Jetart 3.5″ Hard Drive Cooler
Simple but effective 3.5″ HD cooler – Joe
SUMMARY: Simple but effective 3.5″ HD cooler.
pic
The good guys at Jetart were nice enough to send a sample of their 3.5″ Bay HD Cooler (#HCA06) to try out.
Key Features
  • Construction: Aluminum
  • Size: 102 x 90 x 15 mm
  • Fan: 60 x 10 mm, 0.84 watts, spec noise level 22.5 dBA
A bottom view:
pic
The HD Cooler is mounted on the bottom of a hard drive – you have to ensure that there is enough clearance under the fan to allow unobstructed air entry.
Performance
To test its effectiveness, I placed a thermocouple of the top of a Seagate Barracuda 7200 rpm, 120 GB, HD and measured the drive and ambient temps; I then mounted the HD Cooler and measured temps after a half hour with the following results:
Test
HD Temp
Ambient Temp
Delta
No Cooler
33.4ºC
18.7ºC
14.7ºC
Jetart 3.5″ HD Cooler
24.7ºC
19.1ºC
5.6ºC
Jetart’s HD Cooler dropped drive temps by 9.1ºC – not bad! The fan is very quiet – you will not hear it in a case.
CONCLUSIONS
Jetart’s 3.5″ HD Cooler is a simple, effective solution to moderating HD temps. I installed it to test and it’s staying there.
Thanks again to Jetart for sending this our way to test out.
  1. Batmobile Hard Drive Cooler
  2. Jetart VC1000 Slot Cooler and VC2000 GPU Cooler
  3. JETART MiniStand Notebook Cooler
  4. Kingwin Hard Drive Cooler KHD-201
  5. Making a Cheap, Easy and Effective Hard Drive Cooler
Tags:
