Kingwin F-35 3.5″ SATA HD Enclosure
Kingwin’s F-35 3.5″ SATA HD Enclosure looks great and is a nice solution for external storage.
When I first opened it, I thought it was a hair dryer! There are two 50 mm cooling fans on each side that are quiet and do a nice cooling job.
Key Features
  • SATA to USB 2.0 Interface
  • Front LED for Power / HD Activity
  • Two 50 mm  fans
  • External PS and USB cable included
  • Plug & Play, Hot-Swap capability
  • Suitable for all 3.5” SATA HD up to 2 TB
  • Size: 2 1/2” x 9” x 5 1/4”
  • RoHS Compliant
The back shows the power port, power switch and USB port:
Removing one screw at the bottom from opens the case for drive insertion:
An inside view that shows the PCB and SATA connectors:
Insert the drive into the sleeve to clip into the SATA connectors; lifting the large lever pops the drive out:
The enclosure ships with an external PS and  USB cable:
Performance Test
I used HD Tach 3.0.4.0 to test out HD transfer; the results are typical for USB external drive enclosures – nothing to get excited about but certainly OK for backing up data. The front lights up blue to indicate power and HD status – you can’t miss it.
Overall an attractive external storage enclosure with very distinctive packaging.
  1. Kingwin Big Drive – Dual SATA RAID Enclosure
  2. Kingwin Elite SATA 3.5″ Hard Drive Enclosure
  3. MAPower KC-31 3½” SATA Hard Drive Enclosure
  4. Kingwin Jet External Enclosure
  5. iStarUSA Internal 2×2.5″ SATA Enclosure Review (BPU-2535V2)
Tags:
