Kingwin Gladiator Liquid Cooled Heatsink
Add Your Comments
Heatsink Test – Joe
SUMMARY: Visually overwhelming, performance under whelming.
Pic
The good guys at Kingwin sent a sample of their
Gladiator Liquid Cooled Heatsink to test out. Of all the heatsinks I’ve tested, this HAS to be the most visually interesting!
Key Features
  • Fan: 100 x 25 mm; Speed: 1800 ~ 2600 rpm (temp controlled)
  • 8mm thick copper tube injected with anti-freeze
  • Size: 130 x 126.5 x 165 mm; Weight: 2.5 lbs /960 grams
  • Compatible with Athlon 64 Opteron (Socket 754/939/940/AM2), Intel Pentium D/P4(LGA775), Core 2 Duo (775 Dual-Core)
Pic
On one side is the liquid reservoir – it includes a waterpump:
Pic
Liquid is circulated through the copper tubes which are attached to the heatsink’s fins:
Pic
The base is not polished but appears flat:
Base
Parts that ship with the heatsink allow for multiple mounting schemes:
Parts
Test Results
The Gladiator was tested on an Asus P5WD2 motherboard P4 Motherboard Test Platform with a modified Pentium D 805 to read CPU case temps (both supplied by Directron).
Heatsink
Case Temp
Ambient Temp
C/W
On-Die Temp¹
Gladiator, 2445 rpm, 58 dBA²
53.1
25.6
0.29
61
¹MBM on-die temperatures.
²50 dBA measured 8″ from the fan intake corresponds to about 30 dBA measured 3 feet from the fan, a very quiet noise level.
Results place the Gladiator in the lower rank of heatsinks tested to date (Heatsink Ranking). Fan noise was noticeable but not objectionable – the fan is temperature controlled but ran on high during my testing.
CONCLUSIONS
One of the most visually interesting heatsinks I’ve seen to date – more for show than performance.
Thanks again to Kingwin for sending this our way.
Email Joe
Leave a Reply
