Iwill KA266-R DDR Motherboard
Add Your Comments
SUMMARY: DDR is coming and there are real performance improvements – Iwill is first out of the blocks with the KA266-R.
Iwill KA266-R
The board measures 12″ x 9.58″ – larger than the ASUS A7V; serial # 29. It also has a nice “power on” green diode at the bottom left.
PC Nut just got back from COMDEX with the Iwill KA266-R DDR motherboard in tow – no DDR RAM. I have DDR RAM (Crucial Engineering Sample). So we got together to run this board through its paces. Rather than wind-up with the benchmarks we ran this morning, let’s see what this board can do:
Iwill KA266-R Benchmarks
Setup/Benchmark
Result
700 MHz (7 x 100 FSB)
Quake Hi Quality
108.6/109.9
Quake Fastest
119.6/120.3
Quake “Special”
151.2/155.7
3DMark 2000 Default
6192
3DMark 2000 800/600/16
6744
SiSoft CPU
2196/976
SiSoft MultiMedia
2386/3274
SiSoft Memory
392/538
933 MHz (7 x 133 FSB)
Quake Hi Quality
131.8/137.7
Quake Fastest
161.0/161.8
Quake “Special”
203.6/209.5
3DMark 2000 Default
7038
8288
SiSoft CPU
2936/1303
SiSoft MultiMedia
3179/4368
SiSoft Memory
535/728
956 MHz (6.5 x 146 FSB)
Quake Hi Quality
134.6/140.4
Quake Fastest
167.3/168.0
Quake “Special”
211.5/217.9
3DMark 2000 Default
7116
8458
SiSoft CPU
2998/1331
SiSoft MultiMedia
3246/4461
SiSoft Memory
560/773
T-Bird Blue Core 750 MHz, 1.7 v, 128 MB Crucial DDR 7.5ns RAM, Leadtek GTS2, Global Win FOP38, “Special” = all options off, simple items on. There are no asynchronous RAM settings or V Core adjustments on this board.
Note SiSandra’s Memory scores – damn impressive! This is the one area we will see major gains over the next year or so. Good news for bandwidth intensive games like Quake.
Comparing these results to an Intel PIII 700E running 1050 MHz (HERE), it looks like Iwill’s DDR board at 956 MHz outperforms the PIII 700E on an Iwill VD133 Pro at 1050 MHz:
Benchmark
PIII 700E @ 1050 MHz
TBird 750 @ 956 MHz
Quake
158.2/147.2
167.3/168.0
3DMark 2000
8386
8458
SiSoft CPU
2388/1406
2998/1331
SiSoft Memory
415/466
560/773
NOTE: These are not “head to head” tests – comparisons are indicative only.
Rob over at PC Nut will be running more benches over the weekend. We didn’t try pushing the CPU beyond 956 MHz due to the lack of V Core settings – the CPU will do in excess of 1100 MHz at 1.85 volts. Looks like Rob will do the pencil thing on the L7 bridges to bump the voltage up.
One thing I found was that, at the speeds we ran, there were no hotspots on the board; the power transistors were barely warm to the touch – same for all other chips. Even the Northbridge heatsink was barely warm. I would still put an active cooler on it except that it is glued on – no mounting holes for something like a Lasagna chip cooler.
There is one item that is very important: The CPU fan header was not able to spin the Delta 38 cfm fan to full speed. This may be an anomaly with this board, but use caution with high wattage fans on these headers.
Overall, the board was very stable – we did not run exhaustive tests, but it handled everything we threw at it. We did find that it would not power off two times, although this is more likely a Windows problem. More benchmarks and endurance testing to come.
Iwill KA266-R: Key Features
  • FSBs: 100, 101, 102, 103, 105, 107, 110, 120, 126, 133, 136, 137, 140, 142, 146
  • Multiplier Settings: Dipswitch, 5x to 12.5x
  • FSB Settings: BIOS or Jumpers
  • DDR RAM Slots: 3 – up to 3 GB
  • VCore Adjustment: NO
  • Asynchronous RAM Settings: NO
  • CPU Temp Monitoring: Thermistor in Socket A
  • Fan Headers: 3
  • CPU Speeds Supported: 650 to 1200 MHz
  • Drives: On Board RAID
  • Accept SDRAM: NO, DDR Only
AVAILABILITY: Probably end December, no pricing yet.
Iwill KA266-R Socket
Lots of nice room for aggressive heatsinks.
Iwill KA266-R Go
Loaded with the AMD T-Bird Blue Core 750, GlobalWin FOP38 and 128 MB Crucial 133 MHz 7.5 ns DDR RAM; note AMR slot.
Iwill KA266-R Power Transistors
Looks like there are 8 power transistors – if so, speaks a lot to the stability we had with the board.
Many, many thanks to Humphrey and Rob at PC Nut for interrupting their busy workday to run these tests with me.
Email Joe
Leave a Reply
