LN2 Benchmarking 2/12 1PM EST
I’ll be running LN2 on a 1090T rig throughout the day. Get more details and tune in to live video, audio, and chat at Overclockers’ Live, or the forum thread.
Update
Ran for about 4-5 hours, until frost buildup got too heavy on RAM slots, and I encountered OS related issues with pifast, PCMark05, and 3D benches. I will turn back to air cooling to get those issues straightened out and insulate my RAM better, but I was able to get some fairly satisfactory wPrime1024m and wPrime32m submissions. Here are the results I submitted to hwbot.org from the session, you can click on the links to see verification of the scores as well as further settings info:
AMD 1090T @ 5771Mhz running wPrime1024m in 2 minutes 14.797 seconds. This is ranked 18th out of 86 submissions with this CPU. This means there are 17 submissions faster than mine on LN2, and there are about 15 scores on LN2 slower than mine… To me, that means two things. First, I could probably get a faster score if I spent more time tweaking my settings or ran higher voltage. Second, my CPU likely isn’t as strong as those garnering top scores.
AMD 1090T @ 5981.6Mhz running wPrime32m in 4.156 seconds. This is ranked 20th out of 131 submissions, which means there are 19 submissions faster than mine on LN2, and there are about 28 submissions slower than mine. Again, more voltage and tweaking could likely improve this score, but my CPU likely isn’t able to compete with the very top scores.
Live video of the session was recorded and is available on Livestream.com. You can also view the tear down process.
About Matt Bidinger 60 Articles
My name is Matt Bidinger. I manage the editorial and forum staff for Overclockers.com, and I enjoy Community Management with a number of large internet sites. I've worked in IT in my professional career; my site involvement keeps me off the streets at night. When relaxing, I can usually be found walking the parks and roads of Rootstown, OH with my wife Kim and my dog Bubba.
Loading new replies...
Avatar of I.M.O.G.
I.M.O.G.
1
25,037 messages 3 likes
Avatar of I.M.O.G.
I.M.O.G.
1
Back up live. Reinstalling windows7 then will be going after pcmark05 and pifast, neither of which would run earlier today. Then some 3d runs on the 4890.
Reply Like
Avatar of El<(')>Maxi
El<(')>Maxi
1
7,035 messages 0 likes
Hey Matt, don't waste propane warming your container up :p take the rig over to a sink and use hot water. I'll drop in the stream in a sec and see what's up.
Reply Like
Avatar of I.M.O.G.
I.M.O.G.
1
What would cause pifast to crash immediately when the test begins, 3dmark06 to crash immediately after launching (before splash screen), and pcmark05 to fail the 3d pixel shader test?
This is on win7, reinstalled at midnight last night, same problem. Switched between 4890 and 5870. Uninstalled and reloaded drivers on both cards. Ran without any chipset drivers or anything, then installed all chipset drivers and everything for the mobo.
wp1024 runs fine. 3dm03 runs fine. The things that fail also fail at stock settings, or a nice easy 5Ghz overclock thats wp1024 stable at -190C.
Anyone that can solve this riddle will forever be my hero, been up all night trying to figure something out.
Reply Like
Avatar of I.M.O.G.
I.M.O.G.
1
Bump. I know it's only been a few hours, but I could really use some ideas on this issue. Anybody?
Reply Like
Avatar of dejo
dejo
1
4,149 messages 46 likes
wish I could offer some help. I havent used amd for years and years, and havent had any issues running those benches on intel.I have seen issues running some benches over driver issues. My SB wont even open some of the 3d tests with certain drivers and some do just as you say, fail immediately.
Reply Like
Avatar of Brolloks
Brolloks
1
7,521 messages 2 likes
Your RAM stable, can you pass SPI32M?
Reply Like
Avatar of I.M.O.G.
I.M.O.G.
1
Yes. Passing sp32 at stock and 5ghz. These apps are failing before they start, and its totally consistent... always at the same point.
I was running 9.6 with the 4890, and I tried both 11.1 and 10.6 on the 5870.
Pcmark05 runs without issue, except the 3d pixel shader test... it fails before beginning.
Reply Like
Avatar of m0r7if3r
m0r7if3r
1
8,986 messages 0 likes
I feel like there's an AMD joke in here somewhere...
Did you do a clean install of each of them? Maybe you borked the hard drive, have you tried a different one?
Reply Like
Avatar of ChanceCoats123
ChanceCoats123
1
9,572 messages 0 likes
LOL, mor7.
Also, I don't think this is platform related... As in Amd is not the culprit. Are you making sure you're using the latest possible versions of each benchmark?
Reply Like
