Millenium Copper: A Preview Test
Add Your Comments
SUMMARY: A very elegant design resulting in top rate performance in a small package.
Andy Lemont over at Millennium Thermal Solutions is close to launching his first entry into the heatsink market and it’s a beauty. He was kind enough to let me test out a pre-production sample, and if the production units are as good as this one, I think there is going to be a seismic event in this market.
Mill Blank
The Millenium in its final form – the fan guard in this pic is not bolted on.
We have seen, in the last couple of months, the emergence of the Delta 38 as the “performance” fan on many heatsinks. With the need to deliver super performance to cool the ever increasing Duron and T-Bird fires, almost all heatsink manufacturers have resorted to the “brute force” approach – more fan horsepower and more surface area. In most instances, this amounts to putting a 300 cubic inch hemi-head into a Volkswagen – goes like hell, but scary! With Delta 38s – NOISE!
More than a few folks have emailed me of their Delta 38 experience; after a day, in the trash can!
The Millenium, on the other hand, was designed from day one to deliver super performance without excessive noise. As you can see from the picture above, the Millenium is now an all-copper heatsink with an embedded fan.
Mill Blank
The Millenium’s “guts”. It measures about 2 5/8 x 1 1/2 inches high.
The pic above shows the heatsink without the fan. It sits inside the heatsink resulting in maximum airflow through the fins with reduced noise levels. The Millenium fan delivers about 29 cfm @ 5800 rpm. I’ll do some sound measurements, but the noise level was about the same as a YS Tech (26 cfm @ 4700 rpm).
Also, this is no light weight; it weighs in at 1 3/4 pounds (800 grams). I found the clip easy to mount on the socket with just my fingers, a nice surprise.
THE TEST
The Millenium had a thermocouple in its base above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress the CPU on three different motherboards:
  • ABIT KT7 running a Duron 800 @ 1000 (52.6 watts)
  • Iwill KK266 running a T-Bird 750 @ 1064 (63.7 watts)
  • SOYO K7VTA-B running a T-Bird 650 @ 1000 (60.4 watts)
The Duron is actually a more severe test as its area is less than the T-Bird, so there is a higher watt loading by area. Arctic Silver grease was used in all tests.
TEST RESULTS
Motherboard
CPU Temp
Ambient Temp
Delta
C/W
MBM Temp
ABIT KT7
31.2 C
22.2 C
9.0
0.17
40 C
Iwill KK266
34.2 C
22.8 C
11.4
0.18
NA
SOYO K7VTA-B
31.7 C
22.8 C
8.9
0.15
NA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
These results are not quickie snapshots; each test ran Prime 95 for a minimum of two hours – I wanted to make damn sure that the motherboards were warm so that no secondary cooling aberrations crept into the tests. I also wanted to make sure that the result I found on the ABIT KT7 was not a fluke, hence the tests on two different motherboards with different CPUs.
I also tested how far the Millenium could go with four different fans: YS Tech @ 26 cfm, Millenium fan @ 29 cfm, Delta @ 38 cfm and the “Extreme” @ 90 cfm. The YS Tech and Delta 38 fans were cut out of their bodies and fitted into the Millenium, while the “Extreme” was fitted on top of it. The ABIT KT7 was used in this test, running the Duron 800 @ 1000, 1.9 volts, Prime 95.
TEST RESULTS
Fan
CPU Temp
Ambient Temp
Delta
C/W
MBM Temp
YS Tech
32.2 C
22.4 C
9.8
0.19
44 C
Millenium
31.2 C
22.2 C
9.0
0.17
40 C
Delta 38
30.2 C
22.2 C
8.0
0.15
41 C
Extreme
29.0 C
22.0 C
7.0
0.13
40 C
CW vs CFM
As the test shows, the Millenium turns in some impressive numbers, although the noise levels beyond Millenium’s 29 cfm fan start to get excessive. I bought a Radio Shack sound meter and measured sound levels 8″ from each fan’s intake. The dBA measured does not correspond to what you might see as published by the fan manufacturers – that’s not the intent. The YS Tech is not too noisy, so look at the scaling from it:
  • YS TEch: 59 dBA
  • Millenium: 61 dBA
  • Delta 38: 72 dBA
  • Extreme: 81 dBA
To my ears, the Millenium fan, although somewhat stronger than the YS Tech, does not sound louder.
CONCLUSION
C/Ws in the 0.15 range blur the distinction between water and air cooling – the Millenium is that good. I never thought I would see a viable air cooling solution at these C/Ws, and by “viable” I mean without excessive noise, size or expense. Pricing is not finalized, but I would bet that these units will retail someplace in the $35 range (my guess).
I have the same feeling with the Millenium that I had when I first found Alphas – revolutionary design and performance leading to a whole new era in air cooled heatsink performance, much to the benefit of consumers. If Millenium can deliver, it looks like a different ball game. Andy tells me that production units should be available in about a month. We’ll have another test when available – stay tuned!
Thanks again to Andy Lemont over at Millennium Thermal Solutions for letting me test out the latest version.
Andy needs your help! The Millenium Copper needs a name, so he is sponsoring a “Name Contest”. The best name for this heatsink wins a Millenium Copper signed by Andy Lemont. Drop me a line with your entry by March 22nd, and we’ll pick a winner. At Andy’s discreton, the name may or may not be used.
NAME CONTEST WINNERS HERE
Email Joe
I want to thank all of you who took the time to submit names for my heatsink. I was blown away by the creativity and thought that people took to help me out. Picking four winners was really a challenge; I’ve also included a number of Honorable Mentions to share with you a sample of what I received. There were multiple names submitted, so the winners were the first submissions received. Congratulations to the winners!
Overall Winner
Glaciator – eCo
Runners-Up
Millenium I.C.E.* – Lee Cox
*Millenium (I) Imbedded Fan Technology (C) Copper Body Solution (E) Extreme CPU Cooling
The Therminator – Silver Surfer
CubicVortex – David Langston
Honorable Mentions
“Millenium Revolution” – Fiskum
Mobius Heat Dissipator – Chris Alton
Cool Cube Copper – John Allen
Kinetocore Cu29 – Greeves
“Wind-Chill” – Larry Hampel
IceBlock – mshergill
“Copper Cryo” – Carolyn Stears
CopperHead – Nitetrain
Copper Whopper – Khato
Cuool(er) – TEDNKIM
The Millennium CoolCube – Mathew Byrne
ICEBLOCK – Johnny
Dry Ice – Gerry Coats
Copper Cube – Heiu Tran
Cuprum Maximus – Kerwin
Copperfreeze – Tom Briers
CuBlock – Jason Van Leuven
Copperberg – Pat Ord
Cu Freeze – Joeri
COPPER-CHILL – pharoah
ICE^3 – Jason Dilz
Athlon Copper Fire Stopper – Radtke
RedChill – Dian Petrov
copper chip chiller – TIM
CPU-Balm – Ira Jones
CuKooler – G in Denver
Lucid Solution – George
cubic chiller – Chris Garcia
Copper Kiss – Lambert
The Brain Freeze – scully flex
Chill Master – LuckyDaze
Supa Dupa Temp Blaster – Wayne Barret
big ol dang chunka copper thing – Fuzz Norelid
COPPER REVOLUTION – chris.dearmitt
Vostok (this is the coldest place on earth ) – Alec Fu
Andy Lemont
Leave a Reply
