6 GB/s
ECC Memory SupportNo
Graphics Specifications
Processor GraphicsIntel Iris Pro Graphics 6200
Graphics Base Frequency300 MHz
Graphics Max Dynamic Frequency1.15 GHz
Graphics Video Max Memory1.7 GB
Graphics OutputDP/HDMI/VGA
Execution Units48
Max Resolution HDMI2560×1600@60Hz
Max Resolution DP4096×2304@60Hz
DirectX/OpenGL Support11.2/4.3
Intel Quick Sync VideoYes
Intel InTru 3D technologyYes
Intel InsiderYes
Intel Wireless DisplayYes
Intel Flexible Display InterfaceYes
Intel Clear Video HD TechnologyYes
# of Displays Supported3
Expansion Options
PCI Express Revision3.0
PCI Express ConfigurationsUp to 1×16, 2×8, 1×8+2×4
Max # of PCI Express Lanes16
Intel Data/Platform Protection Technology
AES New InstructionsYes
Secure KeyYes
OS GuardYes
Trusted Execution TechnologyNo
Execute Disable BitYes
Anti-Theft TechnologyYes
During Computex 2015, Intel announced the release of five 65 watt Broadwell processors – two are LGA (socket) package type and three are BGA (soldered) package type. The majority of our readers will be interested in the LGA package type to use in existing Z97 chipset motherboards.
intel_cpu
Looking at the CPU die map, we see a couple interesting things going on. The most obvious being the Iris Pro 6200 graphics processor taking up half the die size. The full GT3e configuration of 48 Execution Units the Iris Pro 6200 graphics offers is more than double of that found on Intel’s HD4600 graphics solution. The 128 Mb of eDRAM sits on its own package and is shared by the CPU cores and Iris Pro graphics. However, installing a discrete graphics card will free up all 128 MB for the four CPU cores.
intel_i75770c (1)
The list of key features are provided below and are courtesy Intel. Other than the Iris Pro 6200 graphics, we also have Turbo Boost 2.0 up to 3.7 GHz, 6 MB of shared cache, which is down from the 8 MB found on the i7 4790K. However, the embedded cache (eDRAM) should more than cover that aspect. The i7 5775C supports overclocking of the CPU cores, memory frequency, and the graphics processor.
Intel® Core™ i7-5775C Processor Key Features:
  • 8-Way Multi-Task Processing: Runs 8 independent processing threads in one physical package.
  • Intel® Iris™ Pro Graphics 6200: Offers the best Intel® processor graphics with embedded cache (eDRAM) for the
    stunning visuals and media experience.
  • Intel® Turbo Boost Technology 2.0: Dynamically increases the processor frequency up to 3.7 GHz when applications
    demand more performance. Speed when you need it, energy efficiency when you don’t.
  • Intel® Hyper-Threading Technology: Allows each core of the processor to work on two tasks at the same time
    providing unprecedented processing capability for better multi-tasking, and for threaded applications.
  • Intel® Smart Cache: 6MB of shared cached allows faster access to your data by enabling dynamic and efficient
    allocation of the cache to match the needs of each core significantly reducing latency to frequently used data and
    improving performance.
  • CPU Overclocking Enabled (with Intel® Z97 Chipset),2: Fully unlocked core multiplier, power, base clock and DDR3
    memory ratios enable ultimate flexibility for overclocking.
  • Graphics Overclocking Enabled (with Intel® 9 Series Chipset) 3: Unlocked graphics multiplier allows for overclocking
    to boost the graphics clock speed.
  • Integrated Memory Controller: Supports 2 channels of DDR3-1600 memory with 2 DIMMs per channel. Support for
    memory based on the Intel® Extreme Memory Profile (Intel® XMP) specification2.
  • Chipset/Motherboard Compatibility: Compatible with all Intel® 9 Series Chipsets with the latest BIOS and MCU.
  • Built-in Visuals3: Enhanced built-in visual features deliver a seamless visual PC experience for doing everything from simple e-mail to enjoying the latest 3D and HD entertainment. The built-in visuals suite includes:
    -Intel® Quick Sync Video Technology:Media processing for incredibly fast conversion of video files for portable media players or online sharing.
    -Intel®InTru™3D: Stereoscopic 3D Blu-ray* playback experience in full HD 1080p resolution over HDMI 1.4 with 3D.
    -Intel® Clear Video HD Technology: Visual quality and color fidelity enhancements for spectacular HD playback andimmersive web browsing.
    -Intel® Advanced Vector Extensions 2.0 (Intel® AVX 2.0): Increased performance for demanding visual applications like professional video & image editing.
The following slides go into more detail about the Broadwell desktop processors and what they offer. As you can see, the big ticket item is the Iris Pro 6200 graphics making its debut on a socketed LGA package. Past that, the 65 watt TDP, 14nm manufacturing process, and compatibility with current Z97 motherboards are all worth mentioning. For those who currently own Z87 chipset motherboards, unfortunately, motherboard manufacturers are not likely to devote the resources necessary to provide firmware updates to that series. With the release of Skylake just around the corner, most of their time is being spent developing the new 100 series chipset motherboards. All slides below courtesy Intel.
intel_i75770c (2)
intel_i75770c (3)
intel_i75770c (4)
intel_i75770c (5)
intel_i75770c (6)
intel_i75770c (7)
intel_i75770c (8)
intel_i75770c (9)
Product Tour
As is typical with the Intel sample CPUs we receive, they arrive in a small black box with a couple foam inserts to protect the processor. There isn’t too much to look at here other than the IHS and bottom contact points that allow usage in the socket 1150. The thermal solution specification calls out the PCA 2013D design, which is the same as used on the i7 4770K. If you remember when the i7 4790K was released, it called out the PCG 2013D thermal solution that was supposed to offer cooler temperatures. Given the much lower TDP of the i7 5775C, I doubt reverting back to the PCA 2013 thermal design will hurt much, if at all.
i7 5775C in a Box!
i7 5775C in a Box!
IHS Side Up
IHS Side Up
Contact Points
Contact Points
Benchmarks
For the purpose of comparison, we’ll use two previous socket 1150 processors in the i7 4790K and i7 4770K. We’ll also throw in results from the i7 5960X, which will obviously dominate the multi-threaded CPU based testing. When we get to the iGPU comparison, we’ll add results from the AMD Kaveri A10-7850K. We don’t yet have the AMD Godavari A10-7870K; but from what we’ve seen, the Godavari only provides a couple FPS more on average than the A10-7850K – and that’s at medium-level game settings. All of our gaming benchmarks use maximum settings, so that difference is likely to be even less between the A10-7850K/7870K APUs. Here is a look at the components used in the comparison systems.
i7 5775C / i7 4790Ki7 4770Ki7 5960X
MotherboardASUS Maximus VII FormulaASUS Maximus VI FormulaASUS X99 Deluxe
MemoryG.Skill TridentX 2X8 GB 2400 MHzG.Skill TridentX 2X8 GB 2400 MHzG.Skill Ripjaws4 4X4 GB 3000 MHz
HDDSamsung 840 EVO 500 GBSamsung 840 EVO 500 GBSamsung 840 Pro 256 GB
Power SupplyCorsair HX1050Corsair HX1050Corsair HX1050
Video CardEVGA GTX 780 Ti ClassifiedEVGA GTX 780 Ti ClassifiedEVGA GTX 780 Ti Classified
CoolingEK-Supreme LTX Water Block
360 mm Radiator
MCP35X Pump
360 mm Radiator
MCP35X Pump
360 mm Radiator
MCP35X Pump
OSWindows 7 X64Windows 7 X64Windows 7 X64
Because one of the main features of the i7 5775C is the Iris Pro 6200 graphics, we’ll start with our gaming benchmarks to see just how much improvement has been made when compared to previous generations. After the iGPU testing, we’ll move on to the discrete graphics testing. For our graphics testing methodology, you can visit our testing procedures page for the detailed version of what we do. Below is the down and dirty explanation of said procedure.
Synthetic Tests
  • 3DMark Vantage – DirectX 10 benchmark running at 1280X1024 – Performance preset.
  • 3DMark 11 – DirectX 11 benchmark running at 1280X720 – Performance preset.
  • 3DMark Fire Strike – DirectX 11 benchmark running 1920X1080 – Standard test (not extreme).
  • Unigine Heaven (HWBot version) – DX11 Benchmark – Extreme setting.
Game Tests
  • Batman: Arkham Origins – 1920X1080, 8x MSAA, PhysX off, V-Sync off, The rest set to on or DX11 enhanced.
  • Battlefield 4 – 1920X1080, Ultra Preset, V-Sync off.
  • Bioshock Infinite – 1920X1080, Ultra DX11 preset, DOF on.
  • Crysis 3 – 1920X1080, Very high settings, 16x AF, 8x MSAA, V-Sync off.
  • Final Fantasy XIV: A Realm Reborn – 1920X1080, Maximum preset.
  • Grid 2 – 1920X1080, 8x MSAA, Intel specific options off, Everything else set to highest available option.
  • Metro Last Light – 1920X1080, DX11 preset, SSAA on, Tessellation very high, PhysX off.
As you can witness by the results below, Intel has made great strides with their Iris Pro 6200 graphics. In most cases, the performance has roughly doubled from that of their previous HD4600 series iGPU. Our four synthetic tests show a clean sweep for the Iris Pro graphics and by a pretty impressive amount.
HWBot Heaven Results
3DMark Fire Strike Results
3DMark Vantage Results
3DMark 11 Results
3DMark 11 Results
The game benchmarks again show a clean sweep for the Iris Pro 6200 graphics. Impressive gains are seen when comparing Intel’s older HD4600 series iGPU performance. AMD’s R7 iGPU graphics held relatively close, but wasn’t quite able to keep up.
Batman: Arkham Origin Results
Battlefield 4 Results
Bioshock Infinite Results
Crysis 3 Results
Crysis 3 Results
Final Fantasy XIV: ARR Results
Grid 2 Results
Grid 2 Results
Metro: Last Light Results
Admittedly, most of our readers use a discrete graphics card in their systems. We compared three other Intel CPUs by using the same discrete video card (EVGA GTX 780 Ti Classified) in all the test systems. The synthetic tests show the i7 5775C having no problem keeping up with the other two socket 1150 CPUs and actually taking a win in the HWBot Heaven benchmark.
3DMark 11 Results
3DMark 11 Results
The game benchmarks again show impressive results from the i7 5775C, especially considering its default clock speed is lower than the competitors. While there is very little difference between all the tested CPUs, you’ll typically see the i7 5775C fall between the i7 4770K and i7 4790K results. All in all, nothing to complain about for sure.
Crysis 3 Results
Crysis 3 Results
Grid 2 Results
Grid 2 Results
Moving along to the CPU and Memory benchmarks, we’ll start with the suite of AIDA64 tests. Each benchmark was run three times and the score averaged. All four CPUs used for comparison were left at their default speed and voltage with the memory set to 2400 MHz, except for the i7 5960X, which uses DDR4. Each graph is based on percentages with the i7 5775C being the basis, and thus always being 100%. A higher percentage is better on scored testing, and a lower percentage is better on timed results. Below each graph is the raw data used to produce each chart.
As expected, the i7 5775C produced results lower than the other two socket 1150 processors during the CPU tests because of its lower clock speed. The memory testing had the i7 5775C holding its own against the other socket 1150 CPUs and actually won out a couple of times. To no one’s surprise, the 8-core/16-thread i7 5960X was substantially better in all the AIDA64 testing.
AIDA64 CPU Test Results
AIDA64 CPU Benchmarks – Raw Data
CPUQueenPh WorxxZlibAESHash
i7 5775C4588023655326.8163653918
i7 4790K5624322440377.8199794504
i7 4770K4988922363335.9177203998
i7 5960X7882330727596.3318027167
AIDA64 FPU Test Results
AIDA64 FPU Benchmarks – Raw Data
CPUVP8JuliaMandelSinJulia
i7 5775C587324513131844625
i7 4790K711834882186775607
i7 4770K631030940165634974
i7 5960X641455518297308928
AIDA64 Memory Tests
AIDA64 Memory Tests
AIDA64 Memory Benchmarks – Raw Data
CPUReadWriteCopyLatency
i7 5775C37589373764240353.1
i7 4790K36095376633485942.5
i7 4770K36093376673477644.1
i7 5960X58303469005359564.0
Compression, rendering, and video compression are tested using 7zip, Cinebench R10/11.5/15, x264, and PoV Ray. As expected, the i7 5960X ran away from the field here. Again, the slower clock speed of the i7 5775C resulted in it falling a tad behind the other two socket 1150 processors.
Cinebench and 7zip Results
Cinebench and 7zip Benchmarks – Raw Data
CPUCB R10
CB R11.5CB R15
7zip
i7 5775C295568.3977423517
i7 4790K343959.6790527304
i7 4770K306678.6180424439
i7 5960X4388415.26141042473
x264 and PoV Ray Results
x264 and PoV Ray Benchmarks – Raw Data
CPUPoV Ray
x264 Pass 1
x264 Pass 2
i7 5775C1560.85187.1346.57
i7 4790K1831.70211.5354.99
i7 4770K1622.95181.9849.01
i7 5960X2845.74204.9583.42
The 2D benchmarks include SuperPi, wPrime, and Intel XTU. The I7 5775C managed to top the i7 4770K and i7 5960X in a couple of these tests, but by and large, clock speed and more cores won out here.
intel_i75775c (40)
SuperPi, wPrime, Intel XTU Results
Intel XTU, SuperPi, and wPrime Benchmarks – Raw Data
CPUIntel XTU
wPrime 1024M
wPrime 32M
SuperPi 32M
SuperPi 1M
i7 5775C996183.2215.899520.37010.374
i7 4790K1118164.4735.333429.2828.159
i7 4770K1017185.4086.004483.8349.344
i7 5960X1742103.6473.525536.89410.359
Overclocking
This particular CPU pretty much topped out at 4.4 GHz, which gave us an opportunity to check clock for clock performance against the i7 4790K processor. The wPrime 32M test scored a little better than the i7 4790K, but the SuperPi run came in just a tad slower. We’re splitting hairs here as both CPUs performed roughly the same when set to the same speed. Even though the screenshots below show a little less voltage, it took 1.4 V in order to fully stabilize the CPU at 4.4 GHz. So, we’ll call it good there as most enthusiasts should be able to duplicate that overclock. A 1.1 GHz overclock from the base clock of 3.3 GHz isn’t anything to sneeze at, especially given the mobile processor roots the i7 5775C was derived from.
SuperPi 1M @ 4.4 GHz CPU / 2400 MHz Memory
wPrime 32M @ 4.4 GHz CPU / 2400 MHz Memory
The i7 5775C also offers eDRAM overclocking, which Intel states is primarily to enhance the Iris Pro 6200 graphics. The default speed of the eDRAM is set to 1800 MHz, but some have claimed speeds up to 2200 MHz are possible. ASUS passed along a beta BIOS that had eDRAM overclocking options, but they admitted it still needs work. I didn’t have much luck with the different available eDRAM ratios, but the ones I got working resulted in very minor performance increases at best. It’s something I’ll revisit once a final BIOS version is available. It’s certainly something to keep an eye on as manufacturers fine tune their Broadwell support.
Power Consumption and Temperatures
Given its mobile processor heritage, it’s no surprise the i7 5775C is very power efficient and able to run cool at the same time. Temperature testing had the i7 5775C matching those of the i7 4790K, even though the thermal designs are different. Overclocking temperatures will vary widely depending on your individual cooling apparatus, but our water cooling setup resulted in maximum temperatures of around 78 °C under load. Below are the results under stock conditions.
Temperature Comparison (Stock)
i7 4790Ki7 4770Ki7 5775C
Stock – Idle28 °C29 °C28 °C
Stock – Load59 °C60 °C59 °C
As far as power consumption number go, the i7 5775C performed admirably here as well. In its stock configuration, it draws less power than any of the socket 1150 CPUs reviewed to date, which isn’t surprising given its low 65 watt TDP. Even with the CPU overclocked and under 100% load, the highest wattage recorded was a mere 186 watts. Keep in mind, those numbers do not reflect a simultaneous load that might be put on the graphics card. But, either way… impressive power consumption numbers.
Power Consumption (Stock)
Stock – Idle124112110
Stock – Load211189153
Conclusion
With the Skylake platform just around the corner, it puts the Broadwell desktop CPUs in a rather precarious position. If you’re an enthusiast gamer or overclocker, the i7 5775C might not be a viable upgrade path if you’re currently using an i7 4790K or i7 4770K along with a high-end discrete graphics card. But, that doesn’t mean the Broadwell desktop CPUs are void of enticing features. Without question, the increase in performance the Iris Pro 6200 graphics bring to the table is the big hitter with this release. AMD may have some catching up to do on their APUs, that’s for sure. Combine the Iris Pro 6200 graphics with reduced power consumption; and you have a great opportunity to build an inexpensive, great performing, and very efficient system. Gaming with the Iris Pro 6200 graphics is definitely possible if you’re not opposed to relaxing a few in-game settings. If that’s the case, then you can do without the added expense of a discrete video card. If you’re on a tight budget, then this could be the CPU for you.
Overclockers aren’t left out in the cold either as the i7 5775C will give you a respectable amount of overclocking to go along with the Iris Pro 6200 graphics. While there is still BIOS work to be done by motherboard partners, things should get substantially better as they have time to refine their Broadwell support.
At the time of publishing, the i7 5775C is pretty tough to find at online retailers, but we suspect that should change rather quickly. Because of that, we do not have a concrete MSRP, but it’s expected to be around $370 or less. If that holds true, it’ll be a littler more expensive than the i7 4790K. However, given the better Iris Pro 6200 graphics, the 14nm manufacturing process, and a lower TDP at 65 watts, we can see where the price increase is justified.
Overclockers_clear_approved
Click the stamp for an explanation of what this means.
Dino DeCesari (Lvcoyote)
About Dino DeCesari 230 Articles
Dino DeCesari was a pillar of the Overclockers.com community for over 13 years when he passed away suddenly in 2015. His legacy lives on through his hundreds of computer hardware reviews posted here. Dino spent time in the army as a Telecommunication Center Specialist and received a commendation medal. He had a successful 20+ year career in the automotive parts and technology industry, where he eventually bought and sold his own business. Once retired, he volunteered as tech support for a non-profit and his local school district.
Loading new replies...
Avatar of Janus67
Janus67
Benching Team Leader
17,215 messages 531 likes
Nice review Dino,
Overall I have to disagree on it's purpose/rating, or at least somewhat in the recommendation.
To make an argument that it could be capable as a gaming CPU without a discrete card, I would hope to see results showing at what setting/resolution does the game become playable (FPS in the teens and under 30 fps is largely considered unacceptable, and even sitting at 30 is pushing it).
I honestly don't see the purpose for this CPU. It is too expensive and overpowered for an HTPC (don't need all of those cores), but underperforms compared to previous generation architectures in many circumstances because of its slower clock speed. The only thing it wins at is using slightly less power at load, but it isn't that significant of a difference. It is also more expensive than the previous generation 4770k/4790k CPUs or at least the same price.
I just can't imagine any circumstance where in our build recommendations one of us would tell a user to buy that CPU over a 4790k for their new system (especially if it was used for gaming, as most of our readers do I would guess).
Reply Like
Avatar of Lvcoyote
Lvcoyote
Overclocked Moderator, Overclockers.com Lead Edito
1,473 messages 0 likes
Good points all around Janus, which is why I mentioned it's probably not a viable alternative to the 4790K for the enthusiast/gamer crowd. I think Intel will need to address the pricing moving forward if they expect to entice the enthusiast users, my guess is they will at some point. AIO PC manufacturers will probably be the most likely to use this processor, as it's a good fit for those applications. The i5 5675C might be a better choice for HTPC applications as it should be well under $300, but still offers Iris Pro 6200 graphics. It'll be interesting to see how all this shakes out once Skylake is released too... interesting times ahead!
Reply Like
Avatar of Janus67
Janus67
I guess my thought to that - is the OCF recommended badge for the average user/readers of OCF, or is it recommended for AIO builders? I just don't see it being a recommendable purchase to a user of a 'enthusiast/performance computing community'.
Per the description of Meh:
Meh
The product doesn’t outright fail, but it doesn’t quite do the job properly. This is typically a product with mediocre performance, a poor price/performance ratio or a product that is a little behind the times. Alternatively, it could be a product marketed at overclockers that doesn’t overclock well at all. Better alternatives likely exist at a similar price, making the product difficult to recommend. It won’t set your PC on fire, but it’s just not as good as other products in the same market segment.
I didn't want to get into any sort of an argument about it, but figured it could be said/noted.
Reply Like
Avatar of Lvcoyote
Lvcoyote
We review lots of different products that aren't necessarily intended for enthusiast users - Portable devices, mainstream SSDs, mid-level cases, etc. Hopefully our reviews reach an audience greater than the users here :) But, your points are well taken!
Reply Like
Avatar of ATMINSIDE
ATMINSIDE
23,909 messages 403 likes
Great review Dino.
I agree with Janus here though, it should get a "Meh".
It fits perfectly into "a product with mediocre performance, a poor price/performance ratio" and "Better alternatives likely exist at a similar price, making the product difficult to recommend."
Someone wanting a gaming machine would be better off with a 4690K and 750Ti than buying this for the better iGPU.
Reply Like
Avatar of Lvcoyote
Lvcoyote
Approved
The product performs well at stock and at overclocking, for modding, etc. where relevant. It isn’t necessarily the best of its type, but it performs well enough that we could recommend it with a clear conscience.
I think the CPU meets that criteria too, maybe we need to revisit our rating system... LOL
Reply Like
Avatar of ATMINSIDE
ATMINSIDE
I... won't argue that.
Reply Like
Avatar of Janus67
Janus67
RABBLE RABBLE RABBLE
Reply Like
Avatar of caddi daddi
caddi daddi
Godzilla to ant hills
11,186 messages 40 likes
^^^^^ this^^^^^^^
I had hopes that broadwell would be an upgrade from my 4790K, well it's time to ditch my socket 1150 gear and move on to 2011.
or perhaps the chat I had with Rgone a while back is comming true, if we want to play at this overclocking game, looks like we better learn to hack phones...........
Reply Like
Avatar of Lvcoyote
Lvcoyote
I'm pretty sure this will be the last go around for socket 1150, it'll be interesting to see what Skylake offers.
Reply Like
