Kingwin Mini Shuttle 3.5" Hard Drive Enclosure
Add Your Comments
Lightweight with good cooling – Joe
SUMMARY: Lightweight enclosure with good cooling.
KW Encl
Size: 204 x 126 x 37 mm; Weight 300 grams
The good guys at Kingwin were nice enough to send a sample of the Kingwin Mini Shuttle 3.5″ Hard Drive Enclosure to try out. This is an external USB HD enclosure that has its own power supply – there is also a version that includes a Firewire port in addition to a USB port for higher throughput.
KW Parts
Includes aluminum enclosure, USB 2.0 A-B cable, AC adapter, driver CD and mounting screws
Key Features:
  • USB 2.0 to EIDE
  • Compatible with HDs up to 400 GB
  • Plug & Play (ex W98 – driver disk included)
  • Newest Prolific chipsets included (PL-2507)
  • Stackable with multiple external enclosures
  • Light weight aluminum alloy material
  • 40mm ball bearing cooling fan with red LED fault indicator
  • Over current protection for HD
  • 204(mm)L x 125.5(mm)W x 37(mm)H/ 8″(L)x 4 3/4(W)x 1 1/2(H)inches
  • PC or Mac OS
The bottom of the drive shows the fan grill:
Base
This is not the best arrangement for noise or air flow – unobstructed flow requires no interference one fan diameter from the intake. In this case the fan’s intake is very close, assuming you rest the enclosure on the table (you could use it on its edge). Fan noise was not too loud but definitely noticeable.
Opening up the top (four knurled screws) shows the fan and PCB:
KW Encl
The view from the back shows the On/Off switch and the USB port:
Looking directly into the enclosure better shows the fan location and PCB:
PCB
On the extreme right are the power and fan failure LEDs:
There is also a green LED that is on when powered up:
LED
{mospagebreak}
The HD is a snug fit:
HD
And you notice something else – when it’s all buttonede up, there are no exit holes for the fan to exhaust warm air. I tested for this as you’ll see below.
The unit is composed of aluminum base and top plates with four thin, slip-in aluminum sides:
Plate
The sides are not robust – they can be easily flexed, but once assembled, they are sufficient in compression. However, it would not take much to smack a side in – I would not use this enclosure for heavy duty mobile use.
Temperature Test
I mounted a hard drive and measured drive temps at the drive’s base and ambient temps with a digital thermometer. Temps were measured with the drive fully enclosed, with the front panel removed and with the drive in open air (I suspended the drive so that it did not rest on a hard surface).
Test Results
Condition
HD Temp
Ambient Temp
Delta
Fully Enclosed
32.8ºC
21.3ºC
11.5
Front Panel Off
31.4ºC
21.6ºC
9.8
Open Air
35.4ºC
21.4ºC
14.0
Looks like the fan works well, and opening up the enclosure to let it breathe has a significant impact on results. With the side panels so thin, drilling holes in them for airflow is not a major task and will yield tangible benefits (another approach would be to substitute an aluminum grill for the sides, available in hardware stores).
CONCLUSIONS
Kingwin’s Mini Shuttle 3.5″ Hard Drive Enclosure is an effective solution for easily adding additional storage to any system, but especially for laptops. USB ports easily allow adding more drives than you’ll probably ever need, and the Firewire option is one to consider if high throughput is desired. For hot drives, I would definitely recommend mods to increase airflow.
Email Joe
Leave a Reply
