LapWorks Laptop Legs
A neat way to enhance a laptop’s airflow, but make sure it can fit yours – Joe
SUMMARY: A neat way to enhance a laptop’s airflow, but make sure it can fit yours.
Legs
The good guys at LapWorksTM were nice enough to send a sample of their Laptop LegsTM product. These come in a blister pack of four legs, so if you have two laptops, you’re covered, or you can share with a friend.
As many laptop owners know, a laptop’s bottom is used to dissipate heat; in addition, some laptops have an opening for the CPU fan as well:
Fan
Getting cooling air to these areas is not helped by the skinny rubber pads commonly found on laptops – the resulting minimal clearance between the laptop bottom and the surface on which it rests is not the best situation for best cooling.
As an aid to better airflow, LapWorksTM developed Laptop LegsTM as a possible solution. These are stick-on legs which extend either 1″ or 1 3/8″:
Legs
The small foot has a rubber pad on it:
Legs
Each leg’s footprint is about 2 inches square and weighs 7 grams, about 1/4 of an ounce, so these will not add much weight.
To install, simply peel off the adhesive cover and stick onto the bottom of the laptop. You MUST make sure that the each leg is spaced the same distance from the edge; if not, the legs will be unbalanced and the laptop will possibly rock.
The “Uh-Oh” Factor
Not a bad idea – a nicer way to elevate your laptop than bottle caps or whatever else is handy (I have used pens). However, in contrast to the “make-do” solution, these are relatively permanent, so take a look at your laptop’s bottom – here is a Compaq Presario 2200:
NoNo
What I found is that there are large areas where sticking something on is either undesirable (over the fan intake) or will not work (the large rectangular area outlined on the right has is a raised edge) – the legs have no unobstructed flat surface upon which to adhere.
I checked a couple of others and found on one that the RAM, battery and PCI slots just about took up all the usable space; the third one was OK.
CONCLUSIONS
No doubt effective airflow directed at a laptop’s bottom will result in somewhat lower CPU temps. LapWorksTM Laptop LegsTM can be an effective way to ensure good airflow, although check your laptop’s bottom to make sure you can glue these on unobstructed.
Share and Enjoy:
  • Print
  • Digg
  • Sphinn
  • del.icio.us
  • Facebook
  • Mixx
  • Google Bookmarks
  1. Kingwin Ultra Cool Laptop Cooler
  2. LED Legs
  3. Laptop Cooler Mod
  4. College Laptop or Desktop – An Insider’s View
  5. Tech Talk – Favorite Laptop
Tags:
