DDR power requirements examined – John Culver and David Brown
Today’s computer systems have come a long way from the meager machines of the 80’s. Processors themselves are almost a thousand times faster. With this comes another increase: Power Requirements.
It was not uncommon for an old 808x system to run off of a 95 Watt PSU. Today’s computers are using at least 300 Watts and for some duallies 400 and up. While the CPU is the most obvious source of power consumption there is one other device in your system that can get greedy quick. RAM. More specifically, slots loaded with the latest, greatest, and fastest DDR you can get, or what your board says it will support.
Take a look at some of today’s motherboards:
Abit AT7-MAX2 and KD7-RAID (KT400) +12V
- Four 184-pin DIMM sockets
- Supports 2 DIMM DDR 333/400 (Max. 2GB)
- Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
- Supports 4 DIMM Registered DDR 200/266 (Max. 3.5GB)
Abit KD7E (KT333)
- Supports 2 DIMM DDR 333 (Max. 2GB)
Abit KX7-333R
- Four 184-pin DIMM sockets support PC1600/PC2100/PC2700 DDR SDRAM module
- PC1600/PC2100/PC2700 DDR SDRAM module
- Supports 6 banks up to 3GB DRAMs for unbuffered DDR modules
- Supports 8 banks up to 3.5GB DRAMs for registered DDR modules
Shuttle AK37GTR
- Supports 4GB of DDR200/266/333/400 COMPLIANT DIMMS
Most all of the boards only support 4 DIMMs when using registered memory and then only up to DDR266 and 3.5 GB. Why?
Simple: It’s the power, or rather, the lack thereof provided by the motherboard.
Faster DIMMs require more current as do larger capacity DIMMs (such as 1GB or 512MB modules). How much current? It depends on how the module is made (configuration), whose chips are on it (type) and how fast it is (speed).
Take for instance a 256MB DDR DIMM. This DIMM can be made in one of several ways. It can have 8 256×8 chips or 16 128×4 chips. It could also be made of 4 512X16 chips. Remember there are 8 bits to a Byte. RAM chips are measured in megabits. Also remember that a DIMM is 64 bits wide. You can have any configuration that gives the desired capacity and is 64 bits wide.
There are several current ratings as set forth by the JEDEC standards for DDR. As a matter of fact there are 13 of them. (Manufactures can, and do, add and subtract parameters at their discretion). We will concentrate on IDD7 which is “Operating current: 4 Bank interleaving reads with one bank active,” and IDD5 “Auto Refresh Current”, as these are what determine how much current the RAM needs.
Let’s start by looking at various DDR chips:
| Type |
Speed
IDD7(mA)
IDD5(mA)
| Micron 256MBit |
DDR266
365
245
DDR200
350
215
| Infineon 512Mbit |
DDR333
405
335
DDR266
380
310
DDR200
380
290
| Infineon 256Mbit |
DDR333
285
190
DDR266
235
180
DDR200
220
170
| Infineon 128Mbit |
DDR333
350
205
DDR266
280
190
DDR200
270
180
| Nanya 128Mbit |
DDR333
150
170
| Nanya 256Mbit |
DDR333
200
190
DDR266
150
150
| Winbond 256Mbit |
DDR266
270
190
| Samsung 512×16 |
DDR333
650
360
DDR266
560
330
DDR200
470
300
| Samsung 512×8/4 |
DDR333
390
225
DDR266
320
207
DDR200
295
183
| Samsung 256Mbit |
DDR333
290
180
DDR266
250
165
| Samsung 128×16 |
DDR333
345
190
DDR266
320
180
DDR200
255
165
| Samsung 128×8/4 |
DDR333
320
190
DDR266
290
180
DDR200
255
164
Wheww!! That’s a lot of info. Let’s break it down a bit. We’ll concentrate on Samsung and Infineon as we have a good data sample on their modules:
| Type |
Speed
IDD7(mA)
IDD5(mA)
| Infineon 512Mbit |
DDR333
405
335
DDR266
380
310
DDR200
350
290
| Infineon 256Mbit |
DDR333
285
190
DDR266
235
180
DDR200
220
170
I have removed the 128 Mbit parts, as they are made on a different process which will throw things off:
IDD5 is generally a linear increase with speed. However, IDD7 is not. This makes it difficult to predict the current needs of a DDR400 part. However, it is obvious that a DDR400 part is going take a considerable amount more current to run.
The Samsung is a whole different story:
| Type |
Speed
IDD7(mA)
IDD5(mA)
| Samsung 512×16 |
DDR333
650
360
DDR266
560
330
DDR200
470
300
| Samsung 512×8/4 |
DDR333
390
225
DDR266
320
207
DDR200
295
183
| Samsung 256Mbit |
DDR333
290
180
DDR266
250
165
| Samsung 128×16 |
DDR333
345
190
DDR266
320
180
DDR200
255
165
| Samsung 128×8/4 |
DDR333
320
190
DDR266
290
180
DDR200
225
164
Samsung has different specs for different configurations of the same size RAM. If you do the math, you’ll find that you want modules using the 512Mx16 parts. Even though that part takes more current than the others, they need fewer chips than x4 or x8 configurations. A x4 configuration takes almost twice as much current as a x16 configuration. (Thanks Chad!)
If we have a 256MB module made with 256 Mbit DDR333 Infineon chips, it is going to need (8*285 mA) 2280 mA per stick of DDR333. That’s over 2 Amps!! If we put 4 sticks in we now need 9120 mA of current at 2.5 Volts to drive them all. That’s 22.8 Watts of power.
Want to overclock your RAM some? How about 2.7 Volts? (Which is within JEDEC specs for DDR.) Now you need 24.6 Watts. That’s already more than a Celeron 366 needed. Also, think of the heat generated by this kind of current. Those heat spreaders suddenly make much more sense.
What if you are going all out? 2GB of DDR333. That’s 4 512 MB Modules. Each one needs 3240 mA or almost 13 Amps total (32 Watts at stock voltage). That is also more than most motherboards can support.
Infineon now makes a 2GB DDR module. It requires 8.1 Amps @ DDR266. You won’t be running these in today’s Athlon boards. There just isn’t enough current to drive all that RAM. You might be able to get a maximum of 30 Watts from the 5V rail that runs the DDR.
Why does registered RAM make a difference? Even if your board can supply enough current to the modules, the address lines and control lines can’t. That’s why many boards specify the use of Registered DDR when using 4 modules.
Registered RAM modules have a buffer on the address and control lines. They also have a clock driver chip. These chips re-drive the weak input signals to all of the memory cells; something the outputs from the chipset/CPU can’t do. This is called fanout. When you have 4 modules, those signals have to go to many places. Without buffers, by the time they got to each RAM module, the signals would be much too weak for the RAM to discern.
Now, why can that Shuttle board support 4 DDR333/400 modules and the others can’t? It has an extra power connector:
Near the top right of the DIMM slots is a simple Molex Drive connector. This, and the proximity of the ATX and ATX12V connector to the RAM, let the regulators have the power they need to supply the RAM. Remember – the ATX connector only has four 5V Rails. Each one can drive around 6 A (120 Watts total) of current.
This current also needs to be shared with the CPU and other components. Also, notice that Shuttle says COMPLIANT modules, of which any of the high current chips are not on the list. Obviously, what keeps these boards from running all that RAM is the power requirements and large fan-out of control signals.
Motherboard manufacturers are combating this problem. The ATX 12V connector provides 2 additional 12 V rails to the motherboard. These will be used for the CPU VRMs (VRM 9.0 spec) and other high current needs, freeing up the 5 Volt rails for other applications. All is not lost; it’s just a bit slow in the coming.
DDRII is also just around the corner. It will help the power situation out even more since it needs only 1.8 Volts. That’s around a 25% savings over the 2.5 V required by DDR. Memory manufactures are also constantly working to shrink the process size which also shrinks power consumption.
Increased speed and capacity lead to more power needs. This is nothing unusual or surprising; just not something people think about when they upgrade their RAM. Do I have enough power? Well, Do you?
I am frequently in the Overclockers.com Forums under the “nick hooziewhatsit”. John may be there occasionally under “one800tnt” as well, if you have any questions.
John Culver (one800tnt), and
David Brown (hooziewhatsit)
