Kingwin XT-1264 Heatpipe Heatsink
Kingwin’s XT-1264 heatpipe heatsink tests in the topmost rank – good for aggressive cooling.
The good guys at Kingwin were nice enough to send a sample of their latest heatpipe heatsink, the XT-1264, to test out. This has four heatpipes with a dense aluminum fin array cooled with a 120 mm fan.
Key Features:
  • Four 6mm heatpipes, direct contact with CPU
  • 120 mm fan, 700 – 2300 rpm, 82 – 101 cfm, 35 – 38 dBA
  • Four pin fan connector
  • Mounts for all Intel 1366 / 755 CPUs, All AMD socket AM2 / 754 / 939 / 940
  • Weight 467 grams; Size 120 x 74 x 150 mm high
A view from the side shows a fairly dense aluminum fin array:
The view from the back shows that the fins are flat plates:
The base shows the direct contact patch of the heatpipes with the CPU case:
Mounts that ship with the heatsink include pushpin adapters for Intel CPUs – these are very simple to use and do not require removing the motherboard from the case, a real plus.
Test Results
The Kingwin XT-1264 was tested on an Asus P5WD2 motherboard with a modified Pentium D 805 to read CPU case temps while running Prime 95 with the following results:
Test Die Temp Ambient Temp C/W
Kingwin XT-1264
28.2 20.1 0.14
Fan noise from both 120 mm fans was measured 8″ from the fans’ intake with a Radio Shack sound meter and measured 57 dBA @ 2360 rpm; 50 dBA at this distance is very quiet 3 feet from the fan.
Test Results Kingwin’s XT-1264 in the topmost rank of heatsinks tested to date HERE. Fan noise is noticeable with the fan running at 2360 rpm; the four pin fan header makes fan moderation an easy task with motherboards equipped for PWM.
Overall a very nice product which can be used for aggressive cooling. Kingwin’s XT-1264 are available at Fry’s Electronics Stores Nationwide and frys.com.
  1. Kingwin KA-9228 Heatpipe Heatsink
  2. Kingwin KA-9227 Heatpipe Heatsink
  3. Kingwin KA-9225 Heatpipe Heatsink
  4. Kingwin KA-9226ACU Heatpipe Heatsink
  5. Vantec Mach 1 Heatpipe Heatsink
Tags:
