Kingwin 2.5″ Mobile Disk Enclosure
Very nice unit – Joe
SUMMARY: An attractive package for diminutive hard drive mobility.
KW MD
Size: 17 mm x 90 mm x 138 mm; Weight 210 grams with drive.
The good guys at Kingwin were nice enough to send a sample of their 2.5″ Mobile Disk Enclosure (Model# KH-100), USB 2.0 format. This enables users to set up a notebook-size hard drive as a “shirt pocket” drive.
Included with the enclosure are
Set
  • Housing
  • USB & PSII Cables
  • Drivers
  • Instruction Manual
  • Mounting Screws
  • Vinyl Carry Pouch
Cover
The drive enclosure is petite and light – it measures a scant 17 mm thick. Note that it only takes 9.5 mm drives – it will not take anything thicker (unless you don’t want to use the cover). The enclosure consists of an aluminum housing and plastic hard drive holder:
Inside
The PCB is pretty bare-bones as well:
PCB
There are only two connectors:
Edge
One for the USB cable and one for the PSII cable. The PSII cable may not be needed if there is enough power from the USB port to power the drive – I used this on an Epia M10000 and did not need the PSII cable.
Mounting the drive is a snap – insert the drive into the connector block and screw it to the plastic sleeve:
HD In
Simple.
When you power up the PC, it lights up:
Lit
The bright blue neon light stays on (depends on BIOS settings for USB port) as long as its plugged in, and the red LED powers on when the drive is on.
Performance
To give some idea of what this little package can deliver, I used SiSandra to bench its performance with a Toshiba 20 GB ATA66 drive (HDD2154¹):
Bench
As a comparison, I used an adapter and ran the same drive using the motherboard’s second IDE port, with the following results:
Bench1
Son of a gun – no real difference between using the USB 2.0 or standard IDE port connection. Impressive!
  1. Kingwin F-35 3.5″ SATA HD Enclosure
  2. Kingwin 2.5″ Mobile Data Dock
  3. KINGWIN Night Hawk 3.5″ HD Enclosure
  4. Kingwin Mini Shuttle 3.5″ Hard Drive Enclosure
  5. Kingwin Super Shuttle USB 2.0 5.25″ EIDE Drive Enclosure
Tags:
