iStarUSA X-Rack Removable SATA Hard Drive
Terrific way to swap hard drives to isolate various operating systems on one PC – Joe
SUMMARY: Terrific way to swap hard drives to isolate various operating systems on one PC.
Pic
The good guys at iStarUSA were nice enough to send a sample of their 1 x 5.25″ Bay SAS/SATA Mobile Rack to try out. This is a SATA mobile drive enclosure
Key Features
  • Screwless and trayless design – drive snaps in and out
  • Support SAS and SATA I/II Hard Drive
  • Key Lock prevents theft or removal during operation
  • Fits standard 5.25″ drive bay
  • Positive cooling with 40 mm Fan
  • Sturdy aluminum construction with plastic trim
The rack’s door opens easily with to reveal the interior:
Pic
The back shows two SATA connectors, a four pin power connector and the 40 mm cooling fan:
Pic
Use the yellow port for an SAS hard drive and the black port for a SATA
drive – no daisy chaining possible.
Inserting the drive couldn’t be easier – it’s literally slip it in and close the door:
Pic
Performance
I tried iStarUSA’s X-Rack on a Seagate Barracuda 250 GB, 7200 rpm hard drive with the following results:
Pic
No real surprise – it’s basically a direct connection to the PC, so performance is dependent upon the PC and drive’s characteristics.
CONCLUSIONS
This is the terrific way to swap hard drives to isolate various operating systems on one PC – no cross contamination.
Thanks again to iStarUSA for sending this our way.
  1. SansDigital 5-Bay 3.5″ IDE / SATA Hard Drive Rack
  2. Hard Drive Mobile Rack
  3. Kingwin Mobile Hard Drive Rack KF32
  4. MAPower KC-31 3½” SATA Hard Drive Enclosure
  5. Kingwin Elite SATA 3.5″ Hard Drive Enclosure
Tags:
