Mapower 3.5" Aluminum HD Enclosure
Add Your Comments
Review – Joe
SUMMARY: A very sturdy solution for HD portability with good cooling.
Pic
Size: 133.7 x 194 x 39 mm 5.26 x 7.64 x 1.5 inches
The good guys at Mapower Electronics were nice enough to send their 3.5″ external drive enclosure model # H31M to try out. This unit uses a USB 2.0 port.
Key Features:
  • Aluminum case (2mm thick) with front screen
  • USB 2.0 interface
  • Outer case aluminum, plastic front and rear panels
  • Includes USB cable, external power supply, foot stand and mounting screws
  • PC and MAC OS compatible
The enclosure ships with a stand, external power supply, USB cable and W98 driver disk:
Pic
The rear panel the USB port, power port and On-Off switch:
Pic
The front panel is a screen for air flow with a green power LED:
Pic
Two screws on the rear panel facilitate the removal of the internals:
Pic
The PCB is relatively compact:
Pic
The rear of the PCB features the external ports and power switch:
Pic
Once the HD is screwed onto the mounting rails, it’s ready to slip into the case:
Pic
Performance
I tested temps by mounting a thermocouple on the base of the HD’s spindle; temps were measured with the HD in the case and outside:
Temps
HD
Ambient
Delta
Inside Case
37.4ºC
21.1ºC
16.3ºC
Outside Case
33.9ºC
21.1ºC
12.8ºC
Not bad for passive cooling – a difference of 3.5ºC.
I tested HD transfer rates with HD Tach:
Short Test
Pic
Long Test
Pic
Transfer rates will be dependent upon the HD’s specs.
CONCLUSIONS
Mapower’s 3.5″ Aluminum HD Enclosure is a very sturdy solution for HD portability with good cooling for a passive system.
Thanks again to Mapower Electronics for allowing us to try this out.
Email Joe
Leave a Reply
