Mobile Nuclear Power Station
Andrew shows how you can
Hi!
First of all I’d like to introduce myself: I`m a 22 year old Hungarian man. I made my first watercooling stuff in the late July, 1997. I tried several things like: aircooling, water, vapochil (gas), subzero liquid, peltier, etc., but I found out that watercooling and maybe a peltier would do fine.
Case Front
But there is a problem: I always go out for LAN parties, so I had to make my cooling mobile. I have a big case, so I was thinking about what if I take my cooling inside the case. It`s an old AT case, but I transformed it into ATX 3 years ago.
First I have to talk about the CPU cooler – it’s made of copper and milled. The cooler is soldered with 8mm pipes inside and outside. But the pipes in the system all have 10mm diameter. There is a little rubber on the “block” to hold itself in place.
Waterblock Unmounted
Waterblock
An important thing is how to get rid of the captured heat. I solved it with a car`s heating unit [heater core]. It`s surface is big enough; let me count: 100 copper snails [fins]* 15 column * 7 cm depth + 3cm wide pipe * 2 sides *14 pipes * 2 up and down way = 10,668 sq cm. Dimension: 19,5cm high, 13,2wide, 7,5 deep.
It is soldered brass: up and down units, and soldered copper snails. Capacity: 2,1 dl. All the stumps are made of copper, some of them with epoxy resin, some by soldering. The stumps have 10mm diameters. You see I had to cut the case because of the L figures – the pipes cannot make the curve that the case requires.
Heater Core
Pipes
{mospagebreak}
AndrewBoy
Since the heatunit had to be put into the case, I had to pay more attention to air handling. After trying the fans behind and in front of the unit, I decided to mount them behind. I found an old junk 24x Panasonic CDRom case and I cut out a 15,8*7,8 place for two 8cm fan. The CDRom`s case is very good, because the heatunit has the same width as the CDRom`s case. I hermetically sealed it with epoxy and solid sponge.
Rad
Rad Mount
I had the problem of getting fresh air into the case. I had to cut the front of the case to let the heatunit get enough fresh air.
Case Cut
Case Front
The last thing was water circulation. I`m using a little DE800 (800l/h) pump. It requires 220v power, so I connected it up to the Power Supply`s 220 out connector. When the machine starts, the pump also starts. This pump is transformed to be a kind of inline pump, so I just plug it in and play (or pray;-]]).
Case Detail
The filling works with a T adapter. This adapter is in the highest point of the system and when I fill it up, it automatically pushes out all the air inside. To take out the water, just unplug the pump`s input pipe. The capacity is nearly 4,1 dl. Interesting to count: if the pump works at 750 l/h, then a full cycle takes 750/0,4= 1875, 3600/1845 = 1,92 seconds. It`s quite short. To close the system, I just plug a rubber stopper into the pipe on the upper side.
Case Done
Last question is: What can I do with this?
I`m cooling a 1 GHz AMD Athlon (2*256MB Infinion PC133 RAM, ABIT KT7A raid, 41 GB IBM 7200 ATA100, etc.). I`m using the processor @ 1,5 GHz without any problem.
The minimal temperature at idle: 26 C; maximum: 37 C. The liquid consists of distilled water and antifreeze (5:1). At 1,5Ghz (150*10), it is a stable system; at 1,55 GHz, sometimes it makes errors.
CPUID
Next time I will try it with peltier and a new CPU cooler.
AndrewBoy
  1. Nuclear Tower Water Cooling
  2. Water Station
  3. How to Power Your Water Pump Without Cutting Into Your Power Supply
  4. Kingwin AT100 Mobile Rack KF-101
  5. Kingwin Mobile Hard Drive Rack KF32
Tags:
