KINGWIN Night Hawk 3.5" HD Enclosure
Add Your Comments
SUMMARY: An attractive, sturdy 3.5″ Hard Drive Enclosure
KW NH
Includes aluminum main enclosure, USB 2.0 A-B cable, DC 5V/12V dual power adapter, power cable for adapter.
The good guys at Kingwin sent us a sample of their KINGWIN Night Hawk 3.5″ HD Enclosure to check out. I tested the IDE version – there is also a SATA enclosure available.
Key Features:
  • USB 2.0 IDE (SATA HD Available)
  • Aluminum alloy construction
  • Tool-less installation
  • Plug & Play (ex Winodows 98)
  • Prolific chipset
  • 100~240V, 50~60Hz power adapter included
  • Fan failure alarm system
  • 40 mm ball bearing fan
  • PC or Mac system (desktop / laptop) with available USB ports
  • 210 mm x 122 mm x 39mm / 8 1/4″ x 4 3/4″ x 1 1/2″ inches
Ship Stuff
Product Views
The front is very clean and on the left side is the LED for Power On and Fan Status. If the fan fails, the top half of the LED turns red. The right side is the HD adtivity LED.
Front
The bottom shows the fan exhaust port – you must keep this unobstructed for cooling. There are two knurled screws (not shown) on the right side that you remove to take the top off.
Bottom
The back shows the USB 2.0 port , power plug and On/Off switch – simple.
To remove the top, unscrew two screws on the bottom, grasp the side of the cover and pull it off. However, the problem is that the cover does not come off all that easily – I had to use a moderate degree of force to get it off. In the next picture
Top Ajar
you see that the cover is one piece that covers the top and back – the problem is that it does not just slide smoothly off the back – you must lift the front until it clears the case and then slide it off the back. It’s a tight fit. Note the fan in the back.
The inside of the enclosure is very clean – the white pads are to hold the hard drive in place.
Top Off
With the cover off, the back shows the PCB, cable connecters and power switch.
Back Open
The hard drive mounts without any screws – there are two pins on each side of the case’s bottom that fit in the drive’s screw holes. I found it quite secure.
Pin
I had no space problem in mounting the drive – it’s snug and you must engage the IDE and power plug before slipping the drive into the enclosure.
HD In
Once in, there is air space around the drive for cooling:
HD Space
Overall, a tight package with good protection – this is not “tinny” at all.
The Temperature Test
I tested the Night Hawk to see how well the fan cooled the drive. I placed a thermocouple on the drive’s spindle to measure its temp, and measured ambient temps as well. The results:
KINGWIN Night Hawk Temperature Test
Condition
HD Temp
Ambient Temp
Delta
Inside Case
31.0ºC
19.3ºC
11.7ºC
Bare Drive
30.6ºC
19.2ºC
11.4ºC
The fan does an OK job, keeping drive temps almost as if it were in open air. Air is exhausted through the back of the case.
I also ran a quick test on data transfer rates using an older 20G IBM Deskstar – for what it is and as a backup, the Night Hawk does OK:
HD Test
CONCLUSIONS
KINGWIN’s Night Hawk is an attractive, sturdy 3.5″ Hard Drive Enclosure – a nice package for transporting data, etc, among different locations. If you intend to change drives often, you’ll have to put up with a moderately difficult cover changing operation, however.
Thanks again to Kingwin for sending this our way.
Email Joe
Leave a Reply
