LockHunter is a freeware utility which enables users to delete blocked files.
Key Features
- Shows processes locking a file or folder
- Allows to unlock, delete, copy or rename a locked file
- Allows to kill locking process
- Allows to remove locking processes from hard drive
- Integrates into Explorer menu
- Deletes files into the recycle bin, so you may restore them if deleted by mistake
- Supports both 32 and 64 bit Windows
I recently set up a new Vista PC for my sister and have an install file running that won’t shut down – looks like this is a perfect tool to find it and kill it.
Running the program opens this screen:
Right-clicking on the file gives you this:
Obviously I have no problems on this PC but if you have some rogue process running, this may do the job for you. LockHunter is in beta, so use it with care!
Related posts:
- DiskDigger Freeware File Recovery Program
- Fast Duplicate File Finder – Freeware Utility
- SmillaEnlarger – Freeware Photo Enhancement Tool
- Explore&Burn – Freeware Easy CD/DVD Burning App
- Product Key Finder Freeware
Tags: Software
