Kingston Digital Releases Fourth-Generation High-Speed Media Reader and 64GB 600X CF Card
Add Your Comments
Kingston announced the release of its 4th generation HS4 All-In-One Media Reader, which improves upon previous versions by now supporting all major card formats. The latest SD card speeds (UHS-I, UHS-II) and CF type I and II (UDMA 0-7) are now fully supported. The USB 3.0 interface is backward compatible with USB 2.0 to ensure a wide range of usability.
In conjunction with the HS4 Media Reader release, Kingston also announced a 64GB capacity addition to their CompactFlash Ultimate 600x line. The 600x CF cards offer an impressive 90 MB/s read/write performance.
prodReader-FCR-HS4-thumb prodCF-CFU3-thumb
Here is the press release:
Kingston Digital Releases Fourth-Generation High-Speed Media Reader; 64GB 600X CF Card
  • Versatile Card Reader For Seamless Data Transfer
  • USB 3.0 High-Speed Performance
  • Capacity Addition to CF Ultimate 600x
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced its 4th generation HS4 All-In-One Media Reader. The multi-function reader improves upon the previous model as it reads all major card format types including the latest SD card speeds (UHS-I, UHS-II) and CF Type I and II (UDMA 0-7).
Users can easily back up and transfer music, photos, videos and other digital data with USB 3.0 high-speed performance. This allows users to save time transferring files as USB 3.0 allows up to 5Gb/s data transfer speed – almost 10x faster than USB 2.0. The portable, small- form factor reader has a brushed nickel case and is backwards compatible with USB 2.0.
Kingston® also announces a new 64GB capacity addition to its CompactFlash Ultimate 600x family. The 32GB and 64GB CF Ultimate 600x cards offer premium results with speeds up to 90MB/s read and write to support burst mode photography or HD video. The addition of MediaRECOVER® software lets users recover deleted files and restore corrupt files, if needed.
“HS4 All-In-One Media Reader is a great device to quickly move data between multiple devices whether at home or on the road,” said Jean Wong, Flash memory business manager, Kingston. “The higher-capacity CF Ultimate 600x lets avid photographers and videographers capture more content and when used with the reader, data transfer is simple and fast.”
HS4 All-In-One Media Reader carries a two-year warranty while the CF Ultimate 600x has a lifetime warranty. Both products are backed by legendary Kingston reliability and free technical support. For more information, please visit
HS4 All-In-One Media Reader Features and Specifications:
  • Ultra-portable: small size makes it an easy and convenient travel accessory
  • Versatile: Supports the major types of memory cards and the latest speeds standards (UHS-I and UHS-II)
  • Fast: USB 3.0 performance for an efficient and effortless data transfer
  • Compliant: with USB 3.0 specifications, backwards compatible with USB 2.0
  • Guaranteed: two-year warranty, free technical support
  • Dimensions: 93.17mm x 52.68mm x 16mm
  • Speed Rating1: Up to 5Gb/s data transfer speed
  • Operating Temperature: 32º to 140ºF / 0º to 60ºC
  • Storage Temperature: -4º to 185ºF / -20º to 85ºC
  • Supported card formats:
    Compact Flash: CF Type I & II (UDMA 0-7)
    Secure Digital: SD/SDHC UHS I-II/SDXC UHS I-II
    microSD: microSD/microSDHC UHS-I/microSDXC UHS-I
    Memory Stick®3: Memory Stick PRO/Duo™/PRO Duo™/ PRO-HG Duo™
  • Requirements: system with USB 3.0
  • Built-In LED Indicator
  • USB 3.0 Cable Included
Operating System USB 3.0 USB 2.0
Windows® 8.1/8/7 (SP1)/Vista® (SP2) Yes Yes
Mac OS X v.10.7.x + Yes Yes
Linux v.2.6x + Yes Yes
Chrome OS™ Yes Yes
Dino DeCesari (Lvcoyote)
Leave a Reply
  1. Where can I get one of this. I can't find them on Amazon. I like to get one to try out. I got a Lexar USB 3.0 CF card reader UDMA-7 and I am not happy with the speed and it is not consistence with speed. I bought Lexar CF card reader and I paid a premium for it and it is sucks, at least it is at my end. I see others get very impressive speed with it.
    Never mind, found it..
