Intel Preparing Ivy Bridge-E for September Release
3 SKUs, early September release. That is what the rumor mill has to say about Intel’s upcoming high-performance desktop parts code named Ivy Bridge-E.
Ivy Bridge-E - Image courtesy Wccftech.com
Ivy Bridge-E (Courtesy Wccftech.com)
A supposedly leaked slide puts the launch of three processor parts in the range of 4-11 of September. There’s three parts that are to be released on that date. The top dog is i7-4960X, a six core (12 thread) part with a clock speed of 3.6 GHz and turbo up to 4 GHz. The runner up is i7-4930K. This one should also have six cores (12 threads) but with a slightly lower clock speed of 3.4 GHz and turbo up to 3.9 GHz. The final part that is expected is called i7-4820K and should come to the party with four cores (8 threads) with a base clock of 3.7GHz and turbo up to 3.9GHz. These parts will feature 15, 12, and 10MB of cache respectively, and support for quad-channel DDR3 memory up to 1866MHz.
The i7-4960X is expected to sell in the $999-1$,099 price range, as is the tradition at Intel for the top performance desktop processor. The wildcard here is the presence of a quad core part, which could end up priced closer to Haswell SKUs, but still be paired with the high-performance X79 platform, socket 2011 and quad-channel memory. Note the K moniker, which specifies this CPU is unlocked for added overclocking pleasure. All three CPUs are expected to fit in the 130W thermal envelope.
Intel is not expected to release a new chipset for these parts, relying on the trusted X79 for the time being, although it is not impossible X89 may arrive further down the road.
Read the full report on AnandTech
dostov
Loading new replies...
Avatar of xsuperbgx
xsuperbgx
1
4,793 messages 1 likes
I am wondering if the 4820k, with quad channel memory and the adjustable straps will match haswell on s1150? With so many dud haswell retail CPU's will people be happier with IB-e?
Reply Like
Avatar of EarthDog
EarthDog
1
75,804 messages 2,640 likes
Quad channel ram means little to nothing though outside of bandwidth. It doesnt make a difference in benchmarking it seems and also not with any other applications...
Reply Like
Avatar of xsuperbgx
xsuperbgx
1
You don't think IB-e will have any 2d benching advantage over ib on 1155?
Reply Like
Avatar of EarthDog
EarthDog
1
Nope. sb-e didn't have any advantages over sb. They topped out lower and any extra cache didn't seem to matter on the hex
Reply Like
Avatar of ivanlabrie
ivanlabrie
6,458 messages 0 likes
3d on ln2 might be nice...quad 8970+49/30k-60x at 6ghz :D
Reply Like
Avatar of xsuperbgx
xsuperbgx
1
How about the heat spreader? Will that be soldered and if so, will that help performance at all, or just temps?
Reply Like
Avatar of EarthDog
EarthDog
1
Who knows... And temps only. I imagine its just like IB though.
As far as 3d, in 11 and vantage, sure, otherwise, nope as others dont respond to cores.
Reply Like
ivanlabrie
Exactly...should be fun for those. :p
Reply Like
S
Sabishiihito
1
53 messages 1 likes
Quad channel DDR3-2800? One can dream :-/
Reply Like
ivanlabrie
We're talking Ivy-E still...how many Ivies did 2800 with 4 sticks? :p
I guess you would know better than me anyway.
Reply Like
