Intel to Restrict Overclocking on Sandy Bridge
After all the overclocking triumphs with the Core line of processors, it is hard to believe that the latest Sandy Bridge CPUs from Intel will be more difficult to overclock. Bit-Tech.net is reporting that Intel has “designed the CPUs to deliberately limit overclocking” according to slides prepared by Intel:
A video to HKEPC and posted on YouTube (see from 2mins onwards) confirms the fact that only a 2-3 per cent OC via Base Clock adjustments will be possible. This is because Intel has tied the speed of every bus (USB, SATA, PCI, PCI-E, CPU cores, Uncore, memory etc) to a single internal clock generator issuing the basic 100MHz Base Clock.
This clock gen is integrated into the P67 motherboard chipset and transmits the clock signal to the CPU via the DMI bus. This means there’s no need for an external clock generator that used to allow completely separate control of all the individual hardware.
When you’re overclocking, you want to be able to push certain frequencies, such as the Base Clock and memory clock, but leave others, such as SATA, completely stable as they’re very sensitive to adjustment. Current motherboards allow multiple bus speeds because external clock generators are programmable via the BIOS.
Intel Slide (Courtesy Bit-Tech.net)
The report continues with more technical information and analysis. This fundamental design change will impact casual overclockers all the way to highly-regarded extreme benchmarkers. Don’t panic and switch to AMD just yet, motherboard manufacturers are looking for ways to circumvent the locked frequency. As Bit-Tech points out, locking the frequencies will essentially level the playing field among all motherboard manufacturers. By taking overclocking out of the equation, there is less reason to purchase a higher-end motherboard.
If the past is any indication, this may not be as much of an issue as anticipated. Intel was expected to carry out a similar plan to limit overclocking before the release of the Nehalems core.
Worst case scenario, Intel will still manufacture the unlocked K-series chips. End-users will pay a premium for those CPUs, but their overclocking potential will probably make up for the extra cost.
Will AMD reclaim the overclocking crown? Will motherboard manufacturers discover a workaround? All this remains to be seen. Stay tuned.
For more information visit Bit-Tech.net: Intel Plans to Deliberately Limit Sandy Bridge Overclocking
-mdcomp
  1. Intel Sandy Bridge CPU Overclocking Results Leaked
  2. Intel Sandy Bridge Roadmap Leaked
  3. Intel Roadmap Leaked: Sandy Bridge Enthusiast Specs
  4. AMD Wants to “Bulldozer” Intel’s Sandy Bridge
  5. Intel i7 2600K (Sandy Bridge) Review
Tags: , , , , ,
136 Comments:
xoke's Avatar
Hmmmm, this will really surprise me if it goes down like this. You take overclocking out of the power users hands, well, AMD is about to gain some new fans.
Randyman...'s Avatar
We are such a small percentage of the overall market that it really wouldn't hurt Intel's bottom line - BUT - we are also the ones that recommend parts to numerous potential buyers based on our own perceptions. AMD will welcome any gains in the "Enthusiast" market with open arms
I doubt Intel will be as restrictive as rumored - and we'll still have the K series with higher but not outrageous pricing for our OC'ing enjoyment. However - locking the DMI/QPI will indeed hamper some of the benefits of overclocking (at least in my uses for low-latency audio production). I seriously doubt Intel wants to hand over the reigns to AMD for the Price-vs-Performance Overclocking Crown...
thideras's Avatar
Well, depending on that, I may just go AMD then.
That is, unless Intel is insanely fast at stock. That really hurt saying that word.
xoke's Avatar
Agreed...it seems like I have heard this story before..."Intel stops overclocking" but it never comes to pass.
I'm just saying, if they did...and there was no easy way around it...I bet half this forum would jump ship to AMD.
Mr.Guvernment's Avatar
they claimed the same thing on the i7 series, Nahlem, didn't happen, they have said this a few times, never happened.
But even then, sure we recommend things, but dell , HP and other OEMs still count for i would say %90 of their sales so it still wouldn't make a dent if they did it, sure people would run to AMD, but most people look at a computer on dell, look at the price and hit buy.
DumpALump's Avatar
Exactly, though I don't see how overclocking would hurt them if most of their sales are through the channels where people aren't overclocking. The enthusiasts would just go to AMD, which would be worse off for them. This could very well be just a way to entice investors by saying some individuals will now pay more for the same performance rather than buying a cheaper processor. Lots of companies like to fluff their stocks at certain points.
Archer0915's Avatar
This sucks I just got hold of 2 1156 boardz
Bobnova's Avatar
They (intel AND amd) already tried, hard, once. All cpus used to have an unlocked multi.
Archer0915's Avatar
I guess that was when you did the OC with a jumper for the multi and the Bus
200MHz to 233MHz Core Speed by swapping a jumper. Oh the good old days
CompuTamer's Avatar
Eh, not a good plan. I'll jump ship to AMD in my next build without thinking twice if they do this. I don't see this working out very well... true, mostly OEMs make up Intel's profit base, but if we all jump to AMD, and everyone starts to think AMD is better cause the nerds use em, than OEMs will jump ship to AMD too. Sure, it'd take a bit of time, but it's not horribly outlandish. AMD had a reign before, and it wasn't magic that caused it. (Okay, maybe a little..)
Coreyoliseffect's Avatar
Maybe I am not understanding this but why would they release chips that can not be overclocked?
As was stated above the OC world really isn't that big of a market. From what I would guess the base profit for Intel would be corporate deals. Which to my knowledge don't OC... Is OCing something that Intel really needs to limit?
Not to mention, think of all of the people in the OC Forums community with nothing to do. We would have to leave the house! AHHHHHHH
Archer0915's Avatar
We would dig up the old Gygax games and start modding the rules like the old days of the C64 and 2-386 We would go back to DOS and start rewriting the way memory is accessed so that we could have more than 640K (I had my MS-DOS rewritten to have 720k free, Win3 did not like it but the Duke did).
We would Go back to Basic and start writing our own dice programs for AD&D and AD&D 2E because we were cool back then.
DumpALump's Avatar
There was an issue at some point where some businesses were buying cheaper chips, overclocking, then selling them at the faster speed. Don't really believe that is going on now.
My current ideas
1) Analysts already figured out that they would have a net profit increase even with some switching to AMD. People would be forced to buy more expensive CPU if they wanted more performance. With the branding that Intel has over AMD, they would lose some, but keep the majority.
2) Making certain statements help to increase their market value. Great for the company to buy and sell stocks at the right time.
3) Appease vendors as the benefit to building your own computer will have decreased. (Prebuilt computers tend to not have the options of overclocking much if at all.)
4) Decrease costs of support, now that you would not be able to overclock, the settings would all be set to specific ranges depending on your chip. This would limit peoples ability to mess up their settings and have it set them correctly. There would be less calls to Intel and/or less RMA'd chips.
OEM's wont jump cause we do, they know better, they will go with who ever can offer cheap bulk prices which will be Intel, sorry, but enthusiasts jumping to AMD will NOT change anything for Intel or OEM's, we are not that powerful a force.
Sure, AMD had a better CPU back in the day for a while, but OEM's still sold Intel and Intel out sold AMD all over the charts up and down in every market, so that is proof we don't have the power some seem to think we do, otherwise AMD would be a lot higher than they are now from that era.
AMD needs to hire a new marketing department, get the same company coca cola uses and watch AMD sales skyrocket.
pwnmachine's Avatar
It is really unfortunate since mostly ENTHUSIASTS buy these chips, which for the most part LIKE TO OVERCLOCK. It seems like a backwards step for intel, seems like AMD will once again assume the position of power in hardware overclocking.
pwnmachine's Avatar
This is really sad to see since most pc enthusiasts base their purchases on OVERCLOCK-ABILITY, I still find it hard to see what intel is trying to do, honestly if they are trying to tap into the uninformed pc user-base they are chasing a ghost.
bda1967's Avatar
I would switch to AMD for my primary rig without a doubt. Provided they wouldn't do the same thing on their next release.
MIAHALLEN's Avatar
Food for thought:
http://www.xtremesystems.org/forums/...d.php?t=204868
I think mobo manufacturers will find clever ways around these issues, and overclocking will carry on
White_Pawn's Avatar
they have to. Or they basically lose their jobs. As the article said, if you can't overclock, there is very little reason to buy an enthusiast level mobo.
MIAHALLEN's Avatar
Nice avitar WP
jason4207's Avatar
Yep, they said the same w/ Nehalem.
Here's a link for perspective.
http://www.overclockers.com/forums/s...d.php?t=559606
Not only are we able to OC i7, but we can even use the 'turbo' multi constantly on all cores when it was only designed for single core usage.
Adragontattoo's Avatar
This has been stated IIRC every other generation or so, every time people either got around it or it didnt happen.
Short of them literally forcing manufacturers to eliminate BIOS settings, it wont be enforceable. Well assuming they havent figured out how to apply the DMCA to OCing.
macklin01's Avatar
Frankly, the headline and summary are over the top. Where's the quality control? At best, this is editorialising.
Deliberately restricting overclocking? Are you really sure that the sole and only reason Intel is reducing down to a single on-die clock generator is to thwart overclocking? Not to, say, simplify design and reduce cost? Because these seem like logical things to do, trending along with on-die memory controllers and the like.
In fact, the linked bit-tech article says as much, albeit in a breathless manner that assumes intention where I'd imagine there is none. This seems to be deliberately limiting overclocking in the sense that gravity deliberately interferes with my dreams of flying like superman.
I think we could have done a better job of objectively decoupling the editorialising (assuming certain dastardly intentions) from the reporting (the chips will do X). We're better than this.
It's certainly not the end of the day. "Normal" users get a cheaper chip, more of the system is on the chip (with presumably fewer failure modes as a result), and the rest of us can happily bypass the clock signals onboard. Big deal.
More accurate headline: Sandbridge on-die clock generator will likely break current overclocking methods.
splat's Avatar
Paul, I understand your concerns, but look at how long your title is compared to the existing one. And there is nothing factually wrong with the existing title. The new intel chip, with the reference intel motherboard design will not allow overclocking. And it is stated that 3rd party manufacturers are working on ways to get around this but nothing is working, yet. As such, this does not look good for us, Overclockers, and we said why.
David's Avatar
The changes will break current overclocking methods - that's maybe not the intention, but it's the most important repurcussion as far as overclockers are concerned. It's something we (editors) have discussed and taken on board though, constructive criticism is welcome.
Remeniz's Avatar
I think it's Intel's strategy to force over-clocking enthusiast to buy the premium chips.
macklin01's Avatar
Thanks guys.
I'll take a long, accurate title over a short, sensationalist one any day of the week. However, I understand that concern. But in my opinion, character count should never take precedence over accuracy.
While the current title is "correct," the word choice implies ulterior motive and intent. "restrict" is a word that implies an intentional limitation. As we can see, this is much more likely to be a secondary consequence of a design decision, not an outright restriction intended solely for impeding overclocking (as the word choice suggests, and the summary further "confirms").
And David, I agree that this is the major consequence for our community, it's very important that we don't conflate cause and effect. Here's one place where we can excel over other communities while still hitting all our points.
Thanks -- Paul
But that's just it--this is speculation. We have no facts (e.g., internal strategy memos, etc.) to confirm such an opinion. We do have facts that this will be a consequence, and so we should separate the editorialising and sensationalism from the facts, which are in and of themselves already newsworthy.
You and I have the savvy to pluck out the facts from the speculation, but some of our younger readers may not.
Sentential's Avatar
Dr. Who on XS has already posted that this is bogus. He has engineering samples at this disposal (as he's hinted strongly) and this is not going to be an issue. He said it would be "very different" but it will still clock very high just like current i7s do. He's been dead on before and I trust his info as he has put up screenshots of his chips in previous posts.
macklin01's Avatar
Fantastic! Do you have a link and/or sources?
Seriously, this is where we can really build our reputation. Report the stories, but do the deeper fact checking that requires real thinking and analysis. (Not to mention good old fashioned fact checking.)
thideras's Avatar
That is a relief to hear, actually.
splat's Avatar
the title at XS definitely says that intel is doing it on purpose. I still don't think ours implies the same thing. We posted the article on the 22nd using the facts in the bittech article. Just because different facts came to light the next day doesn't mean that we weren't doing our fact checking or that we were wrong to report it, just like with the "fake" intel chips a few months ago.
Paul, we're all volunteers doing the best we can with the limited time we have. We invite you to help us out.
macklin01's Avatar
Splat, I'm sorry it came across as unduly harsh. That was absolutely not my intent. I'm sorry I've become a curmudgeon in my old age.
I understand and agree that it was the information we had at the time. Given that the information was limited, perhaps we could have taken a more cautious stance? Also, we could have easily written a more restrained entry that (once again) separated the facts as presented in the bit-tech article from the sensationalism/editorialising.
The facts (as understood at the time) regarding the clock generator were in and of themselves interesting and newsworthy. The logical implications for overclocking, in and of themselves, were interesting and newsworthy. The breathless accusation of deliberate breaking of overclocking was wholly unnecessary and didn't need to be repeated.
Please take it as constructive criticism. You guys are doing a great job, and I recognise that you're doing amazing work as volunteers. I wish I could get more deeply involved, but family and work life are preventing it at this point, beyond my current role of trying to provide feedback and constructive criticism. I hope it's helpful. If you feel otherwise, I'll back off.
Thanks again to the hard work by you and the others. -- Paul
*edit*
I agree that our title is better. The XS title is just a direct copy/paste of the bit-tech title.
splat's Avatar
no hard feelings and thanks for the understanding. We certainly do appreciate the feedback and are working to improve. So don't hold back too much, but do keep in mind our diverse backgrounds.
macklin01's Avatar
Sounds great.
And once again, let me give you and the other writers and editors a public pat on the back. You're taking the site in a very good direction. -- Paul
QuietIce's Avatar
Personally, I think anything Intel offers will end up overclocked. Once the genie is out of the bottle there's no going back.
With all the under-handed and illegal things Intel did to keep OEMs from selling AMD I'd say Intel thought it made a difference! Paying off OEMs to NOT sell AMD chips? Threatening to end long-standing pricing contracts not because the OEMs were going to sell fewer Intel chips but because they were also going to sell AMD chips? You think Intel did those things just on a whim? A whim that would cost them Billions of dollars a few years later? (And they had to have known the risks they were taking at the time.) Obviously Intel saw a threat to it's bottom line from AMD even if you didn't.
Yes, I'm sure without Intel's illegal and unethical interference with OEMs during "that era", AMD would be "a lot higher than they are now" ...
ChanceCoats123's Avatar
If this hasn't been pointed out, the article mentioned that it was for chipset P67. 1156 boards will be fine since they are on P55/H55. Just don't get Sandy Bridge cpu's.
My favorite part of the whole article.
Zucker's Avatar
This is false alarm, overclocking on SB would be different due to design, that's all.
EarthDog's Avatar
Yeah, thats what they said for i series as well... we will see.
SecrtAgentMan's Avatar
This really would be AMD's time to shine.
They could start making better processors with lower heat output and a smaller form factor while being able to charge more if they allow for overclocking on said processors.
Bobnova's Avatar
Different by design as in you have to buy an overclockable CPU, that's my guess.
We may not be a large segment, but we do exist, if half the people on this forum go to SB and buy unlocked CPUs at the current locked+$100 rate intel gets $44K, that's not bad, really.
It's in intel's best interests to charge more for unlocked CPUs and keep bus speed locked, just like it was in AMDs best interest back when HTref didn't OC as well. They had BE and non-BE for the same cpu, the BE just cost more.
Really Intel just has to make it hard, it doesn't matter if it's doable as long as the basic joe n00b can't do it effectively.
I can't see intel making it impossible, at some point someone will make a motherboard with a filter in the PLL lines, it catches the signal and raises it. The sata is on the chipset, it's uneffected, same for USB. The PCIe on die goes up, but the same chip could interface into the PCIe lines (ala Hydra) and drop the frequency back down to 100 to keep the GPUs happy.
It'd cost more, but it ought to be doable.
As James Bolivar DiGriz says: What man can lock and encode man can unlock and decode.
wingman99's Avatar
+1 Yeah now you will have to buy the k models and extreme. Did you read how there doing it this time, Intel has tied the speed of every bus (USB, SATA, PCI, PCI-E, CPU cores, Uncore, memory etc) to a single internal clock generator issuing the basic 100MHz Base Clock.
Shiggity's Avatar
Intel had the writing on the wall as soon as Turbo Boost Technology was unveiled. Their marketing department will start saying every chip they make is overclocked automatically, which is technically true (anything with turbo boost, which will be almost every chip soon).
AMD is coming out with something similar soon.
We all got spoiled from the legendary Core2Duo series (4.0Ghz on stock voltage, yawn =D) and we'll have to work a lot harder to get those good overclocks. But that's the fun
Killador's Avatar
We all knew this would happen. Intel has never been a fan of overclockers because we can show how unjustified their prices are for extreme chips compared to a normal. AMD is soon to follow im sure...
Qusus's Avatar
OK, who the hell are you? Did you, in a past profession, have experience as a writer/editor?
I only ask because what you just said makes perfect sense and is an example of a much larger problem in all outlets of media/journalism (especially politics) and is something I think we should all be more cognizant of.
Thus, I would like to subscribe to your newsletter.
(edit*** Also, I forgot to add: in my experience, what you said usually comes from the mouth of a crazy old dude with tautologically infallible conspiracy theories about 9/11 and etc. Even if they're right... I mean... they're crazy. Surprisingly, your rant was quite reasonable.)
wingman99's Avatar
I don't think it's going to be fun if Intel sets there engineers to make a chip that we can't overclock
The motherboard manufactures are going to have to come up with some magic engineering of there own and make a external clock generator that will separate USB, SATA, PCI, PCI-E, CPU cores, Uncore, memory etc. I'm guessing it would be before and after the DMI bus also memory and PCI-E that will send separate clock signals.
If Intel does this, it's going to cost allot of money to overclock, either you pay intel for the unlock multiplier CPU's or hope they can make $400+ motherboards to overclock.
I don't know where the fun is, if this happens.
QUOTE:This is because Intel has tied the speed of every bus (USB, SATA, PCI, PCI-E, CPU cores, Uncore, memory etc) to a single internal clock generator issuing the basic 100MHz Base Clock.
This clock gen is integrated into the P67 motherboard chipset and transmits the clock signal to the CPU via the DMI bus. This means there's no need for an external clock generator that used to allow completely separate control of all the individual hardware.
Bobnova's Avatar
I betcha the DMI bus clock signal is the clock signal, it'd make sense given that the DMI is a PCIe bus with a new name.
I was talking to someone (ghost?) about the very first SB chip seen in the wild and how it looked like they were using PCIe directly for the bclk and how it'd be a major pain to OC. Wish i'd posted that convo back then, i'd look like an oracle or something now :P
wingman99's Avatar
Direct Media Interface DMI, It provides for a 2GB/s bidirectional data rate.
It's much faster than the PCI E specifications because it handles all the south PCH traffic, all at the same time on intel specked boards.
Here is a old Link when it was only 10Gb/s:http://en.wikipedia.org/wiki/Direct_Media_Interface
Bobnova's Avatar
Like i said:
The current DMI is a 4x PCIe 2.0 link, which totals 2GB/s.
http://www.bit-tech.net/hardware/cpu...the-next-gen/1
Gotta keep in mind, a PCIe 16x 2.0 slot is a whopping 8GB/s of bandwidth.
wingman99's Avatar
I totally agree until Intel puts the PCH and CPU,IMC on a single Chip for the sake of speed improvement.
wingman99's Avatar
PCIe 16x 2.0 slot is 16GB of bandwidth bidirectional.
The current DMI is a 4x PCIe 2.0, which totals 2GB/s bidirectional, Intel is using PCIe 1.0 speed standard 250 MB/s on the DMI bus on the ICH-10, P55
Anandtech LINK:http://www.anandtech.com/show/3574
Your still missing some things.
The PCIe 2.0 standard uses a base clock speed of 5.0 GHz, while the PCIe 1.0 version operates at 2.5 GHz
QUOTE: and posted on YouTube (see from 2mins onwards) confirms the fact that only a 2-3 per cent OC via Base Clock adjustments will be possible. This is because Intel has tied the speed of every bus (USB, SATA, PCI, PCI-E, CPU cores, Uncore, memory etc) to a single internal clock generator issuing the basic 100MHz Base Clock.
The base clock comes from a clock Generator in the PCH.
Thanks for the link, for sandy bridge
macklin01's Avatar
Uh, thanks?
I'm just a mathematician / scientist who wants us to be accurate. We have a great responsibility to our readership, who can sometimes tend to take rumours to be fact far too quickly. We're still seeing some of that in this thread now.
wingman99's Avatar
In your professional opinion, do you think this is not from intel.
QUOTE: Intel's own slides confirm just 2-3 per cent
macklin01's Avatar
In my opinion, professional or not, you're reading too much intent into a single line in a single PowerPoint that hasn't been 100% confirmed as the final design. Even if it is the final design (which cooler heads do not yet appear to confirm), it does very little to prove that it was a primary design goal, rather than a consequence.
The facts are in and of themselves interesting. There's no need to project good-and-evil on top of them. Slow down. Let the facts emerge. Analyse them as they come. This thing is not due out for a couple of quarters at the earliest, all sources seem to point to the same 19 bytes on bit-tech. If it's true, other sources (e.g., ars technica) will emerge.
wingman99's Avatar
Well 3Q 2011 looks better, however expensive.
QUOTE: also mirror what we've heard and go further to include details Intel's upcoming LGA2011 Sandy Bridge-E and 'Patsburg' chipset that will replace the current X58 and LGA1366 platforms.
According to HKEPC the upper limit DDR3 support currently exceeds 2,666MHz (wowzers) and most importantly follows previous current generations basic designs so overclocking potential is unaffected, yet, unspecified
Killador's Avatar
Thats some serious RAM speed, but why stop @ 2666 - if they are going with this new platform, they need to cater to my budget as well
Bobnova's Avatar
That'd be socket 2011, socket 1155 is for cheapskates.
wingman99's Avatar
I just found this intresting
QUOTE:According to one Taiwanese motherboard company, on a Sandy Bridge system, the fact that all the busses are linked means that turning up the Base Clock by just 5MHz caused the USB to fail and SATA bus to corrupt.
We chatted about possible work-arounds but at the moment the few 'asynchronous' setups tried were currently not working. It's been claimed to use out-of-the-box the design was deliberately limited with the intention to simplify board design and lower costs. This obviously has the 'unfortunate' side effect that enthusiasts will be unable to manually overclock Sandy Bridge CPUs to their limits, but the CPU's own internal overclocking, TurboBoost, will still work and Intel will offer some controlled multiplier overhead for enthusiasts as a token gesture.
If bit-tech did talk to the Taiwanese and it's true, it does not make any sense, decrease the complexity of the motherboard for cost and increase the complexity of the CPU and PCH
QUOTE:Energy cannot be created or destroyed" this fundamental law of nature, it can only be redistributed or changed from one form to another
LOL I'm one of those vary vary vary cheapskaters.
Cant.Touch.This's Avatar
I wholly agree with the former statement - guess they didn't like how people took their lower clocked CPU and OC'd to higher for free. As for the latter, could you offer a reason to why AMD may follow so soon? Just curious on your thoughts Killador.
On another note, what would the sockets be then?
S1156-> S1155(?)
S1366-> S2011(?)
What becomes of S1567? Not really applicable to me, but I'd like to have a rounded-view on this. Haven't come across the next MP-supported socket in my readings or browsing through the above posts. No one touched on the four channel DDR3 support for their high-end offering; yes, the benefits will surely be contested - a measurable but not really perceivable change in performance (what were the average % increase from dual to triple channel DDR3 again?). Actually, re-reading my last sentence I guess there isn't much to talk about it, it'll just be a repeat.
If the DMI clock doesn't OC past 2-3% of its base 100MHz, we're down to multiplier OC (assuming board manufacturers don't figure a workaround)? I guess their 'K' series processors fill that space, but for those on air cooling it doesn't outperform their locked counterparts (of course I'm referring to current CPU's, I couldn't know how SB locked vs unlocked would perform).
Fueling some discussion since it's been a week.
CarpeDiem's Avatar
I still remember the days when they said the same thing about Nahelem not being overclockable. I'll believe it when I see it.
wingman99's Avatar
Nahelem was just speculation, This is a roomer with allot of legs to stand on.
wingman99's Avatar
I find it odd and compelling that the year 2011 is the same as the pin count does intel just play with us when deciding the pin count.
With just adding unlocked multipliers it is not as good as being able to raise BCLK, you receive much more performance.
Also with no motherboard involvement in overclocking, a chimp will be able to overclock.
Here is more evidence that intel is going to make it cheaper to build motherboards with sandy bridge.
LINK:http://www.youtube.com/watch?v=7HkPwqPQpPs
DumpALump's Avatar
So the rumors are becoming real? What a shame. I figure this would affect a lot of people designing products for overclocking. Sure a lot of people will switch to AMD, but there is still a majority who will buy Intel and will just end up having to leave everything stock.
I'm sure AMD will welcome the new enthusiasts. I don't really see AMD limiting overclocking. Considering that their chips are so cheap, why wouldn't you just buy one of their high end chips anyways? I hope Bulldozer turns out to be a real beast so there would be no need to buy an Intel.
JenBell's Avatar
I see it as very simple. Intel...however unlikely, do limit the OC...then OCer's will move to AMD. AMD CPUs might not be awesome OCers...but they never stop u. I dont think Intel will stop the OCing community. The reason is simple...the nerds have influence. I give u an example, one of my clients wanted to upgrade there fleet of laptops and desktops (200/400 respectively) for Windows 7. As tech consultant I was asked a simple question by the tech dept geeks: Desktops. Intel or AMD? I reponded instantly Core i5's. Laptops...I recommended neither. I instead asked about the users, applications, etc and then recommended that they enter a rolling contract for initial 2 years with a respected Mac reseller. From September they will issuing MBP 13 as standard issue with Parallels 5 installed with win7 (VL holders). What does this all mean...simple...they followed my advice...one person...decided 600 laptops/desktops. Influence is not something u can buy. I mean...how many people here who own a 980x CPU can say, yep...AMD is the way to go...that's what I want? U cant...and u wont. U read, u see, u buy...u play...u smile and then u know...u bought something awesome.
(I owned Abit Max3 mobo...had AMD PC's when there DCores ruled the world...since Intel unleashed core...its all been Intel). Before anyone asks the question...during the AMD reign...I still recommended Intel mobile CPUs...even for desktops...they OCed so well it was almost comical^__^
Oh, thanks I was looking for the actual pictures. All I got were thumbs from others.
wingman99's Avatar
It's all over, here comes the intel overclocking money train.
Anandtech
The Sandy Bridge Preview
LINK: http://www.anandtech.com/show/3871/t...ins-in-a-row/5
QUOTE:With Sandy Bridge, Intel integrated the clock generator, usually present on the motherboard, onto the 6-series chipset die. While BCLK is adjustable on current Core iX processors, with Sandy Bridge it’s mostly locked at 100MHz. There will be some wiggle room as far as I can tell, but it’s not going to be much. Overclocking, as we know it, is dead.
Regardless of how they’re priced, what this is sure to hurt is the ability to buy a low end part like the Core i3 530 and overclock the crap out of it. What Intel decides to do with the available multiplier headroom on parts further down the stack is unknown at this point.
There will be ways around this - I'm sure of it. Look how much Intel has embraced Overclocking on the i7 - they even wrote some software tweak applications for it! I have no intentions of going to Sandy Bridge in the next year, but I'm sure something will happen on the Overclocking front by then. Granted Intel will still sell more expensive unlocked "K" processors, but I seriously doubt all overclocking will be dead with the exception of the K series CPU's.
NTM the revenue they "lose" from us overclockers buying $200 CPU's and cranking them up past a $1000 CPU's stock clocks is minimal and likely only a small blip on their bottom line. I know I'd NEVER buy a $1000 CPU - maybe a $300 CPU. So I wouldn't be an example of any type of lost revenue to them - only a better price-to-performance experience for me as the end user and an Intel Fanboy
k9rosie's Avatar
I think it's a simple marketing idea. They want to limit/disable overclocking in their processors because they want you to fork out more money with a processor than a higher Ghz.
Killador's Avatar
There are runmors going around about AMD's Fusion CPUs to counter the Sandy Bridges CPU coming out Q1 2011. They have the Bulldozer (Zambezi Family), Llano (Athlon II Family) and Ontario (Bobcat Family) CPUs that are rumored to be released Q1 and Q2 2011. Most of these i believe are to be mainstream on desktop and laptops - they really look identical to Nehalems - but with some features Sadny Bridges has to offer.
RE: k9rosie
That's kind of my point - I'd NEVER spend $600-$1000 on a CPU. I guess I see it as a similar argument that content providers lose revenue due to piracy. Well, most people that pirate wouldn't have bought the content in the first place making the actual "losses" much less. So Intel saying "All you people that buy $200 CPU's and OC them will now have to buy our $600 CPU instead" - it's just not going to happen and we'll be content with our $200 CPU's at stock speeds .
The Overclockers are a blip in their bottom line, so it's not like this is going to boost Intel's bottom line anyways (we are such a small percentage of their sales, and then an even smaller subset of people that would actually fork out 2x-3x more cash for the faster CPU's)...
wingman99's Avatar
That is not true most of all retial motherboards are overclokable, we are the meat and potatos of DIY around the world for desk top usage industy that also incudes performance video cards, and all performance producs, it all ties in.
intel is not stopping overclocking there putting a price on it. I've never spent over $200 for a cpu and not much over a $100 for a overcloking motherboard and have always destroyed the performance of the intel $1000 CPU with overclocking.
If intel only market $300+ CPU K models and if motherboard manufactures have a special chip's made to bypass intel, the cost of it being the only factor, this will hurt the market in the long run I feel.
To this date intel has only sold 15-25,000 thousand Gulftowns world wide IIRC there is not a big market for $1000 cpu,s.
From the beginning PC gaming boomed with because of DIY video and CPU,
and the meat and potatoes of DIY are low budget.
So we will have to see because video card companies started to charge more from the beginning, also SLI, fire and that worked because you can't cheat on video cards like you can do with CPU's
Just think they way it stands now there is only 2 K models of CPU that can be overclocked, the way it was before all models could be overcloked. like $50-$100 CPUs running almost as good as top model CPUs, some even better.
Think of all the people that did not intend to overclock, however did later because they already had all the equipment and just gave it a try, boom.
Bobnova's Avatar
They are embracing it, look at the K series!
This is Intel realizing that overclockers are a large enough market to make it worthwhile to market to them. They can't market to OCers if all cpus can be OC'd.
Sooooo, they lock 'em down except for a few more expensive ones.
OEM dwarfs DIY by magnitudes - The DIY/Performance Enthusiast market that actually knows what Overclocking is is very small when comapred to the OEM's massive buying power.
I know if I ask 100 of my coworkers (a fairly tech savvy bunch, too!) only 1% would know what I'm even talking about - much less actually implement overclocking in their own rigs. If you ask here, you'll get a VERY different sample since we are on OC Forums after all (we are the exception - not the rule).
Needless to say my sentiments above stand. I would not buy a $500-$1000 CPU just because they are the only ones that "allow" overclocking - just as the "pirates" generally wouldn't buy the content they pirate if they had no way to pirate in the first place. It's a very similar concept (something for nothing) from a "bottom line" standpoint...
Why would I upgrade from a 4GHz i7 930 to a "Stock" sandy bridge of similar price ($199)? I wouldn't - and Intel knows that. The fact that their more expensive CPU's don't sell well adds more creedence to my theory IMO. The MoBo manufacturers will mod their BIOS's to find a way around this IMO - I'm not terribly worried
Worst case scenario? Everyone goes back to AMD - then Intel will eat crow rather quickly. I seriously don't believe Intel is willing to give AMD that chance after the P4 era left egg on their face...
Bobnova's Avatar
If that 1% of computer buyers pay $100 more for an unlocked CPU, Intel makes a few more million.
This whole thing is aimed at mid range, socket 1155. Your 930 will likely still beat everything for this socket.
In the mid range it's just like the 650 vs 655K.
It's less than 0.1% - well less than that. My 1% was an arbitrary sample from "techies" and only suggested they know what overclocking was - not that they actually implemented any type of overclocking themselves. Out of the 300 people that work here (a "techie" environment on top of that), I'd bet maybe me and one other person actively overclock their PC's...
If an i7 930 is $199 and beats the more expensive "K" series Sandy Bridge CPU's - then what's the motivation to buy the K series??? I don't see it.
Again - I really believe Intel will NOT let AMD take the reigns on this - and AMD already has $99 Quad Cores, and a slew of fantastic overclockers below $200.
I might consider a $300 CPU (my last two i7's were only $199), but beyond that I wouldn't have a huge problem going to AMD - and Intel knows this. I'm not terribly worried either way as I won't be building a new system anytime soon.
wingman99's Avatar
I'm not taking about OEM I'm talking about Asus gigabyte and all the others motherboard and companies that make DIY products including video cards. for DIY when you tie it all together we are the ones that make up the big gaming industry it's not OEM desk top PC's for gaming.
look at it this way if you think we are only 1%, who do you know that games on a PC desk top, you can't go by who you know.
Do you get the big picture yet. DIY is what pushes the gaming industry not OEM desk top sales.
I will put it this way the majority of people in the world don't need new pc desktop upgrades unless there gaming.
And if you did go to local gaming clubs like I have done in the past gamers are well aware of the DIY products out there.
Also I work as a tech and hardly ever upgrade gaming PC's or have to deal with gaming PC owners.
I really don't get the big picture with regard to Overclocking
I know plenty of people that gladly upgrade their RAM, HD's, Video cards, and even CPU's and complete OS re-installs themselves. Yet they have no clue what Overclocking is and certainly haven't OC'd their CPU's. Some *might* OC their GPU's via ATI's driver based OC utility - and that's as far as it goes and is only used because the OC capability is built into the driver and is 100% automatic! I agree the "DIY" market is big, but again the percentage of that DIY market that has any clue about overclocking - and then the fewer that actually overclock their rigs - is miniscule compared to Intel's big business of OEM's...
I know I personally wouldn't buy an expensive (>$300) CPU just because the cheap ones would be locked. I'd go AMD instead. Do you get that big picture or is my stance as a dedicated Intel consumer (I'd even call myself an intel fanboy) also irrelevant?
Here is where we stand:
1) Either the MoBo manufacturers will find loopholes around this and it will be a non-issue just like it was before i7 was released (remember this same issue came up back then, too )
2) Intel's K series will flop and they will eat crow once they lock all of the cheap CPU's (will have to wait for i7 to die off first)
3) The enthusiasts will all migrate to AMD - also resulting in Intel eating crow
4) Intel's odd marketing strategy will be a "hit" and they will sell more $500 CPU's than they ever have (I'm SERIOUSLY doubting that outcome).
I'd also add that unless you can increase the bus speeds/bandwidth, a simple unlocked CPU Multi is NOT ging to give you the same performance benefits that we see now via FSB/bclck overclocking. Food for thought.
I'm all set for the next year or so - two i7 rigs, two C2Q rigs, and two C2D rigs to keep me going. The fact that Sandy Bridge might be a better architecture is no motivation for me to spend $500 on a CPU and $300 on a high-end MoBo when my $199 i7 930 and $170 ASUS P6X58D-E will be right on it's heels at less than 1/2 the cost!!! Clear as a bell to me - but that's me
DaveHCYJ's Avatar
I think even if you accept the fact that the OEM market dwarfs the DIY market, that doesn't mean the DIY market is not important to Intel/AMD. Its the DIY market that gets lots of attention and has a huge PR $ value. I think Intel is aware of that and won't let it slip away (I hope).
That being said, I'm kind of disapointed with the whole unlocked multipliers being the new overclocking. I never was one to chase the boundries of overclocking, I typically would just give my system a modest boost to the fsb and be happy. I enjoyed having everything run slightly faster, not just the processor. Oh well, at least with memory ratios you can still overclock the two most important components.
The PR and Reviewer/Blogger aspects have more "legs" than the entire Overclocking user base IMO. That is also why I don't think Intel will completely block overclocking. They are leaving a backdoor open somewhere - and just waiting for Asus or Gigabyte to tap into it IMNSHO. AMD spanked Intel in the P4 era - Intel will not let that happen again - and AMD is still coming on strong (It's not like Intel can rest on their laurels or risk bad PR - or AMD will overtake them AGAIN!)
One of the 4 outcomes I listed above
wingman99's Avatar
I think your severely underestimating peoples and gamers knowledge and the thing called the internet.
Overclocking is born form tweaking it all starts when you have trouble with something and you ask for advice or google for it.
You think allot of gamers don't know about overcloking and DIY don't because of the people around you. you can't judge by that.
Gamers and DIY are always looking for advantage or better graphics or performance end of story.
I'll respectfully disagree from my real-world perceptions - and the peeps I work with and associate with aren't exactly stuck in the 20th Century (they are a fairly tech-savvy group as we work in a technichal environment - and they do enjoy gaming in general). Even if the DIY'ers are interested in Overclocking - will they be willing to dish out a good deal more cash to purchase (or completely upgrade) an overclockable system? I doubt it - so I strongly believe Intel has left a backdoor open to allow overclocking on the cheaper parts as they always have.
The hardcore gamers will be the ones that Overclock (and might be OCD like me ). The casual gamers (most gamers like the ones I work with who are passionate but not "Gung-Ho" on tricking out their systems - ) are the ones that will install a new GPU, and don't want to screw with the BIOS and stress-testing and possible crashes and system instabilities involved with manual CPU overclocking. I'm not even fond of the whole "new system Overclock Stress Testing / stability testing / crashing" procedure - and I absolutely LOVE building PC's!
You also have the odd-balls like me that NEVER game, but are all about squeezing the last drop from our $199 CPU's to get the best Audio performance out of my systems (tons of Low-Latency audio is a tough task to handle). For my applications, an unlocked Multi ("K Series" CPU's) is almost useless as I need more bandwidth across the entire system to handle 128 chanels of Audio coming in and out of my system at extremely-low latencies. RAM and FSB/QPI/DMI bandwidth is crucial in my settings - and simpy unlocking the CPU Multi and charging me more cash is not going to do me any favors.
Regardless - Intel will be shooting themselves in the foot if they effectively kill overclocking from their affordable CPU's. The PR and related pushbacks will drive the budget-minded enthusiasts (like me) to AMD. I'd have no issues going to AMD - and every single PC I've built in my life has been an Intel (likely over 20 systems by now). If that doesn't say something - then I don't know what does...
Don't forgte this same "Scare" reared its head before i7's came out too - and they are some of the best overclockers on the planet! Cry wolf...
Intel's bottom line won't grow because they want us (the tiny Overclocking market) to buy more expensive CPU's. If anyting it will shrink as we (lots of us) will go elsewhere in search of cheap overclockable power...
wingman99's Avatar
In the real world now most motherboards have overcloking capability now, no extra purchase needed from the DIY community and this community is vary large way more than 1% and like I said before you can overclock now for cheap $50-$100 boards.
There are many reason to build your own computer and people do the research and they wanted overclocking motherboards, that's why most motherboards you buy will overclock that is how big it is in the real world customer demand caused manufactures to supply overcloking boards in all price ranges, you can be hard pressed not to end up with a ovclocking motherboard on any purchase.
Real world PC Gamers cheat in games steal games and and the gaming industry says it a loosing the battle that is how bad it is and you don' think there smart enough to overclock a cheap system to save some money or maybe they are on the good side and want the best graphics at a low cost and game play to win, just like how i'm trying to explain that 1% does not even come close to the amount of overclokers that do it jut because they can and it's easy, can saves money or more performance.
intel did not leave a back door, they did this because just like you they can't count the number of people overclocking because most retail boards overclock, they want a peace of this big pie.
I'm not saying they can't make a clock generator to interrupt and take over clock gen from the south PCH however if it is possible, which i'm finding hard to believe because they set the internal multipliers all to 100mhz.
After reading the the data that's out there would have to be two paths into the CPU one for memory so you can change memory speed multiplier with the P67 chipset and the other would be a path into the cpu chip for BCLK and video clock so you can't separate PCI-E video buss clock speed of 5.0 GHz from the CPU clock, so if you increase the bclk the PCI-E video buss will go up to.
That is how I would do it.
So if there is only two clock gen paths going in to the CPU chip good luck opening and changing architecture.
This is how much intel thinks there is mass amount of overclokers out there and they want to cash in.
LINK:http://www.youtube.com/watch?v=U62lC...eature=channel
BrianAbington's Avatar
they may do that at first, but I think they will then come out with something beastly that really responds well to overclocking and is way more efficent that is aimed at gamers and servers.
Bobnova's Avatar
If just the record number of people on this site (who now know about OCing) buy $100-extra K series CPUs, that is half a million bucks for Intel.
On one hand that's not much, on the other hand we're a drop in the bucket users wise.
DaveHCYJ's Avatar
Based on the current roadmap it looks like the Sandy Bridge i5 2500k is going to be priced the same as the i5 750/760 is currently. People are currently loving the 750/760 in the $200ish price range so that shouldn't really change assuming the 2500k hits the same price range.
Also don't forget all intel CPUs will not have some multiplier "wiggle room". They aren't completely unlocked like the k series will be, but if the wiggle room is large enough, it may be enough to satisfy your average overclocker.
Bobnova's Avatar
I haven't seen any prices mentioned anywhere, link?
DaveHCYJ's Avatar
No official pricing, just speculation that the units will be priced relatively the same as those they are replacing.
http://www.anandtech.com/show/3871/t...ins-in-a-row/4
Bobnova's Avatar
I would be very, very surprised to see that personally.
DaveHCYJ's Avatar
Agreed. I'm not holding my breath, but at the same time that is the direction Intel has been moving. Originally you could only get unlocked multipliers in the $1000 EE units, but its slowly been moving into lower price brackets with the K units. I don't think its out of the realm of possibilities for this to be one more step in the lower priced direction.
wingman99's Avatar
I have done some more thinking and I think the motherboard manufacture can bypass intel with 3 new designed chips. A new clock gen chip for the different clock tasks and a multiplier converter chip intercept in the tracers from the PCH to the CPU and and a auto, lock PCI-E video divider chip to intercept the CPU chip tracers 5.0 GHZ buss to the PCIE-E 16x slots.
So the way I look at it, it's a win win situation for intel
Motherboard for overclocking 1155 cost $300+
or you could go with the intel unlock CPU k series i5 2500K Quad 3.3 GH z cost$300+
I don't see the CPU k for anything less than $300+ because the non overclocking cpus in there lineup go all the way down to Core i5 2500T 2.3GHz quad, that is 6 in the line up of quad cores before you get to the first K at 3.3Ghz 6MB L3 and the top k is 3.4GHz 8MB L3.
The hopefully external clock gen on the the fully overclockable 2011 socket and year. with cpus starting at $ 300, this could change to locked like the1155
intel is just cashing in on this big overclcoking enthusiast market, just like the intel engineer is saying in the youtube video I posted above.
Also I have had time to think it over and I can see we are no better than the gamers I talked about above. We cheat intel out of buying the higher clocked price point cpus with stock heatsinks, in the video I posted above intel points this out by saying there is only a small amount of extreme overclockers that pay the high price for components.
Watch the whole intel video above and pay vary close attention to what the intel engineer says, some of the video is vary boring for some of us and he points that out too, however he hits most of my points.
Bobnova's Avatar
That's what i said on page 2 :P
wingman99's Avatar
Yea I said some of the same things before too in this form, however it's much more complicated to bypass intel then we originally thought. Also overclocking is not a small market.
MIAHALLEN's Avatar
And same as what I said on page #1 (kinda)
My sentiments exactly This is nothing more than pre-mature "crying wolf" IMNSHO. The same hub-bub was happening before i7's came out, and they are SICK overclockers even on a budget! (i7 930's and i7 860's are only $199 at MicroCenter).
Overclocking will carry on - Asus and Gigabyte et all will see to that...
We're a drop in the bucket - but Intel doesn't want that drop to end up in AMD's bucket
As you were
thideras's Avatar
Could this just be a marketing ploy to garner attention?
Dolk's Avatar
So question... How are you going to OC your memory now? Are the K series going to allow Intel users to use the BCLK or is it fully locked to 100mhz across the board?
Bobnova's Avatar
You'll get more memory multipliers.
thideras's Avatar
Personally I liked where they said "UP TO 56X MULTI". With a 100mhz "FSB" (bite me, I'm on LGA775), that maxes out at 5600MHz if you can't change the "FSB". That seems pretty lackluster, in my opinion.
Dolk's Avatar
I noticed that but it didn't click. I'm betting they will have something available for highest end so that you can attempt to get to 7ghz again.
The real problem I see is that, its always been showed that straight Multi OCing has limits. At one point or another, things stop clicking and you need to push the Clock ref.
I'm only looking at this from a Benchers perspective.
thideras's Avatar
From my understanding, that was their "super high end ultra unlimited $1,000,000,000 processor that only two people can afford" line. But maybe I read it wrong.
jason4207's Avatar
More mem multis, but it looks like you'll basically be locked into standardized speeds. No tweaking to get that little bit extra, and it looks like an absolute max of 2133 on socket 1155 unless mobo manufacturers have some leeway there.
I thought that the middle/low end SB stuff (Socket 1155) was going to be locked down, but the higher-end stuff (Socket 2011) would use an external clock and be fully OCable? Details are obviously still fuzzy, though.
thideras's Avatar
I still say this is a marketing ploy. "Leak" information that may hint towards your products being locked down and BOOM, threads explode everywhere and everyone knows that a new processor is coming out. Coincidence that it happens 3-4 times in a row now? No way.
wingman99's Avatar
Overclocking is not a small market.
Intel, Discussion on CPUs and Overclocking LINK:http://www.youtube.com/watch?v=U62lC...eature=channel
Watch the whole intel video above and pay vary close attention to what the intel engineer says, some of the video is vary boring for some of us and he points that out too, however he hits all the points.
wingman99's Avatar
We never had a Anandtech preview 3-4 times.
thideras's Avatar
I'm talking about older processors. I remember this happening when i7 came out, i5 came out, Core2...
wingman99's Avatar
What I meant, we never had a any previews 3-4 times in the past.
The i7 i5 and core2 there was no actual product testing, like the sandy bridge at Anandtech.
I'm not worried in the slightest. I'm prepared to stick with my $199 i7's for at least a year - and then I would simply switch to AMD if Intel is jacking up the cost of Overclocking. Problem solved
Let the market decide and Intel will eat crow soon enough. Or (as I believe to be the case) there WILL be ways around these limitations. Or you can pay more to Overclock your Sandy Bridge "K" CPU and Intel will "win" this battle. I think the consumers should vote with their wallets since the Overclockers are such a HUGE part of Intels' bottom line like you keep getting at (I really don't believe that - even if the Intel engineer says otherwise ).
OEM makes "us" look like ants. Just look at Intel's onboard graphics dominace over AMD/Nvidia's discrete offerings (COMBINED) amungst "Enthusiasts". That's only a tiny part of the story...
RJARRRPCGP's Avatar
Looks like it may make the motherboard operate like Via KT133! (OMG, going back 9 years!)
Wouldn't that mean the PCI has to be at 40 mhz when at 120 mhz for the bus?!
That may mean that I can't OC any better than a PC with a POS 250W Deer PSU! (that I had in 2001 and 2002)
(and also has overheating PCB!)
Looks like I may be going to AMD. I may have to boycott the P67 chipset.
You might as well go back to a Via KT400 chipset with that stuff.
And that's what it would take to make Intel eat crow *IF* this is more than pre-mature crying wolf (I really think that's all it is)...
Overclocking is all about cost effective parts opened up to a whole new level of performance. If you have the cash for high-end parts - then more power to you - but I've always stuck with ~$200 CPU's and ~$200 MoBo's - and I have no intention on changing that because Intel wants to rake us over the coals to make some extra cash...
Again - I'm not worried. I'm actually a bit curious to experiment with my first AMD system if it comes to that (but it won't )
Killador's Avatar
I just want a Core i7 12core with HT running cool @ 4.0GHz for a good price. Is that too much to ask?
wingman99's Avatar
The intel Engineer said that desk top users are switching to mobile and what you have left is a desktop hyper segmentation and a big component of that is the enthusiast overclokers.
He said that the traditional market is moving to mobile so whose left, it's people that really care about these products and overclockers are big piece of that.
The word is BIG not HUGE not a drop in the bucket.
He is part of the market analysis for enthusiast, what more do you need to hear he has been working for intel for 4 years as marketing enthusiast engineer.
Also he or intel reads the overclocking forms on the net and compares and looks at overclocking data clock speeds and general overclocking data, he also said that.
He also said intel does not want to do things that would make overcloking fizzle out they feel overcloking is a key component to keep the market strong.
What part of the video did intel says otherwise.
Bobnova's Avatar
It is worth noting that if he "discovers" anything else during his market research he'll research himself right out of a job.
I'm absolutely a gung-ho overclocker. And I'm an ABSOLUTE Intel Fanboy - probably more so than most on this thread (every single PC I've built in my lifetime has used Intel CPU's and Chipsets - no joke). No doubt at all about that. If Intel raises the price of Overclocking because they can - I'm going to AMD. I'm not the only one
I'm pretty sure the Intel guy knows this, too...
Of course some will stick with higher priced Intel CPU's and still overclock on the Intel side - but part of what drives me to overclock is 1) Limited Budget and 2) Performance. I want to have a solid grasp on BOTH - if Intel removes one of the two - AMD will gladly fill the void...
Intel won't let that happen after the P4 spanking AMD gave them IMO - and there WILL be a way to overclock "base" Sandy Bride chips in the near future IMO. A broken record: "I'm not worried in the slightest"...
And we are just a drop in the bucket. Intel's attempt to make us feel otherwise is simply good marketing on their part (they have to justify their higher priced unlocked CPU's to US somehow - right?) OEM dwarfs any and all overclockers on the planet by a HUGE margin (H-U-G-E!).
wingman99's Avatar
Why would that be good marketing overclockers like to feel elite, correct. why are you debating the truth from what he says? He was talking about oveclocking is big, he is not inflating market data for sales.
If he said we are a small number of people that overclock, that would probably do better for sales. People like to feel they are in a elite club or group they do something that allot of people don't. This form is a club.
I feel ovecloking is vary easy to do and anyone can do it. Do you know how mad some enthusiasts get when i say that. And intel said there not going to take away are overcloking because we are to important for there sales.
Do you truly believe he is lying or have you just not considered he is telling the truth and overclockers are important for the market and sales.
Just consider the ida that overclocking is big like he says what would it change? most people do it and there done, they don't post they don't join the forms they just do it.
I feel they are locking up the BCLK because there is a big enough market and they feel we will pay them to overclock and I think the market will bare it.
And intel did not put the PLL in the cpu so motherboard manufactures can probably find a way to bypass intel.
The DIY overcloking community is big, that is all intel boxed cpu sales around the world and the intel engineer talked about it, anyone of those boxes now can be overclocked, if people want.
Where are the websites on the net that are for non overclocking enthusiast. At one time i wanted to get out the oveclocking forms, just to deal with regular pc problems and I could not find any sites, it's all about overclocking on the net and always has been.
We are not a drop in the bucket.
And they tried to sell those unlocked high priced cpu's and know there locking the BCLK
I think intel is experimenting to see if people will pay the price to overclock with there unlocked k chips.
Bobnova's Avatar
There is some OCing allowed, just not much.
"A few" extra multis. Sounds like ~500mhz to me.
We are a drop in the bucket. A decent sized one, and one worth exploiting, but a drop nontheless.
x509's Avatar
Basically I agree with you. But consider this.What if you have to spend say $400 more to water-cool than to air-cool, to achieve a higher overclock? From an overall "systems" perspective, at some point you simply take all that extra cash for your "overclocking budget" and spend it on faster components? No?
Just wondering. And no, I'm NOT trolling.
wingman99's Avatar
I know they won't allow base multiplier because of OEM clocking before, so they locked it, and they say turbo will have a few bins on the top limit, that will only help single threaded applications.
You can believe what you want, I trust what intel tells me about data with products and data of buyers that are overclocking they have the money to do the research and engineers just for the enthusiast market. We are not just drop in the bucket overclockers, because we help the DIY community that does not overclock and that is rare to see that, intel does not want that to fizzle.
Think of it this way, is it harder to select the correct parts and build a PC then to overclock a few bins.
Overclockers are not just a drop in the bucket.
nightelph's Avatar
Anandtech has one on hand and a pretty lengthy review.
Ace.'s Avatar
Happy New Year!
some small results to Core i5-2500k
exodus1337's Avatar
Intel has a video of a sandy bridge OC'ed to 5 ghz.... you can over clock them........
wingman99's Avatar
I would like to see that Video.
hokiealumnus's Avatar
They overclock, you can rest assured of that. It's restricted in the sense that you can't do much with bclk (a 7 MHz + increase is good), but multipliers can work wonders.
Bobnova's Avatar
That, of course, assumes you pay for an unlocked cpu.
This whole thread was about the locked cpus and locked bclk.
ghost_recon88's Avatar
Can you give 'er some gas, like 1.3v and see how it clocks?
Aye, can't argue with that. It's a pain that overclockers are limited to two CPUs on an entire platform.
jason4207's Avatar
Thanks for posting those pics!
Does CPU-Z need to be updated or something? Those RAM multis don't look right. It seems like the RAM speed is based on a 133MHz Bus speed instead of 100MHz.
Does SB allow the use of odd multis for RAM?
You're correct jason...they're based on multiplying by 133. I have no idea WHY that is, but they are. Here are the options available on the Intel board I was using. I think I've seen other boards have a DDR3-2000 option as well, so it may be board-specific.
doz's Avatar
Man, Im so golden. Wife just said today when am I going to build a 2nd computer for the house SB here I come! Probably keep this rig the way it is and give me a chance to try out a GTX570 maybe
RADIO_ACTIVE's Avatar
The OCing results, along with the the encoding/transcoding testing on the 2 K series chips are simply amazing! I think Intel really nailed it again
As for them limiting the OCers to just the K series chips, thats all fine with me if it yields the results I have been seeing.
MIAHALLEN's Avatar
In case any of you missed it....5.1GHz stable on air cooling
My full article is here...
doz's Avatar
Hey MIAHALLEN, just tell me when you want to "donate" that CPU to me and Ill "donate" a few dollars to your cause.
Leave a Comment
